PESD2CAN
Can bus Esd Protection Diode
www.sot23.com.tw
Features
Mechanical Characteristics
250W peak pulse power(8/20µs)
SOT-23 package
Molding compound flammability rating:
UL 94V-0
Packaging: Tape and Reel per EIA 481
Protects two bi-directional lines
Ultra low leakage:nA level
Operating voltage:24V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
IC
Shipping Qty : 3000pcs/7Inch Tape & Reel
- - (Lightning)5A (8/20 μs)
– IEC61000-4-5
Applications
RoHS Compliant
BL
CAN Bus Protection
CH
PU
Automotive Appllcatrons
TE
Dimensions and Pin Configuration
1
3
2
1
PESD2CAN
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
250
W
Peak Pulse Power(8/20µs)
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
−55 to +125
°C
Tstg
−55 to +150
°C
BL
Storage Temperature Range
kV
TJ
IC
Operating Temperature Range
±30
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Reverse Working Voltage
Breakdown Voltage
VRWM
VBR
IR
Clamping Voltage
VC
Clamping Voltage
VC
Unit
Test Condition
24
V
32
V
IT = 1mA
0.08
uA
VRWM = 24V
V
IPP = 1A (8 x 20µs pulse)
50
V
IPP = 5A (8 x 20µs pulse)
5.5
A
tp = 8/20µs
pF
VR = 0V, f = 1MHz, Pin 1 to Pin 2
33
IPP
CJ
Max
26.5
TE
Junction Capacitance
Typ
CH
Reverse Leakage Current
Peak Pulse Current
Min
PU
Parameter
17
2
PESD2CAN
www.sot23.com.tw
CH
PU
BL
IC
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
TE
% Of Rated Power
FIGURE 3
3
PESD2CAN
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E1
GAUGE
PLANE
SEATING
PLANE
E
c
0.25
C
IC
L
L1
DETAIL A
1
2
bxN
bbb
C A B
A2
A
3X
BL
e
aaa C
TE
CH
C
PU
A1
SEE DETAIL A
SIDE VIEW
SEATING PLANE
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
C
C
E
E1
G
X
Y
Z
E
E1
4
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.08
0.18
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
很抱歉,暂时无法提供与“PESD2CAN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.27473
- 300+0.19632
- 1200+0.19338
- 3000+0.16394
- 15000+0.16230
- 国内价格
- 1+0.26840
- 200+0.17270
- 1500+0.15070
- 3000+0.13310
- 国内价格
- 10+0.29970
- 100+0.24268
- 300+0.21417
- 3000+0.17885
- 6000+0.16179
- 9000+0.15326
