ESDA25L
2 -L ine Uni-directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
300W peak pulse power(8/20µs)
Protects one bi-directional or two uni-directional lines
Ultra low leakage:nA level
Operating voltage:24V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
Applications
– IEC61000-4-4 (EFT) 40A (5/50ns)
–IEC61000-4-5 (Lightning) 7A (8/20μs)
RoHS Compliant
Ordering Information
Part Number
3000
Reel Size
Cellular Handsets and Accessories
Notebooks and Handhelds
Portable Instrumentation
Set Top Box
Industrial Controls
7”
舟
电
子
ESDA25L
Qty per Reel
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J STD 020
台
Dimensions and Pin Configuration
1
1
ESDA25L
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
300
W
Peak Pulse Current (8/20µs)
IPP
7
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Reverse Working Voltage
Breakdown Voltage
VRWM
VBR
IR
Forward Voltage
VF
VC
Typ
0.8
Junction Capacitance
CJ
CJ
Max
Unit
24
V
V
Test Condition
IT = 1mA
0.1
µA
1.2
V
IF = 10mA
V
IPP = 1A (8 x 20µs pulse)
45
V
IPP = 7A (8 x 20µs pulse)
70
pF
33
VC
台
Clamping Voltage
26.7
舟
Reverse Leakage Current
Clamping Voltage
Min
子
Symbol
电
Parameter
pF
VRWM = 24V
VR=0, f=1MHz,Pin 1 to Pin 3 or
Pin 2 to Pin 3
VR=0, f=1MHz,Pin 1 to Pin 2
ESDA25L
www.sot23.com.tw
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
Percent of Peak Pulse Current %
tr
60
40
td=t IPP/2
90%
10%
10
15
30
子
Power Derating Curve
舟
电
台
% of Rated Power
110
100
90
80
70
60
50
40
30
50
75
30ns
60ns
t - Time ( s)
Fig3.
tr = 0.7~1ns
100
125
150
Ambient Temperature –TA (ºC)
3
Time (ns)
ESDA25L
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E1
GAUGE
PLANE
SEATING
PLANE
E
C
c
0.25
L
L1
DETAIL A
1
2
bxN
bbb
e
A2
A
C A B
3X
aaa C
C
舟
电
子
A1
SEE DETAIL A
SIDE VIEW
SEATING PLANE
台
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
C
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
C
E
E1
G
X
Y
Z
E
E1
4
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.18
0.08
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
很抱歉,暂时无法提供与“ESDA25L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31264
- 100+0.25512
- 600+0.22631
- 1200+0.22292
- 3000+0.18543
- 国内价格
- 10+0.34107
- 100+0.27832
- 300+0.24689
- 3000+0.20229
- 6000+0.18339
- 9000+0.17399
