SLVU2.8S3
Low Voltage EPD TVS Diode For ESD and Latch-Up Protection
www.sot23.com.tw
Features
Mechanical Characteristics
150W peak pulse power(8/20µs)
One device protects one unidirectional line
Two devices protect two high-speed line pairs
Ultra low leakage:nA level
Low operating voltage:2.8V
Low capacitance
Ultra low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 10A (8/20µs)
RoHS Compliant
Applications
3000
7”
CH
PU
Reel Size
Dimensions and Pin Configuration
TE
SLVU2.8S3
Qty per Reel
Base Station
Analog Inputs
Switch Systems
10/100 Ethernet
WAN/LAN Equipment
BL
Ordering Information
Part Number
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
IC
3
1
2
SLVU2.8S3
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power(8/20µs)
Ppk
150
W
Peak Pulse Current(8/20µs)
IPP
10
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±30
Symbol
Punch-Through Voltage
Reverse Leakage Current
Clamping Voltage
Clamping Voltage
Junction Capacitance
Max
Unit
2.8
V
Test Condition
IR
0.5
µA
VRWM = 2.8V
VC
4
V
IPP = 1A (8 x 20µs pulse)
VC
6
V
IPP = 5A (8 x 20µs pulse)
8
V
IPP = 10A (8 x 20µs pulse)
pF
VR=0, f=1MHz
VBR
TE
Clamping Voltage
VRWM
Typ
PU
Reverse Working Voltage
Min
3.0
0.01
CH
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
VC
CJ
5
V
I T =2µA
WWW.TECHPUBLIC.COM.TW
SLVU2.8S3
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
Fig3.
Power Derating Curve
tr = 0.7~1ns
Time (ns)
30ns
60ns
CH
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
t - Time ( s)
IC
80
90%
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
SLVU2.8S3
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
H
3
B
C
c
IC
E1
GAUGE
PLANE
SEATING
PLANE
E
L
L1
DETAIL A
1
2
C A B
A2
A
3X
aaa C
PU
bbb
BL
bxN
e
SEATING PLANE
A1
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.08
0.18
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
SEE DETAIL A
TE
CH
C
SIDE VIEW
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
C
C
E
E1
G
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
E
E1
很抱歉,暂时无法提供与“SLVU2.8S3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.56916
- 50+0.44993
- 150+0.39032
- 500+0.34560
- 3000+0.30986
- 6000+0.29193
- 国内价格
- 10+0.52173
- 100+0.41243
- 600+0.31680
- 1200+0.31205
- 3000+0.28403
