ESDA6V1-5W 6-TP
5-Line TVS Array
www.sot23.com.tw
Mechanical Characteristics
Features
Working voltage: 5V
Low clamping voltage
Lead Finish: Matte Tin
Protects five I/O lines
Case Material: “Green” Molding Compound.
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±25kV
Contact discharge: ±20kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Ordering Information
Reel Size
3000
7”
Microprocessor Based Equipmenmt
Cell Phone Handsets and Accessories
Personal Digital Assistants (PDAs) and Pagers
PU
ESDA6V1-5W6-TP
Qty per Reel
CH
Part Number
Portable Instrumentation
BL
IC
Applications
RoHS Compliant
Dimensions and Pin Configuration
TE
Package: SOT-363 (2.0X2.1X0.35mm)
Pin Configuration
ESDA6V1-5W 6-TP
5-Line TVS Array
www.sot23.com.tw
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
100
W
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
±25
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
−55 to +125
°C
Tstg
−55 to +150
°C
Reverse Working Voltage
Breakdown Voltage
Min
VRWM
VBR
6
Typ
Max
Unit
5
V
PU
Symbol
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Test Condition
V
IT = 1mA
0.1
uA
VRWM = 5V
IR
Forward Voltage
VF
1.2
V
IF = 15mA
Clamping Voltage
VC
10
V
IPP 1A=(8 x 20us pulse)
pF
VR = 0V, f = 1MHz
TE
CH
Reverse Leakage Current
Junction Capacitance
CJ
Note 1: I/O pins are Pin 1, 3, 4, 5 and 6
30
kV
TJ
IC
Storage Temperature Range
±20
ESDA6V1-5W 6-TP
5-Line TVS Array
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
Ambient Temperature –TA (ºC)
10%
BL
90%
IC
tr
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
150
tr = 0.7~1ns
30ns
60ns
Time (ns)
ESDA6V1-5W 6-TP
5-Line TVS Array
www.sot23.com.tw
Outline Drawing - SOT-363(2.0X2.1)
DIM
D
e1
A
A1
A2
b
c
D
E1
E
e
e1
L
L1
N
01
aaa
bbb
ccc
N
E/2
E1
1
ccc C
2X N/2 TIPS
E
2
e
B
D
A2
A
SEATING
PLANE
bxN
bbb
1.10
0.00
0.10
0.70 0.90 1.00
0.15
0.30
0.08
0.22
1.80 2.00 2.20
1.15 1.25 1.35
2.10 BSC
0.65 BSC
1.30 BSC
0.26 0.36 0.46
(0.42)
6
0°
8°
0.10
0.10
0.30
H
A1
C
.043
.000
.004
.028 .035 .039
.012
.006
.003
.009
.071 .079 .087
.045 .049 .053
.083 BSC
.026 BSC
.051
.010 .014 .018
(.017)
6
8°
0°
.004
.004
.012
BL
aaa C
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
IC
A
C A-B D
GAGE
PLANE
PU
0.15
SEE DETAIL
01
(L1)
DETAIL
A
A
CH
SIDE VIEW
L
c
TE
Land Pattern - SOT-363
X
DIM
C
G
Y
P
Z
C
G
P
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.073)
.039
.026
.016
.033
.106
(1.85)
1.00
0.65
0.40
0.85
2.70
很抱歉,暂时无法提供与“ESDA6V1-5W6-TP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61031
- 50+0.49119
- 150+0.43168
- 500+0.38697
- 3000+0.30575
- 6000+0.28782
- 国内价格
- 10+0.55945
- 100+0.45025
- 600+0.35472
- 1200+0.34940
- 3000+0.28027
- 国内价格
- 1+0.33660
- 200+0.21780
- 1500+0.18920
- 3000+0.16830
