GBLC03C-TP
GBLC03C-TP
    TECHPUBLIC(台舟)
    SOD-323
    ESD抑制器/TVS二极管 SOD-323 23V 4A
GBLC03C-TP 数据手册
GBLC03C-TP 1-Line Low Capacitance Bi-directional TVS Diode www.sot23.com.tw Features    Mechanical Characteristics 100W peak pulse power (8/20μs)   Ultra low capacitance: 0.3 pF typical Ultra low leakage: nA leel Low operating : 3.3V  Low clamping voltage  Protects one power line or data line  Complies with following standards:  – IEC 61000-4-2 (ESD) immunity test Air discharge: ±20kV Contact discharge: ±15kV  – IEC61000-4-4 (EFT) 40A (5/50ns)  RoHS Compliant     BL IC  PU Applications   USB Ports Smart Phones Wireless Systems Ethernet 10/100/1000 Base T Qty per Reel Reel Size 3000 7” TE GBLC03C-TP   CH Ordering Information Part Number Package: SOD-323 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Dimensions and Pin Configuration 1 A 2 1 GBLC03C-TP 1-Line Low Capacitance Bi-directional TVS Diode www.sot23.com.tw Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 100 W Peak Pulse Current (8/20µs) IPP 4 A ESD per IEC 61000−4−2 (Air) ±20 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ −40 to +85 °C Tstg −55 to +150 °C IC Storage Temperature Range kV ±15 Symbol Reverse Working Voltage VBR Clamping Voltage Junction Capacitance IT = 1mA Typ 4 Max Unit 3.3 V 6 V 0.2 µA IR VRWM = 3.3 V VC IPP = 1A (8 x 20µs pulse) 5 V VC IPP = 4A (8 x 20 s pulse) 23 V TE Reverse Leakage Current Clamping Voltage VRWM Min CH Breakdown Voltage Test Condition PU Parameter BL Electrical Characteristics (TA=25°C unless otherwise specified) CJ VR = 0V, f = 1MHz 2 0.3 pF GBLC03C-TP 1-Line Low Capacitance Bi-directional TVS Diode www.sot23.com.tw Typical Performance Characteristics (TA=25°C unless otherwise Specified) Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 80 60 40 td=t IPP/2 0 0 5 10 15 20 25 30 t - Time ( s) Power Derating Curve CH 90 80 70 60 50 40 30 20 10 0 TE % of Rated Power 110 100 0 25 50 75 100 125 tr = 0.7~1ns 30ns PU Fig3. 10% BL 20 90% IC IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP Percent of Peak Pulse Current % tr 150 Ambient Temperature –TA (ºC) 3 60ns Time (ns) GBLC03C-TP 1-Line Low Capacitance Bi-directional TVS Diode www.sot23.com.tw SOD-323 Package Outline Drawing A DIMENSIONS MILLIMETERS INCHES MIN MAX MIN MAX 1.50 1.80 0.060 0.071 B 1.20 1.40 0.045 0.054 C 2.30 2.70 0.090 0.107 D - 1.10 - 0.043 E 0.30 0.40 0.012 0.016 IC SYM 0.10 0.25 0.004 0.010 H - 0.10 - 0.004 BL F PU Suggested Land Pattern TE CH SYM 4 DIMENSIONS MILLIMETERS INCHES A 3.15 0.120 B 0.80 0.031 C 0.80 0.031
GBLC03C-TP
1. 物料型号:GBLC03C-TP 2. 器件简介:1-Line Low Capacitance Bi-directional TVS Diode,即单线低电容双向TVS二极管。 3. 引脚分配:文档中提供了引脚配置图,但未提供具体的引脚功能描述。 4. 参数特性: - 峰值脉冲功率:100W(8/20μs) - 超低电容:典型值0.3pF - 超低漏电流:nA级别 - 低工作电压:3.3V - 低钳位电压 - 符合IEC 61000-4-2(ESD)和IEC61000-4-4(EFT)标准 - RoHS合规 5. 功能详解:文档提供了电气特性表和典型性能特性图,包括反向工作电压、击穿电压、反向漏电流、钳位电压和结电容等参数。 6. 应用信息:适用于USB端口、智能手机、无线系统、以太网10/100/1000 Base T等。 7. 封装信息:SOD-323封装,引脚镀锡,采用“绿色”模具化合物,UL阻燃等级94V-0,湿度敏感等级3,根据J-STD-020标准。
GBLC03C-TP 价格&库存
很抱歉,暂时无法提供与“GBLC03C-TP”相匹配的价格&库存,您可以联系我们找货
GBLC03C-TP
  • 20+0.25938
  • 300+0.20938
  • 1200+0.18157
  • 3000+0.14721
库存:3000
GBLC03C-TP
  • 20+0.21846
  • 300+0.17149
  • 1200+0.14536
  • 3000+0.11309
库存:116
GBLC03C-TP
  • 1+0.18980
库存:463
