SR05
SR05
    TECHPUBLIC(台舟)
    SOT-143
    ESD抑制器/TVS二极管 SOT143 Ppk=150W Ipp=6A VBR=6V
SR05 数据手册
SR05 Low Capacitance TVS Diode Array www.sot23.com.tw Mechanical Characteristics Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) –IEC61000-4-5 (Lightning) 6A (8/20μs) RoHS Compliant Package: SOT-143 ●  Lead Finish: Matte Tin ● UL Flammability Classification Rating 94V-0 Applications ● ● ● 子 ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet ● Ordering Information Reel Size 3000 7” 舟 SR05 Qty per Reel Dimensions and Pin Configuration 台 Part Number 电 ● Pin 4 1 Pin 2 4 Pin 3 2 Pin 1 3 SR05 Low Capacitance TVS Diode Array www.sot23.com.tw Absolute Maximum Ratings (Tamb=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 150 W Peak Pulse Current (8/20µs) Ipp 6 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range −55 to +125 °C Tstg −55 to +150 °C Symbol Breakdown Voltage VBR Typ Max Unit 5 V 6 Test Condition V IT = 1mA IR 0.1 uA VRWM =5V Clamping Voltage VC 15 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 25 V IPP = 6A (8 x 20 s pulse) Junction Capacitance CJ 0.5 pF VR = 0V, f = 1MHz 台 Reverse Leakage Current VRWM Min 舟 Reverse Working Voltage 电 Electrical Characteristics (TA=25°C unless otherwise specified) Parameter 0.3 kV TJ 子 Storage Temperature Range ±30 SR05 Low Capacitance TVS Diode Array PROTECTION PRODUCTS www.sot23.com.tw Typical charateristics Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 5 10 15 20 25 30 t - Time ( s) Power Derating Curve 电 Fig3. 舟 90 80 70 60 50 40 30 20 10 0 台 % of Rated Power 110 100 0 25 50 75 100 125 Ambient Temperature –TA (ºC) 10% 子 0 90% 150 tr = 0.7~1ns 30ns 60ns Time (ns) SR05 Low Capacitance TVS Diode Array www.sot23.com.tw Outline Drawing - SOT-143 D A e H e/2 DIM 4 3 GAUGE PLANE SEATING PLANE B C L L1 DETAIL A 2 子 1 0.25 E E1 c 0 bxN bbb A2 C A B A SIDE VIEW SEE DETAIL A .035 .114 .093 .051 .075 .008 .015 .020 (.021) 4 0° .006 .008 .004 .031 .000 .029 .011 .029 .003 .110 .082 .047 .048 0.80 1.22 .006 0.013 0.15 .042 0.75 0.90 1.07 0.51 .020 0.30 .037 0.76 0.94 0.20 .008 0.08 .120 2.80 2.90 3.04 .104 2.10 2.37 2.64 .055 1.20 1.30 1.40 1.92 BSC 0.20 BSC .024 0.40 0.50 0.60 (0.54) 4 8° 0° 8° 0.15 0.20 0.10 电 e1 A A1 A2 b b1 c D E E1 e e1 L L1 N 0 aaa bbb ccc DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX ccc C 4X SEATING PLANE A1 b1 C A B 台 舟 aaa C Land Pattern -SOT-143 X1 X1 SYM Y Z C E1 G E2 Y X2 X1 C E1 E2 DIMENSIONS MILLIMETERS INCHES 2.20 0.087 1.92 0.076 1.72 0.068 G 0.80 0.031 X1 X2 Y Z 1.00 1.20 1.40 3.60 0.039 0.047 0.055 0.141
很抱歉,暂时无法提供与“SR05”相匹配的价格&库存,您可以联系我们找货
SR05
  • 10+0.42066
  • 100+0.31580
  • 300+0.26331
  • 3000+0.25056
  • 6000+0.21914
  • 9000+0.20337
库存:36953
SR05
  • 10+0.38561
  • 100+0.28948
  • 600+0.24136
  • 1200+0.23774
  • 3000+0.22968
库存:4516
SR05
  • 1+0.33660
  • 200+0.21780
  • 1500+0.18920
  • 3000+0.16830
库存:10234
