SMF05C
5-Line TVS Array
www.sot23.com.tw
Mechanical Characteristics
Features
Working voltage: 5V
Low clamping voltage
Lead Finish: Matte Tin
Protects five I/O lines
Case Material: “Green” Molding Compound.
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±15kV
Contact discharge: ±8kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Ordering Information
Reel Size
3000
7”
Microprocessor Based Equipmenmt
Cell Phone Handsets and Accessories
Personal Digital Assistants (PDAs) and Pagers
PU
SMF05C
Qty per Reel
CH
Part Number
Portable Instrumentation
BL
IC
Applications
RoHS Compliant
Dimensions and Pin Configuration
TE
Package: SOT-363 (2.0X2.1X0.35mm)
Pin Configuration
SMF05C
5-Line TVS Array
www.sot23.com.tw
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
100
W
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
±15
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
−55 to +125
°C
Tstg
−55 to +150
°C
Reverse Working Voltage
Breakdown Voltage
Min
VRWM
VBR
6
Typ
Max
Unit
5
V
PU
Symbol
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Test Condition
V
IT = 1mA
0.1
uA
VRWM = 5V
IR
Forward Voltage
VF
1.2
V
IF = 15mA
Clamping Voltage
VC
10
V
IPP 1A=(8 x 20us pulse)
pF
VR = 0V, f = 1MHz
TE
CH
Reverse Leakage Current
Junction Capacitance
CJ
Note 1: I/O pins are Pin 1, 3, 4, 5 and 6
15
kV
TJ
IC
Storage Temperature Range
±8
SMF05C
5-Line TVS Array
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
Ambient Temperature –TA (ºC)
10%
BL
90%
IC
tr
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
150
tr = 0.7~1ns
30ns
60ns
Time (ns)
SMF05C
5-Line TVS Array
www.sot23.com.tw
Outline Drawing - SOT-363(2.0X2.1)
DIM
D
e1
A
A1
A2
b
c
D
E1
E
e
e1
L
L1
N
01
aaa
bbb
ccc
N
E/2
E1
1
ccc C
2X N/2 TIPS
E
2
e
B
D
A2
A
SEATING
PLANE
bxN
bbb
1.10
0.00
0.10
0.70 0.90 1.00
0.15
0.30
0.08
0.22
1.80 2.00 2.20
1.15 1.25 1.35
2.10 BSC
0.65 BSC
1.30 BSC
0.26 0.36 0.46
(0.42)
6
0°
8°
0.10
0.10
0.30
H
A1
C
.043
.000
.004
.028 .035 .039
.012
.006
.003
.009
.071 .079 .087
.045 .049 .053
.083 BSC
.026 BSC
.051
.010 .014 .018
(.017)
6
8°
0°
.004
.004
.012
BL
aaa C
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
IC
A
C A-B D
GAGE
PLANE
PU
0.15
SEE DETAIL
01
(L1)
DETAIL
A
A
CH
SIDE VIEW
L
c
TE
Land Pattern - SOT-363
X
DIM
C
G
Y
P
Z
C
G
P
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.073)
.039
.026
.016
.033
.106
(1.85)
1.00
0.65
0.40
0.85
2.70
很抱歉,暂时无法提供与“SMF05C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33116
- 100+0.26007
- 600+0.22463
- 1200+0.22126
- 3000+0.19790
- 国内价格
- 10+0.36126
- 100+0.28372
- 300+0.24506
- 3000+0.21590
- 6000+0.19268
- 9000+0.18112
- 国内价格
- 1+0.31680
- 200+0.20350
- 1500+0.17820
- 3000+0.15840
