TPCM1213A-01SO
1 CHANNEL LOW CAPACITANCE TVS DIODE ARRAY
WWW.SOT23.COM.TW
Mechanical Characteristics
Features
Transient protection for high speed data lines to
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Package: SOT23
Lead Finish: Matte Tin
UL Flammability Classification Rating 94V-0
Pb-Free, Halogen Free, RoHS/WEEE Compliant
Part Number
3000
Reel Size
7”
USB Power & Data Line Protection
Monitors and Flat Panel Displays
I²C Bus Protection
Portable Instrumentation
Set Top Box
CH
PU
TPCM1213A-01SO
Qty per Reel
BL
Ordering Information
IC
Applications
TE
Dimensions and Pin Configuration
VN
1
CH1
A
VP
3
CH 1
2
VP
VN
WWW.TECHPUBLIC.COM.TW
TPCM1213A-01SO
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Characteristic
Operating Supply Voltage
DC Voltage at any Channel Input
Peak Pulse Current
ESD Protection – Contact Discharge
ESD Protection – Air Discharge
Symbol
V P - VN
IPP
VESD_Contact
VESD_Air
WWW.SOT23.COM.TW
Value
6.0
(VN – 0.5) to (VP + 0.5)
4
±8
Unit
V
V
A
kV
Conditions
8/20µs, Per Figure 3
Standard IEC 61000-4-2
±15
kV
Max
5.5
8.0
±1.0
0.95
0.95
Unit
V
µA
µA
V
V
V
V
V
Ω
1.2
pF
BL
CT
Typ
3.3
±0.1
10.0
-1.7
0.80
0.80
0.9
PU
Min
6.0
0.60
0.60
0.85
Test Conditions
(VP – VN) = 3.3V
VP = 5V, VN = 0V
IR = 1mA
IPP = 1A, tp = 8/20μs
IPP = -1A, tp = 8/20μs
IF = 8mA, CH1 to VP
IF = 8mA, VN to CH1
VIN = 1.65V, VP = 3.3V,
VN = 0V, f = 1MHz
TE
Channel Input Capacitance
Symbol
VP
IP
IR
VBR
VCL1
VCL2
VFD1
VFD2
RDYN
CH
Characteristic
Operating Supply Current (Note 6)
Channel Leakage Current (Note 6)
Reverse breakdown voltage
Clamping Voltage, Positive Transients
Clamping Voltage, Negative Transients
Forward Voltage for Top Diode
Forward Voltage for Bottom Diode
Dynamic Resistance
IC
Electrical Characteristics (TA=25°C unless otherwise specified)
TPCM1213A-01SO
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
60
40
td=t IPP/2
10
15
30
Time (ns)
30ns
60ns
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
tr = 0.7~1ns
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
tr
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
50
75
100
125
150
Ambient Temperature –TA (ºC)
TPCM1213A-01SO
WWW.SOT23.COM.TW
Outline Drawing - SOT23
D
A
DIM
e1
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
H
3
B
C
c
IC
E1
GAUGE
PLANE
SEATING
PLANE
E
L
L1
DETAIL A
1
2
A2
A
C A B
3X
aaa C
PU
bbb
BL
bxN
e
SEATING PLANE
A1
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.51
0.30
0.18
0.08
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
CH
SEE DETAIL A
TE
Land Pattern - SOT23
C
SIDE VIEW
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
X
Y
DIM
Z
G
Y
C
C
E
E1
G
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
E
E1
很抱歉,暂时无法提供与“TPCM1213A-01SO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.69443
- 50+0.56497
- 600+0.45178
- 1200+0.44500
- 3000+0.36985
