CBMV722AS8
CBMV722AS8
    COREBAI(芯佰微)
    SOP-8
    低成本、低噪声、轨到轨输出、双通道运算放大器
CBMV722AS8 数据手册
CBMV721S-CBMV722S-CBMV721-CBMV722-CBMV724 OPERATION INSTRUCTION FEATURES APPLICATIONS  HIGH GAIN BANDWIDTH:10MHz  SENSORS  RAIL-TO-RAIL INPUT AND OUTPUT  PHOTODIODE AMPLIFICATION 0.9mV Typical Vos  ACTIVE FILTERS INPUT VOLTAGE RANGE: -0.1V to +5.6V  TEST EQUIPMENT with Vs = 5.5V  DRIVING A/D CONVERTERS   SUPPLY RANGE: +2.5V to +5.5V  SHUTDOWN: CBMV721S/CBMV722S  SPECIFIED UP TO +125°C  MicroSIZE PACKAGES: SOT23-5, SOT23-6 DESCRIPTION The CBMV72X families of products offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (10MHz) and slew rate of 7V/us. The op-amps are unity gain stable and feature an ultra-low input bias current. The devices are ideal for sensor interfaces, active filters and portable applications. The CBMV721S, CBMV722S include a shutdown mode. Under logic control, the amplifiers can be switched from normal operation to a standby current that is less than 1uA.The CBMV72X families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single or dual power supplies of 2.5V to 5.5V. 1 www.corebai.com CBMV721S-CBMV722S-CBMV721-CBMV722-CBMV724 OPERATION INSTRUCTION PIN CONFIGURATIONS ABSOLUTE MAXIMUM RATINGS (1) Supply Voltage, V+ to V-........................................7.0V (1) Stresses above these ratings may cause Input Terminals, Voltage (2) .... – 0.5 to (V+) + 0.5V permanent damage. Exposure to absolute Current (2)..……..……...…..... ±10mA maximum conditions for extended periods Storage Temperature ……….…..… −65°C to +150°C may degrade device reliability. These are Operating Temperature ……….… −40°C to +125°C stress ratings only, and functional operation Junction Temperature...........................................150°C of the device at these or any other conditions Package Thermal Resistance @ TA = +25°C beyond those specified is not implied. SOT23-5, SOT23-6………………….………..……200°C/W (2) MSOP-10, SOIC-8 ……………..……….…..….... 150°C/W the power-supply rails. Input signals that can SOIC-14, TSSOP-14………….……….………...…100°C/W swing more than 0.5V beyond the supply rails Lead Temperature (Soldering, 10s) ……….......260°C should be current-limited to 10mA or less. Input terminals are diode-clamped to ESD Susceptibility HBM ….......................................................................5000V MM ……………………….........…………………….……….400V 2 www.corebai.com CBMV721S-CBMV722S-CBMV721-CBMV722-CBMV724 OPERATION INSTRUCTION ELECTRICAL CHARACTERISTICS (At TA = +25℃, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) CBMV721S,CBMV722S, PARAMETER CONDITIONS TJ CBMV721,CBMV722, CBMV724 MIN TYP UNIT MAX POWER SUPPLY Vs IQ PSRR Operating Voltage Range 25℃ Quiescent 2.5 25℃ Current/Amplifier 1.15 Power-Supply Rejection Vs=2.5V to 5.5V, 25℃ 75 Ratio Vcm=(V-)+0.5V -40℃ to 125℃ 65 5.5 V 1.4 mA 85 dB INPUT VOS Input Offset Voltage VOS TC Input Offset Voltage Average Drift 25℃ -40℃ to 125℃ 0.5 2.5 2.6 mV uV/℃ IB Input Bias Current 25℃ 1 10 pA Ios Input Offset Current 25℃ 1 10 pA 3 www.corebai.com CBMV721S-CBMV722S-CBMV721-CBMV722-CBMV724 OPERATION INSTRUCTION Vcm CMRR Common-Mode Voltage Range Common-Mode Rejection Ratio Vs= 5.5V 25℃ -0.1 Vs= 5.5V, 25℃ 73 -40℃ to 125℃ 67 25℃ 60 Vcm=-0.1V to 5.6V -40℃ to 125℃ 57 RL=2KΩ, Vo=0.15V 25℃ 86 -40℃ to 125℃ 65 25℃ 90 -40℃ to 125℃ 66 Vcm=-0.1V to 4V Vs= 5.5V, 5.6 V 85 dB 75 OUTPUT to 4.85V AOL Open-Loop Voltage Gain RL=10KΩ,Vo=0.05V to 4.95V Output Swing From Rail Iout RL=2KΩ dB Output Short-Circuit Current 96 52 25℃ RL=10KΩ 95 mV 7 25℃ 70 mA FREQUENCY RESPONSE SR Slew Rate 25℃ 7 V/us GBP Gain-Bandwidth Product 25℃ 10 MHz PM Phase Margin 25℃ 62 ° ts Setting Time,0.1% 0.2 us 0.35 us Overload Recovery Time VIN·Gain≥VS NOISE f=1 KHz 25℃ 9.5 nV/√Hz f=10KHz 25℃ 6.5 nV/√Hz 25℃
CBMV722AS8 价格&库存
很抱歉,暂时无法提供与“CBMV722AS8”相匹配的价格&库存,您可以联系我们找货
CBMV722AS8
  • 1+3.38000
  • 10+3.12000
  • 30+3.06800
