SD36C
BI-directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
* 250W peak pulse power (8/20μs)
* Protects one data or power line
* Ultra low leakage: nA level
* Operating voltage: 36V
* Ultra low clamping voltage
Package: SOD-323
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Peripherals
Pagers Peripherals
Desktop and Servers
* Complies with following standards:
Air discharge: ±30kV
BL
Contact discharge: ±30kV
Ordering Information
Reel Size
3000
7”
CH
Qty per Reel
TE
SD36C
PU
– IEC61000-4-4 (Lightning) 4A (8/20ns)
Part Number
IC
Applications
– IEC 61000-4-2 (ESD) immunity test
Dimensions and Pin Configuration
1
2
WWW.TECHPUBLIC.COM.TW
SD36C
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
250
W
Peak Pulse Current (8/20µs)
IPP
4
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±30
Symbol
Parameter
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
PU
VRWM
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
f
VC VBR VRWM
IT
IR
IR
IT
VRWM VBR VC V
Parasitic Capacitance
Reverse Voltage
IPP
TE
VR
I
IPP
CH
IT
CESD
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Small Signal Frequency
Parameter
Breakdown Voltage
Symbol
Bi-Directional TVS
Min
Typ
VRWM
VBR
Max
Unit
36
V
40
0.5
Test Condition
V
IT = 1mA
µA
VRWM = 36V
IR
Clamping Voltage
VC
41
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
60
V
IPP = 4A (8 x 20µs pulse)
Junction Capacitance
CJ
pF
VR = 0V, f = 1MHz
10
SD36C
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
t - Time ( s)
Power Derating Curve
110
100
tr = 0.7~1ns
Time (ns)
30ns
60ns
CH
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
Fig3.
IC
80
90%
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
SD36C
www.sot23.com.tw
Outline Drawing - SOD-323
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
TE
CH
PU
BL
IC
SYM
Land Pattern - SOD-323
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
很抱歉,暂时无法提供与“SD36C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.21087
- 300+0.16385
- 1200+0.13771
- 3000+0.12207
- 国内价格
- 20+0.23004
- 200+0.17874
- 600+0.15023
- 3000+0.13317
- 9000+0.11826
- 21000+0.11027
