TPCDSOD323-T03SC
1-Line Bi-directional Diode
www.sot23.com.tw
Features
Mechanical Characteristics
500W peak pulse power (8/20μs)
Package:SOD-323
Protects one data or power line
Operating voltage: 3.3V
Ultra low leakage: nA level
Ultra low clamping voltage
UL Flammability Classification Rating 94V-0
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 80A (5/50ns)
– IEC61000-4-5 (SURGE) 38A (8/20us)
Shipping Qty : 3000pcs/7InchTape & Reel
Case Material: “Green” Molding Compound.
IC
Moisture Sensitivity: Level 3 per J-STD-020
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Peripherals
TE
CH
PU
BL
Dimensions and Pin Configuration
1
TPCDSOD323-T03SC
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
500
W
Peak Pulse Current (8/20µs)
IPP
38
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
°C
IC
Operating Temperature Range
kV
±30
Storage Temperature Range
Tstg
−55 to +150
°C
Symbol
Reverse Working Voltage
Min
VRWM
Typ
PU
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Max
Unit
Test Condition
3.3
V
6.0
V
IT=1mA
Breakdown Voltage
VBR
Leakage Current
ILeak
100
nA
VRWM=3.3V
VC
9
V
IPP=20A,Tp=8/20μs
VC
12.0
V
IPP=38A,Tp=8/20μs
Dynamic Resistance
CH
4.0
RDYN
0.1
Ω
TLP=0.2/100ns
Junction Capacitance
CJ
50
pF
VR=0V, f=1MHz
Clamping Voltage
TE
Clamping Voltage
WWW.TPsemi.COM
TPCDSOD323-T03SC
www.sot23.com.tw
Typical Performance Characteristics (TA=25℃ unless otherwise Specified)
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
t - Time ( s)
Power Derating Curve
110
100
CH
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
Fig3.
50
75
100
125
Ambient Temperature –TA (ºC)
150
IC
80
90%
tr = 0.7~1ns
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
30ns
60ns
Time (ns)
TPCDSOD323-T03SC
www.sot23.com.tw
Outline Drawing - SOD323
DIMENSIONS
MILLIMETERS
MIN
INCHES
MAX
MIN
MAX
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
TE
CH
PU
A
BL
IC
SYM
Land Pattern - SOD323
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
WWW.TPsemi.COM
很抱歉,暂时无法提供与“TPCDSOD323-T03SC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33442
- 100+0.27176
- 600+0.24037
- 1200+0.23676
- 3000+0.19553
- 国内价格
- 10+0.36483
- 100+0.29646
- 300+0.26223
- 3000+0.21330
- 6000+0.19278
- 9000+0.18252
