TPESD112-B1-02ELS
Ultra-Low Capacitance 1-Line ESD Protection
www.sot23.com.tw
Mechanical Characteristics
Features
⚫ Ultra small package: 0.6x0.3x0.3mm
Ordering Information
Qty per Reel
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
⚫ Digital Cameras
⚫ Peripherals
Reel Size
CH
Part Number
IC
⚫ Case Material: “Green” Molding Compound.
⚫ Moisture Sensitivity: Level 3 per J-STD-020
⚫ Terminal Connections: See Diagram Below
BL
Ultra low capacitance: 0.2 pF typical
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
2-pin leadless package
Complies with following standards:
- IEC 61000-4-2 (ESD) immunity test
Air discharge: ±18kV
Contact discharge: ±12kV
– IEC61000-4-5 (Lightning) 3A (8/20 μs)
These are Pb−Free Devices
Response Time is Typically < 1 ns
PU
⚫ Package: DFN0603-2 (0201)
⚫ Lead Finish: Matte Tin
7”
TE
TPESD112-B1-02ELS 10000 or 15000
Dimensions and Pin Configuration
1
TPESD112-B1-02ELS
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
70
W
Peak Pulse Current (8/20µs)
Ipp
3
A
ESD per IEC 61000−4−2 (Air)
±18
VESD
±12
IC
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
BL
Storage Temperature Range
Symbol
Reverse Working Voltage
Clamping Voltage
Junction Capacitance
Typ
Max
Unit
Test Condition
5
V
8.6
V
IR
0.07
uA
VC
12
V
Ipp=1A(8x 20us pulse)
VC
V
Ipp=3A(8x 20us pulse)
0.25
pF
VR = 0V, f = 1MHz
6
TE
Clamping Voltage
VRWM
VBR
Reverse Leakage Current
Min
CH
Breakdown Voltage
PU
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
CJ
7.5
0.2
2
kV
IT = 1mA
VRWM = 5V
TPESD112-B1-02ELS
www.sot23.com.tw
TE
CH
PU
BL
IC
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
3
TPESD112-B1-02ELS
www.sot23.com.tw
e
D
h
b
E
NOM
MAX
A
0.230
0.300
0.330
A1
0.000
0.020
0.050
b
0.215
0.245
0.275
c
0.120
0.150
0.180
D
0.550
0.600
0.650
e
CH
c
A
Bottom View
TE
A1
DIMENSIONS
MILLIMETERS
MIN
PU
L
SYM
BL
h
IC
DFN0603-2 Package Outline Drawing (0201)
0.355 BSC
E
0.250
0.300
0.350
L
0.160
0.190
0.220
h
0.079 BSC
Suggested Land Pattern
DIMENSIONS
SYM
Y3
Y2
Z
X
MILLIMETERS
INCHES
X
0.30
0.012
Y1
0.25
0.010
Y2
0.15
0.006
Y3
0.40
0.016
Z
0.65
0.026
Y1
很抱歉,暂时无法提供与“TPESD112-B1-02ELS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.23869
- 100+0.21037
- 2000+0.18562
- 4000+0.15434
- 10000+0.15018
- 国内价格
- 5+0.26517
- 50+0.24046
- 500+0.21576
- 1000+0.19105
- 2500+0.17952
- 5000+0.16964
