SD05
SD05
    TECHPUBLIC(台舟)
    SOD-323
    ESD抑制器/TVS二极管 SOD-323 Ppk=350W Ipp=26A VBR=6V
SD05 数据手册
SD05 BI-directional TVS Diode www.sot23.com.tw Mechanical Characteristics Features  350W peak pulse power (8/20μs)  Protects one data or power line  Ultra low leakage:nA level  Operating voltage:5V  Ultra low clamping voltage  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns)  RoHS Compliant * * * * * * Package: SOD-323 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below * * * * * * * Cellular Handsets and Accessories Personal Digital Assistants Notebooks and Handhelds Portable Instrumentation Peripherals Pagers Peripherals Desktop and Servers Ordering Information Reel Size 3000 7” CH SD05 Qty per Reel TE Part Number PU BL IC Applications Dimensions and Pin Configuration WWW.TECHPUBLIC.COM.TW SD05 BI-directional TVS Diode www.sot23.com.tw Absolute Maximum Ratings (Tamb=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) IPP 26 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) TJ −55 to +125 IC Operating Temperature Range ±30 Storage Temperature Range Tstg −55 to +150 kV °C °C Symbol Reverse Working Voltage Breakdown Voltage Forward Voltage VBR IR Junction Capacitance Typ Max Unit 5 V Test Condition V IT = 1mA 0.5 µA VRWM = 5V 1.2 V IF=10mA 6 VF 0.8 VC 7 V IPP = 1A (8 x 20µs pulse) VC 11 V IPP = 26A (8 x 20µs pulse) pF VR = 0V, f = 1MHz TE Clamping Voltage Clamping Voltage VRWM CH Reverse Leakage Current Min PU Parameter BL Electrical Characteristics (TA=25°C unless otherwise specified) CJ 150 WWW.TECHPUBLIC.COM.TW SD05 BI-directional TVS Diode www.sot23.com.tw Typical Performance Characteristics (TA=25℃ unless otherwise Specified) Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 30 t - Time ( s) Power Derating Curve 110 100 tr = 0.7~1ns Time (ns) 30ns 60ns CH 90 80 70 60 50 40 30 20 10 0 TE % of Rated Power 10% PU Fig3. IC 80 90% BL IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP Percent of Peak Pulse Current % tr 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) WWW.TECHPUBLIC.COM.TW SD05 BI-directional TVS Diode www.sot23.com.tw Outline Drawing - SOD-323 A DIMENSIONS MILLIMETERS INCHES MIN MAX MIN MAX 1.50 1.80 0.060 0.071 B 1.20 1.40 0.045 0.054 C 2.30 2.70 0.090 0.107 D - 1.10 - 0.043 E 0.30 0.40 0.012 0.016 F 0.10 0.25 0.004 0.010 H - 0.10 - 0.004 TE CH PU BL IC SYM Land Pattern - SOD-323 SYM DIMENSIONS MILLIMETERS INCHES A 3.15 0.120 B 0.80 0.031 C 0.80 0.031 WWW.TECHPUBLIC.COM.TW
SD05
物料型号:SD05
器件简介:SD05是一款双向TVS二极管,能够保护数据线或电源线,具有超低漏电流(nA级别),并且符合RoHS标准。
引脚分配:文档中提供了引脚配置图,但未提供具体的引脚分配信息。
参数特性: - 峰值脉冲功率:350W(8/20μs) - 工作电压:5V - 封装:SOD-323 - 防潮等级:根据J-STD-020为3级 - 符合IEC 61000-4-2(静电放电)和IEC61000-4-4(电快速瞬变脉冲群)标准。
电气特性(在25°C环境温度下): - 反向工作电压:5V - 击穿电压:6V - 反向漏电流:最大0.5μA(在5V反向工作电压下) - 正向电压:0.8V至1.2V(在10mA正向电流下) - 钳位电压:7V(在1A脉冲电流下)和11V(在26A脉冲电流下) - 结电容:最大150pF(在0V反向电压和1MHz频率下)
功能详解:SD05能够双向钳位电压,提供有效的静电放电和电快速瞬变脉冲群保护。
应用信息:适用于手机及其配件、笔记本电脑、便携式仪器、个人数字助理、寻呼机及其周边设备、台式电脑和服务器等。
封装信息:SOD-323封装,提供了详细的尺寸和引脚图案。
很抱歉,暂时无法提供与“SD05”相匹配的价格&库存,您可以联系我们找货
