1N4148WT
FAST SWITCHING DIODE
www.sot23.com.tw
Features
Applications
High reverse impedance;
Speed is fast.
High speed switch circuit
Ordering Information
1N4148WT
Reel Size
IC
Qty per Reel
7”
3000
BL
Part Number
PU
SOD523
Cathode
CH
Anode
TE
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
反向峰值电压/Non-Repetitive Peak Reverse Voltage
VRM
100
V
重复反向峰值电压/ Repetitive Peak Reverse Voltage
VRRM
75
V
重复正向峰值电流/ Repetitive Peak Forward Current
IFRM
300
mA
IO
150
mA
IFSM
2
A
PD
0.2
W
Tstg
-55~150
连续正向电流/Continuous Forward Current
正向瞬间峰值电流 @=1.0µS
Peak Forward Surge Current
功率/ Power Dissipation
储存温度/Storage Temperature
WWW.TECHPUBLIC.COM.TW
1
1N4148WT
www.sot23.com.tw
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Symbol
Conditions
Min
IR=100μ A
100
IR=5μ A
75
Max
Unit
V
BV
正向电压/Forward Voltage
VF
IF=10mA
1
V
IR1
VR=75V
5
μA
IR2
VR=20V
25
nA
CT
VR=0,f=1MHz
4
pF
4
nS
端电容/Capacitance Between
Terminals
反向恢复时间/Reverse Recovery
IF=10mA, IR=60mA
Irr=1mA,RL=100Ω
TE
CH
PU
Time
trr
BL
反向漏电流/Reverse Current
IC
击穿电压/Break Voltage
2
1N4148WT
www.sot23.com.tw
TE
CH
PU
BL
IC
Typical Characteristics
3
1N4148WT
www.sot23.com.tw
Outline Drawing - SOD-523
SOD-523
A
Millimeters
B
1
2
Min
Max
Min
Max
A
1.10
1.30
0.043
0.051
B
0.70
0.90
0.028
0.035
C
0.50
0.70
0.020
0.028
D
0.25
0.35
0.010
0.014
J
0.07
0.20
BL
C
K
S
K
0.15
0.25
0.006
0.010
S
1.50
1.70
0.059
0.067
CH
Land Pattern - SOD-523
0.0028 0.0079
PU
J
DIM
IC
D
Inches
TE
Recommended Mounting Pad Layout
1.40
0.0547
0.40
0.0157
0.40
0.0157
Dimensions in ( millimeters )
inches
4
很抱歉,暂时无法提供与“1N4148WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09980
- 500+0.07863
- 3000+0.06470
- 6000+0.05768
- 24000+0.05152
- 51000+0.04828
- 国内价格
- 50+0.09148
- 600+0.07207
- 1200+0.07099
- 3000+0.05930
- 15000+0.05287
- 国内价格
- 1+0.33330
- 200+0.11110
- 1500+0.06941
- 3000+0.05489
