SR70
SR70
    TECHPUBLIC(台舟)
    SOT-143
    ESD抑制器/TVS二极管 SOT143 Ipp=24A VBR=85V
SR70 数据手册
SR70 Low Capacitance TVS Diode Array www.sot23.com.tw Features Mechanical Characteristics ⚫ Ultra low capacitance: 3pF typical ⚫ Package: SOT143 ⚫ Lead Finish: Matte Tin ⚫ Ultra low leakage: nA level ⚫ Case Material: “Green” Molding Compound. ⚫ Moisture Sensitivity: Level 3 per J-STD-020 ⚫ Protects Two I/O lines ⚫ Low clamping voltage ⚫ Terminal Connections: See Diagram Below ⚫ Shipping Qty : 3000pcs/7Inch Tape & Reel ⚫ Complies with following standards: ⚫ – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV - - (Lightning)24A (8/20μs) ⚫ – IEC61000-4-5 ⚫ RoHS Compliant Applications ⚫ Portable Electronics ⚫ T1/E1 secondary IC Side Protection 电 子 ⚫ WAN/LAN Equipment ⚫ ISDN S/T Interface ⚫ Digital Cameras   台 舟 Dimensions and Pin Configuration   WWW.TECHPUBLIC.COM.TW SR70 Low Capacitance TVS Diode Array www.sot23.com.tw Absolute Maximum Ratings (Tamb=25°C unless otherwise specified) Parameter Symbol Value Unit Ipp 24 A Peak Pulse Current (8/20µs) ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Symbol Reverse Working Voltage Breakdown Voltage VRWM VBR IR Typ Clamping Voltage Junction Capacitance Unit 70 V V Test Condition IT = 50uA 1 uA VC 1.5 V Ipp=1A(8x 20us pulse) VC 7 V Ipp=24A(8x 20us pulse) pF VR = 0V, f = 1MHz, IO to IO 台 Clamping Voltage Max 85 舟 Reverse Leakage Current Min 电 Parameter 子 Electrical Characteristics (TA=25°C unless otherwise specified) CJ 3 2 VRWM = 5V WWW.TECHPUBLIC.COM.TW SR70 Low Capacitance TVS Diode Array www.sot23.com.tw 舟 电 子 Typical Performance Characteristics (TA=25°C unless otherwise Specified) 台 % Of Rated Power FIGURE 3 SR70 Low Capacitance TVS Diode Array www.sot23.com.tw Outline Drawing - SOT-143 D A e H e/2 DIM 4 3 GAUGE PLANE SEATING PLANE B C L L1 DETAIL A 2 子 1 0.25 E E1 c 0 bxN bbb A2 C A B A SIDE VIEW SEE DETAIL A .035 .114 .093 .051 .075 .008 .015 .020 (.021) 4 0° .006 .008 .004 .031 .000 .029 .011 .029 .003 .110 .082 .047 .048 0.80 1.22 .006 0.013 0.15 .042 0.75 0.90 1.07 0.51 .020 0.30 .037 0.76 0.94 0.20 .008 0.08 .120 2.80 2.90 3.04 .104 2.10 2.37 2.64 .055 1.20 1.30 1.40 1.92 BSC 0.20 BSC .024 0.40 0.50 0.60 (0.54) 4 8° 0° 8° 0.15 0.20 0.10 电 e1 A A1 A2 b b1 c D E E1 e e1 L L1 N 0 aaa bbb ccc DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX ccc C 4X SEATING PLANE A1 b1 C A B 台 舟 aaa C Land Pattern -SOT-143 X1 X1 SYM C E1 E2 Y Z C E1 G E2 Y X2 DIMENSIONS MILLIMETERS INCHES 2.20 0.087 1.92 0.076 1.72 0.068 G 0.80 0.031 X1 X2 Y Z 1.00 1.20 1.40 3.60 0.039 0.047 0.055 0.141 X1 4 WWW.TECHPUBLIC.COM.TW
SR70
物料型号:SR70
器件简介:低电容TVS二极管阵列,具有超低电容(典型值3pF)、超低漏电流(nA级别)、低钳位电压,符合IEC 61000-4-2(ESD)和IEC61000-4-5(闪电)标准,符合RoHS标准。
引脚分配:文档中提供了引脚配置图,但未提供具体引脚功能描述。
参数特性: - 峰值脉冲电流(8/20us):24A - ESD(空气放电):±30kV - 工作温度范围:-55°C至+125°C - 存储温度范围:-55°C至+150°C
功能详解:该器件用于保护两个I/O线路,适用于便携式电子设备、T1/E1次级IC侧保护、WAN/LAN设备、ISDN S/T接口和数字相机等应用。
封装信息:SOT-143封装,引脚镀锡,使用“绿色”模具化合物,湿度敏感度等级为3,按照J-STD-020标准。
电气特性: - 反向工作电压:70V - 击穿电压:最小85V - 反向漏电流:最大1uA(在5V反向工作电压下) - 钳位电压:1.5V(在1A 8x20us脉冲下),7V(在24A 8x20us脉冲下) - 结电容:3pF(在0V反向电压,1MHz频率下,I/O到I/O)
很抱歉,暂时无法提供与“SR70”相匹配的价格&库存,您可以联系我们找货
SR70
  • 1+0.64900
  • 200+0.44770
  • 1500+0.40700
  • 3000+0.38060
库存:6252
SR70
  • 5+0.80664
  • 50+0.62662
  • 600+0.46921
  • 1200+0.46217
库存:211
SR70
  • 5+0.80223
  • 50+0.63994
  • 600+0.49794
  • 1200+0.49047
  • 3000+0.42130
库存:6000
