TPSN65220DBVR
WWW.SOT23.COM.TW
Features
Mechanical Characteristics
Ultra low capacitance: 50 pF typical
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Up to 4 data lines and one power line protects
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±20kV
Contact discharge: ±20kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) : 5 A(8/20μs)
ROHS Compliant
Applications
3000
Reel Size
7”
PU
Qty per Reel
CH
TPSN65220DBVR
USB 2.0 and USB 3.0 Ports
USB OTG
Digital video interface(DVI)
Monitor and Flat Panel Displays
PCI Express and Serial SATA Ports
Gigabit Ethernet
IEEE 1394 firewire ports
Consumer products (STB, DVD, DSC, DVC…)
BL
Ordering Information
Part Number
Package: SOT23-6
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
IC
TE
Dimensions and Pin Configuration
1
NC
1
6
A
GND
2
5
GND
NC
3
4
B
1
TPSN65220DBVR
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power(tp=8/20μs)
PPP
100
W
Peak Pulse Current(tp=8/20μs)
IPP
5
A
ESD per IEC 61000−4−2 (Air)
±20
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
IC
Operating Temperature Range
±20
Storage Temperature Range
Tstg
−55 to +150
kV
°C
°C
Symbol
Breakdown Voltage
Reverse Leakage Current
Clamping Voltage
VRWM
VBR
IR
Typ
PU
Reverse Working Voltage
Min
6
CH
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
VC
CJ
TE
Junction Capacitance
2
50
Max
Unit
5
V
Any I/O pin to ground
9
V
IT = 1mA, any I/O pin to ground
0.5
µA
VRWM = 5V, any I/O pin to ground
V
pF
Test Condition
IPP = 5A (8 x 20µs pulse) any I/O pin
to ground
VI=0.4 SIN(4E6nt)+0.5V
TPSN65220DBVR
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
150
Ambient Temperature –TA (ºC)
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPSN65220DBVR
TE
CH
PU
BL
IC
WWW.SOT23.COM.TW
4
很抱歉,暂时无法提供与“TPSN65220DBVR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.69717
- 50+1.34339
- 600+1.00253
- 1200+0.98749
- 3000+0.77245
- 国内价格
- 5+1.73499
- 50+1.37327
- 600+1.02479
- 1200+1.00942
- 3000+0.78968
- 国内价格
- 5+1.91204
- 50+1.51341
- 150+1.34255
- 500+1.12936
- 3000+0.87027
- 6000+0.81324
