PESD5V0S1BL-TP
1-Line Bi-directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
⚫ Package: DFN1006-2 (0402)
⚫ Lead Finish: Matte Tin
⚫ Ultra small package: 1.0x0.6x0.5mm
⚫ Ultra low capacitance: 15pF typical
⚫ Case Material: “Green” Molding Compound.
⚫ Moisture Sensitivity: Level 3 per J-STD-020
⚫ Ultra low leakage: nA level
⚫ Low operating voltage: ±5V
⚫ Terminal Connections: See Diagram Below
⚫ Shipping Qty : 10000pcs/7Inch Tape & Reel
⚫ Low clamping voltage
⚫ 2-pin leadless package
⚫ Marking: PB
⚫ Complies with following standards:
Applications
⚫ – IEC 61000-4-2 (ESD) immunity test
⚫ Smart Phone and Tablet PC
Air discharge: ±30kV
Contact discharge: ±30kV
- - (Lightning)8A (8/20μs)
μs)
⚫ – IEC61000-4-5
⚫ RoHS Compliant
⚫ TV and Set Top Box
⚫ Wearable Devices
⚫ PDA
舟
电
子
⚫ Lead Finish: NiPdAu
Dimensions and Pin Configuration
台
1.0
0.60
0.65
0.50
PNESD5V0S1BL-TP
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
80
W
Peak Pulse Current (8/20µs)
Ipp
8
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
子
Storage Temperature Range
kV
±30
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Reverse Working Voltage
Reverse Leakage Current
5
V
8.4
V
IR
0.08
uA
VC
6
V
Ipp=1A(8x 20us pulse)
10
V
Ipp=8A(8x 20us pulse)
pF
VR = 0V, f = 1MHz
台
Clamping Voltage
Clamping Voltage
Unit
VBR
Junction Capacitance
Typ
5.6
舟
Breakdown Voltage
Max
VRWM
Min
电
Parameter
VC
CJ
15
2
Test Condition
IT = 1mA
VRWM = 5V
WWW.TECHPUBLIC.COM.TW
PESD5V0S1BL-TP
www.sot23.com.tw
台
舟
电
Fig.1 Pulse Waveform-ESD (IEC61000-4-2)
子
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
PESD5V0S1BL-TP
www.sot23.com.tw
DFN1006-2 Package Outline Drawing (0402)
e
D
h
h
A
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
b
E
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
L
A1
c
A
Bottom View
0.65 BSC
子
e
0.026 BSC
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
舟
电
E
台
Suggested Land Pattern
Y3
Y2
SYM
Y1
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
4
很抱歉,暂时无法提供与“PESD5V0S1BL-TP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06979
- 2000+0.04693
- 4000+0.04623
- 10000+0.04198
- 国内价格
- 50+0.07614
- 500+0.06005
- 1500+0.05120
- 10000+0.04580
- 20000+0.04115
- 50000+0.03867
