TPESD5304D-10
Ultra Low Capacitance TVS Arrays
www.sot23.com.tw
Features
Mechanical Characteristics
u
150 Watts Peak Pulse Power per Line (tp=8/20μs)
u
Protects two or four I/O lines
u
Package: DFN2510-10 (2.5×1.0×0.5mm)
u
Low capacitance: 0.3pF typical (I/O to I/O)
u
Lead Finish: Matte Tin
u
Low operating voltage: 5V
u
Case Material: “Green” Molding Compound.
u
RoHS Compliant
u
UL Flammability Classification Rating 94V-0
u
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
u
Moisture Sensitivity: Level 3 per J-STD-020
u
IEC61000-4-4 (EFT) 40A (5/50ηs)
u
Terminal Connections: See Diagram Below
u
IEC61000-4-5 (Lightning) 5A (8/20μs)
IC
Applications
Qty per Reel
3000
7”
u
Digital Visual Interface (DVI)
u
Unified Display Interface (UDI)
u
MDDI Ports
u
PCI Express
u
Serial ATA
CH
TPESD5304D-10
Reel Size
PU
Part Number
High Definition Multimedia Interface (HDMI)
BL
Ordering Information
u
TE
Dimensions and Pin Configuration
10
9
8
7
6
1
2
3
4
5
Pin
Identification
1, 2, 4, 5
Input Lines
6, 7, 9, 10
Output Lines
(No Internal Connection)
3, 8
Ground
Pin 1
Pin 2
Pin 4
Pin 5
3, 8
4-Line Protection
WWW.TECHPUBLIC.COM.TW
TPESD5304D-10
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
150
W
Peak Pulse Current (8/20µs)
IPP
5
A
ESD per IEC 61000−4−2 (Air)
±15
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
°C
IC
Operating Temperature Range
kV
±8
Storage Temperature Range
Tstg
−55 to +150
°C
Symbol
Reverse Working Voltage
VBR
Reverse Leakage Current
Clamping Voltage
0.01
CJ
Junction Capacitance
CJ
0.3
Unit
Test Condition
V
Any I/O pin to ground
V
IT = 1mA, any I/O pin to ground
0.5
µA
VRWM = 5V, any I/O pin to ground
9
V
IPP = 1A (8 x 20µs pulse), any I/O
pin to ground
16
V
IPP = 5A (8 x 20µs pulse), any I/O
pin to ground
0.4
pF
VR = 0V, f = 1MHz, between I/O
pins
0.8
pF
VR = 0V, f = 1MHz, any I/O pin to
ground
6
VC
Max
5
VC
TE
Clamping Voltage
IR
Typ
CH
Breakdown Voltage
VRWM
Min
PU
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
TPESD5304D-10
Characteristic Curves
8/20μs Pulse Waveform
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
tr
100
Peak Value IPP
80
100%
TEST
WAVEFORM
PARAMETERS
tr=8μs
td=20μs
Percent of Peak Pulse Current %
60
40
td=t IPP/2
10
15
tr = 0.7~1ns
Time (ns)
60ns
Fig4. Normalized Capacitance vs. Reverse Voltage
PU
Non - Repetitive Peak Pulse Power vs. Pulse Time
CH
10
1
0.1
TE
Peak Pulse Power - PPK (kW)
10%
30ns
30
t - Time (μs)
Fig3.
90%
BL
IPP - Peak Pulse Current - % of IPP
120
IC
Fig1.
www.sot23.com.tw
0.01
0.1
1
10
100
1000
Pulse Duration - tp (μs)
TPESD5304D-10
www.sot23.com.tw
Application Information
1
2
3
GND
8
4
1
2
3
GND
8
4
IC
BL
5
IC
5
1
2
3
8
PU
GND
4
5
TE
CH
ESD protection for HDMI port
TMDS_D2+
TMDS_D2_
TMDS_GND
TMDS_D1+
TMDS_D1_
TMDS_D0+
TMDS_D0_
TMDS_GND
TMDS_CK+
TMDS_CK_
CE_REMOTE
DDC_CLK
DDC_DAT
HOTPLUG_DET
TPESD5304D-10
www.sot23.com.tw
Outline Drawing - DFN2510-10
D
B
DIM
E
A
SEATING
PLANE
aaa C
A2
b1xN
bbb
R0.125
1
2
C A B
PU
E/2
C
A1
A
A1
A2
b
b1
D
E
e
L
N
aaa
bbb
BL
PIN 1
INDICATOR
(LASER MARK)
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.020 .023 .026 0.50 0.58 0.65
0.00 .001 .002 0.00 0.03 0.05
(.005)
(0.13)
.006 .008 .010 0.15 0.20 0.25
.014 .016 .018 0.35 0.40 0.45
.094 .098 .102 2.40 2.50 2.60
.035 .039 .043 0.90 1.00 1.10
.020 BSC
0.50 BSC
.012 .015 .017 0.30 0.38 0.425
8
8
0.08
.003
0.10
.004
IC
A
LxN
2X R0.075
7 PLACES
CH
N
bxN
e
bbb
C A B
TE
D/2
Land Pattern - DFN2510-10
P1
P
DIMENSIONS
Y
Z (C)
(Y1)
G
X
X1
DIM
C
G
P
P1
X
X1
Y
Y1
Z
INCHES
(.034)
.008
.020
.039
.008
.016
.027
(.061)
.061
MILLIMETERS
(0.875)
0.20
0.50
1.00
0.20
0.40
0.675
(1.55)
1.55
很抱歉,暂时无法提供与“TPESD5304D-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37779
- 100+0.30370
- 300+0.26666
- 3000+0.23112
- 6000+0.20888
- 9000+0.19775
- 国内价格
- 10+0.34630
- 100+0.27839
- 600+0.24443
- 1200+0.24076
- 3000+0.21186
- 国内价格
- 1+0.24975
- 30+0.24050
- 100+0.22200
- 500+0.20350
- 1000+0.19425
