MMBT5551
MMBT5551
    SLKOR(萨科微)
    SOT-23
    NPN Vcbo:180V Ic:0.6A Pc:0.3W SOT23-3
MMBT5551 数据手册
MMBT5551 NPN General Purpose Transistor FEATURES z Epitaxial planar die construction. z Complementary PNP type available (MMBT5401). z Also available in lead free version. APPLICATIONS z Ideal for medium power amplification and switching SOT-23 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Symbol Parameter Value UNIT VCBO collector-base voltage 180 V VCEO collector-emitter voltage 160 V VEBO emitter-base voltage 6 V IC collector current (DC) 0.6 A PC Collector dissipation 0.3 W Tj ,Tstg junction and storage temperature -55-150 °C ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Symbol Parameter Test V(BR)CBO Collector-base breakdown voltage IC=100μA,IE=0 180 V(BR)CEO Collector-emitter breakdown voltage IC=0.1mA,IB=0 160 V(BR)EBO Emitter-base breakdown voltage IE=100μA,IC=0 6 ICBO collector cut-off current IE = 0; VCB = 180V - 0.1 μA IEBO emitter cut-off current IC = 0; VEB = 4V - 0.1 μA hFE DC current gain VCE = 5V; IC= 1mA VCE = 5V;IC = 10mA VCE = 5V;IC = 50 mA 80 80 30 250 - VCE(sat) collector-emitter saturation voltage IC = 50 mA; IB = 5 mA - 0.5 V VBE(sat) base-emitter saturation voltage IC = 50 mA; IB = 5 mA - 1 V fT transition frequency IC = 10mA; VCE = 10V; f = 100MHz 80 - MHz www.slkormicro.com conditions B B B 1 MIN. MAX. UNIT MMBT5551 TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.slkormicro.com 2 MMBT5551 Dimensions in inch (mm) SOT-23 www.slkormicro.com 3
MMBT5551
物料型号为 MMBT5551,这是一款NPN型通用晶体管。
器件简介包括外延平面芯片结构,并且有互补的PNP类型(MMBT5401)以及无铅版本可供选择。
引脚分配为SOT-23封装,具体引脚未在文档中明确说明。
参数特性包括最大额定值和电气特性。
最大额定值有集电极-基极电压(VCBO 180V)、集电极-发射极电压(VCEO 160V)、发射极-基极电压(VEBO 6V)、集电极电流(DC)(Ic 0.6A)、集电极耗散功率(Pc 0.3W)以及结和存储温度(Tj,Tstg -55至150摄氏度)。
功能详解涉及电气特性,包括集电极-基极击穿电压(V(BR)CBO 180V)、集电极-发射极击穿电压(V(BR)CEO 160V)、发射极-基极击穿电压(V(BR)EBO 6V)、截止集电极电流(IcBO 0.1uA)、截止发射极电流(IEBO 0.1uA)、直流电流增益(hFE 80至250)、饱和集电极-发射极电压(VcE(sat) 0.5V)、饱和基极-发射极电压(VBE(sat) 1V)以及过渡频率(fT 80MHz)。
应用信息指出该晶体管适用于中等功率放大和开关。
封装信息为SOT-23,尺寸数据以英寸和毫米为单位提供。
更多详细信息和应用指南可访问 www.slkormicro.com。
MMBT5551 价格&库存
很抱歉,暂时无法提供与“MMBT5551”相匹配的价格&库存,您可以联系我们找货
MMBT5551
  • 50+0.07534
  • 600+0.05930
  • 1200+0.05841
  • 3000+0.04762
库存:2981
MMBT5551
  • 50+0.08219
  • 500+0.06470
  • 3000+0.05195
  • 6000+0.04612
  • 24000+0.04115
  • 51000+0.03834
库存:508
MMBT5551
  • 3000+0.073903000+0.00956
  • 6000+0.064556000+0.00836
  • 9000+0.059789000+0.00774
  • 15000+0.0543915000+0.00704
  • 21000+0.0511921000+0.00663
  • 30000+0.0480630000+0.00622
MMBT5551
  • 1+0.884691+0.11446
  • 10+0.2472910+0.03200
  • 100+0.14987100+0.01939
  • 500+0.10649500+0.01378
  • 1000+0.092201000+0.01193
MMBT5551
  • 1+0.05250
  • 10+0.04810
  • 100+0.04380
  • 500+0.03870
  • 1000+0.03700
  • 3000+0.03470
  • 9000+0.03230
库存:1993
