CBM9001A-48AG
CBM9001A-48AG
    COREBAI(芯佰微)
    TQFP-48(7x7)
    嵌入式USB主机/从控制器
CBM9001A-48AG 数据手册
Embedded USB Host/Slave Controller CBM9001A Datasheet Features ■ ■ Functional Description First USB Host/Slave controller for embedded systems in the market with a standard microprocessor bus interface Supports both full speed (12 Mbps) and low speed (1.5 Mbps) USB transfer in both master and slave modes ■ Conforms to USB Specification 1.1 for full- and low speed ■ Operates as a single USB host or slave under software control ■ Automatic detection of either low- or full-speed devices ■ 8-bit bidirectional data, port I/O (DMA supported in slave mode) ■ On-chip SIE and USB transceivers ■ On-chip single root HUB support ■ 256-byte internal SRAM buffer ■ Ping-pong buffers for improved performance ■ Operates from 12 or 48 MHz crystal or oscillator (built-in DPLL) ■ 5 V-tolerant interface ■ ■ ■ The CBM9001A is an Embedded USB Host/Slave Controller capable of communicating in either full speed or low speed. The CBM9001A interfaces to devices such as microprocessors, micro- controllers, DSPs, or directly to a variety of buses such as ISA, PCMCIA, and others. The CBM9001A USB Host Controller conforms to USB Specification 1.1. The CBM9001A incorporates USB Serial Interface functionality along with internal full or low speed transceivers. The CBM9001A supports and operates in USB full speed mode at 12 Mbps, or in low-speed mode at 1.5 Mbps. When in host mode, the CBM9001A is the master and controls the USB bus and the devices that are connected to it. In peripheral mode, otherwise known as a slave device, the CBM9001A operates as a variety of full- or low-speed devices. The CBM9001A data port and microprocessor interface provide an 8-bit data path I/O or DMA bidirectional, with interrupt support to allow easy interface to standard microprocessors or microcontrollers such as Motorola or Intel CPUs and many others. The CBM9001A has 256 bytes of internal RAM, which is used for control registers and data buffers. Suspend/resume, wake up, and low-power modes are supported The available Pb-free package is a 48-pin (CBM9001A) package. All packages operate at 3.3 VDC. The I/O interface logic is 5 V-tolerant. Auto-generation of SOF and CRC5/16 Auto-address increment mode, saves memory READ/WRITE cycles ■ Development kit including source code drivers is available ■ 3.3-V power source, 0.35 micron CMOS technology ■ Available in 48-pin TQFP package Logic Block Diagram Master/Slave Controller INTERRUPT CONTROLLER D + D- SERIAL USB INTERFACE Root HUB ENGINE XCVRS CLOCK GENERATOR INTR 256 Byte RAM BUFFERS & CONTROL REGISTERS DMA Interface PROCESSOR INTERFACE nDRQ nDACK nWR nRD nCS nRST D0-7 X1 专芯发展 • 用芯服务 • 创芯未来 X2 www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Functional Overview DMA Controller (slave mode only) In applications that require transfers of large amount of data, such as scanner interfaces, the CBM9001A provides a DMA interface. This interface supports DMA READ or WRITE transfers to the CBM9001A internal RAM buffer, it is done through the microprocessor data bus via two control lines (nDRQ - Data Request and nDACK - Data Acknowledge), along with the nWR line and controls the data flow into the CBM9001A. The CBM9001A has a count register that allows selection of programmable block sizes for DMA transfer. The control signals, both nDRQ and nDACK, are designed for compatibility with standard DMA interfaces. Data Port, Microprocessor Interface The CBM9001A microprocessor interface provides an 8-bit bidirectional data path along with appropriate control lines to interface to external processors or controllers. Programmed I/O or memory mapped I/O designs are supported through the 8-bit interface, chip select, read and write input strobes, and a single address line, A0. Access to memory and control register space is a simple two step process, requiring an address Write with A0 = ‘0’, followed by a register/memory Read or Write cycle with address line A0 = ‘1’. In addition, a DMA bidirectional interface in slave mode is available with handshake signals such as nDRQ, nDACK, nWR, nRD, nCS and INTRQ. The CBM9001A WRITE or READ operation terminates when either nWR or nCS goes inactive. For devices interfacing to the CBM9001A that deactivate the Chip Select nCS before the Write nWR, the data hold timing must be measured from the nCS and is the same value as specified. Therefore, both Intel®- and Motorola-type CPUs work easily with the CBM9001A without any external glue logic requirements. 专芯发展 • 用芯服务 • 创芯未来 Interrupt Controller The CBM9001A interrupt controller provides a single output signal (INTRQ) that is activated by a number of programmable events that may occur as a result of USB activity. Control and status registers are provided to allow the user to select single or multiple events, which generate an interrupt (assert INTRQ) and let the user view interrupt status. The interrupts are cleared by writing to the Interrupt Status Register. -2- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Auto Address Increment Mode Buffer Memory The CBM9001A supports the auto increment mode to reduce READ and WRITE memory cycles. In this mode, the microcontroller needs to set up the address only once. Whenever any subsequent DATA is accessed, the internal address counter advances to the next address location. The CBM9001A contains 256 bytes of internal memory used for USB data buffers, control registers, and status registers. When in master mode (host mode), the memory is defined where the first 16 bytes are registers and the remaining 240 bytes are used for USB data buffers. When in slave mode (peripheral mode), the first 64 bytes are used for the four endpoint control and status registers along with the various other registers. This leaves 192 bytes of endpoint buffer space for USB data transfers. Auto Address Increment Example. To fill the data buffer that is configured for address 10h, follow these steps: 1. Write 10h to CBM9001A with A0 LOW. This sets the memory address that is used for the next operation. 2. Write the first data byte into address 10h by doing a write operation with A0 HIGH. An example is a Get Descriptor; the first byte that is sent to the device is 80h (bmRequestType) so you would write 80h to address 10h. 3. Now the internal RAM address pointer is set to 11h. So, by doing another write with A0 HIGH, RAM address location 11h is written with the data. Continuing with the Get Descriptor example, a 06h is written to address 11h for the bRequest value. 4. Repeat Step 3 until all the required bytes are written as necessary for a transfer. If auto-increment is not used, you write the address value each time before writing the data as shown in Step 1. The advantage of the auto address increment mode is that it reduces the number of required CBM9001A memory READ/WRITE cycles to move data to/from the device. For example, transferring 64 bytes of data to/from CBM9001A, using auto increment mode, reduces the number of cycles to 1 address WRITE and 64 READ/WRITE data cycles, compared to 64 address writes and 64 data cycles for random access. Access to the registers and data memory is through the 8-bit external microprocessor data bus, in either indexed or direct addressing. Indexed mode uses the Auto Address Increment mode described in Auto Address Increment Mode, where direct addressing is used to READ/WRITE to an individual address. USB transactions are automatically routed to the memory buffer that is configured for that transfer. Control registers are provided so that pointers and block sizes in buffer memory are determined and allocated. Figure 1. Memory Map 16 bytes 240 bytes 0x00 – 0x0F Control and s tatus registers 64 bytes 0x10 – 0xFF USB data buffer 0x00 – 0x39 Cont rol/status registers and endpoint contr ol/status registers 0x40 – 0xFF USB data buffer 192 bytes Host Mode Memory Map Peripheral Mode Memory Map 专芯发展 • 用芯服务 • 创芯未来 -3- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet PLL Clock Generator Figure 3. Optional 12 MHz Crystal Circuit Either a 12-MHz or a 48-MHz external crystal is used with the CBM9001A. Two pins, X1 and X2, are provided to connect a low cost crystal circuit to the device as shown in Figure 2 and Figure 3. Use an external clock source if available in the application instead of the crystal circuit by connecting the source directly to the X1 input pin. When a clock is used, the X2 pin is not connected. X1 X2 Rf 1M When the CM pin is tied to a logic 0, the internal PLL is bypassed so the clock source must meet the timing requirements specified by the USB specification. 100 X1 Figure 2. Full Speed 48 MHz Crystal Circuit 12 MHz , series, 20-pF load X2 X1 Rs Cin Cout 22 pF 22 pF Rf Typical Crystal Requirements 1M The following are examples of ‘typical requirements.’ Note that these specifications are generally found as standard crystal values and are less expensive than custom values. If crystals are used in series circuits, load capacitance is not applicable. Load capacitance of parallel circuits is a requirement. The 48-MHz third overtone crystals require the Cin/Lin filter to guarantee 48-MHz operation. Rs X1 100 48 MHz, series, 20-pF load Cbk 0.01 µF Cin 22 pF Lin 2.2 µH 专芯发展 • 用芯服务 • 创芯未来 Cout 22 pF -4- 12 MHz Crystals: Frequency Tolerance: Operating Temperature Range: Frequency: Frequency Drift over Temperature: ESR (Series Resistance): Load Capacitance: Shunt Capacitance: Drive Level: Operating Mode: ±100 ppm or better 0 °C to 70 °C 12 MHz ± 50 ppm 60 Ω 10 pF min 7 pF max 0.1–0.5 mW fundamental 48 MHz Crystals: Frequency Tolerance: Operating Temperature Range: Frequency: Frequency Drift over Temperature: ESR (Series Resistance): Load Capacitance: Shunt Capacitance: Drive Level: Operating Mode: ±100 ppm or better 0 °C to 70 °C 48 MHz ± 50 ppm 40 Ω 10 pF min 7 pF max 0.1–0.5 mW third overtone www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet USB Transceiver Table 1. CBM9001A Master (Host) Mode Registers The CBM9001A has a built-in transceiver that meets USB Specification 1.1. The transceiver is capable of transmitting and receiving serial data at USB full speed (12 Mbits) and low speed (1.5 Mbits). The driver portion of the transceiver is differential while the receiver section is comprised of a differential receiver and two single-ended receivers. Internally, the transceiver interfaces to the Serial Interface Engine (SIE) logic. Externally, the transceiver connects to the physical layer of the USB. USB-A Host Control Register CBM9001A (hex) Address 00h USB-A Host Base Address 01h USB-A Host Base Length USB-A Host PID, Device Endpoint (Write)/USB Status (Read) 02h USB-A Host Device Address (Write)/Transfer Count (Read) 04h Control Register 1 05h Interrupt Enable Register 06h Reserved Register Reserved USB-B Host Control Register 08h USB-B Host Base Address 09h USB-B Host Base Length USB-B Host PID, Device Endpoint (Write)/USB Status (Read) 0Ah USB-B Host Device Address (Write)/Transfer Count (Read) 0Ch Status Register 0Dh SOF Counter LOW (Write)/HW Revision Register (Read) 0Eh Register Name CBM9001A CBM9001A Registers Operation and control of the CBM9001A is managed through internal registers. When operating in Master/Host mode, the first 16 address locations are defined as register space. In Slave/Peripheral mode, the first 64 bytes are defined as register space. The register definitions vary greatly between each mode of operation and are defined separately in this document (section Table 1 describes Host register definitions, while Table 19 on page 15 describes Slave register definitions). Access to the registers are through the microprocessor interface similar to normal RAM accesses (see “Bus Interface Timing Requirements” on page 26) and provide control and status information for USB transactions. Any write to control register 0FH enables the CBM9001A full features bit. This is an internal bit of the CBM9001A that enables additional features. Table 1 shows the memory map and register mapping of the CBM9001A in master/host mode. 03h 0Bh SOF Counter HIGH and Control Register 2 0Fh Memory Buffer 10H-FFh The registers in the CBM9001A are divided into two major groups. The first group is referred to as USB Control registers. These registers enable and provide status for control of USB transactions and data flow. The second group of registers provides control and status for all other operations. Register Values on Power-up and Reset The following registers initialize to zero on power-up and reset: ■ USB-A/USB-B Host Control Register [00H, 08H] bit 0 only ■ Control Register 1 [05H] ■ USB Address Register [07H] ■ Current Data Set/Hardware Revision/SOF Counter LOW Register [0EH] All other register’s power-up and reset in an unknown state and firmware for initialization. 专芯发展 • 用芯服务 • 创芯未来 -5- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet USB Control Registers Communication and data flow on the USB bus uses the CBM9001A’ USB A-B Control registers. The CBM9001A communi- cates with any USB Device function and any specific endpoint via the USB-A or USB-B register sets. Table 2. CBM9001A Host Control Registers Register Name CBM9001A The USB A-B Host Control registers are used in an overlapped configuration to manage traffic on the USB bus. The USB Host Control register also provides a means to interrupt an external CPU or microcontroller when one of the USB protocol transactions is completed. Table 1 and Table 2 show the two sets of USB Host Control registers, the ’A’ set and ’B’ set. The two register sets allow for overlapping operation. When one set of parameters is being set up, the other is transferring. On completion of a transfer to an endpoint, the next operation is controlled by the other register set. Note The USB-B register set is used only when CBM9001A mode is enabled by initializing register 0FH. The CBM9001A USB Host Control has two groups of five registers each which map in the CBM9001A memory space. These registers are defined in the following tables. 专芯发展 • 用芯服务 • 创芯未来 -6- CBM9001A (hex) Address USB-A Host Control Register 00h USB-A Host Base Address 01h USB-A Host Base Length USB-A Host PID, Device Endpoint (Write)/USB Status (Read) 02h USB-A Host Device Address (Write)/Transfer Count (Read) 04h USB-B Host Control Register 08h 03h USB-B Host Base Address 09h USB-B Host Base Length USB-B Host PID, Device Endpoint (Write)/USB Status (Read) 0Ah USB-B Host Device Address (Write)/Transfer Count (Read) 0Ch 0Bh www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet USB-A/USB-B Host Control Registers [Address = 00h, 08h] . Table 3. USB-A/USB-B Host Control Register Definition [Address 00h, 08h] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Preamble Data Toggle Bit SyncSOF ISO Reserved Direction Enable Arm Bit Position 7 Bit Name Preamble Function If bit = ‘1’ a preamble token is transmitted before transfer of low speed packet. If bit = ‘0’, preamble generation is disabled. ■ The CBM9001A automatically generates preamble packets when bit 7 is set. This bit is only used to send packets to a low speed device through a hub. To communicate to a full speed device, this bit is set to ‘0’. For example, when CBM9001A communicates to a low speed device via the HUB: — Set CBM9001A SIE to operate at full speed, i.e., bit 5 of register 05h (Control Register 1) = ‘0’. — Set bit 6 of register 0Fh (Control Register 2) = ‘0’. Set correct polarity of DATA+ and DATA– state for full speed. — Set bit 7, Preamble bit, = ‘1’ in the Host Control register. ■ When CBM9001A communicates directly to a low speed device: — Set bit 5 of register 05h (Control Register 1) = ‘1’. — Set bit 6 of register 0Fh (Control Register 2) = ‘1’, DATA+ and DATA– polarity for low speed. — The state of bit 7 is ignored in this mode. ’0’ if DATA0, ‘1’ if DATA1 (only used for OUT tokens in host mode). 6 Data Toggle Bit 5 SyncSOF 4 ISO ’1’ = Synchronize with the SOF transfer when operating in FS only. The CBM9001A uses bit 5 to enable transfer of a data packet after a SOF packet is transmitted. When bit 5 = ‘1’, the next enabled packet is sent after next SOF. If bit 5 = ‘0’ the next packet is sent immediately if the SIE is free. If operating in low speed, do not set this bit. When set to ‘1’, this bit allows Isochronous mode for this packet. 3 Reserved Bit 3 is reserved for future use. 2 Direction 1 Enable When equal to ‘1’ transmit (OUT). When equal to ‘0’ receive (IN). If Enable = ‘1’, this bit allows transfers to occur. If Enable = ‘0’, USB transactions are ignored. The Enable bit is used in conjunction with the Arm bit (bit 0 of this register) for USB transfers. 0 Arm Allows enabled transfers when Arm = ‘1’. Cleared to ‘0’ when transfer is complete (when Done Interrupt is asserted). Once the other CBM9001A Control registers are configured (registers 01h-04h or 09h-0Ch) the Host Control register is programmed to initiate the USB transfer. This register initiates the transfer when the Enable and Arm bit are set as described above. USB-A/USB-B Host Base Address [Address = 01h, 09h] . Table 4. USB-A/USB-B Host Base Address Definition [Address 01h, 09h] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 HBADD7 HBADD6 HBADD5 HBADD4 HBADD3 HBADD2 HBADD1 HBADD0 The USB-A/B Base Address is a pointer to the CBM9001A memory buffer location for USB reads and writes. When transferring data OUT (Host to Device), the USB-A and USB-B Host Base Address registers can be set up before setting ARM on the USB-A or USB-B Host Control register. When using a double buffer scheme, the Host Base Address could be set up with the first buffer used for DATA0 data and the other for DATA1 data. 专芯发展 • 用芯服务 • 创芯未来 -7- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet USB-A/USB-B Host Base Length [Address = 02h, 0Ah]. Table 5. USB-A / USB-B Host Base Length Definition [Address 02h, 0Ah] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 HBL7 HBL6 HBL5 HBL4 HBL3 HBL2 HBL1 HBL0 The USB A/B Host Base Length register contains the maximum packet size transferred between the CBM9001A and a slave USB peripheral. Essentially, this designates the largest packet size that is transferred by the CBM9001A. Base Length designates the size of data packet sent or received. For example, in full speed BULK mode, the maximum packet length is 64 bytes. In ISO mode, the maximum packet length is 1023 bytes since the CBM9001A only has an 8-bit length; the maximum packet size for the ISO mode using the CBM9001A is 255 – 16 bytes (register space). When the Host Base length register is set to zero, a Zero-Length packet is transmitted. USB-A/USB-B USB Packet Status (Read) and Host PID, Device Endpoint (Write) [Address = 03h, 0Bh]. This register has two modes dependent on whether it is read or written. When read, this register provides packet status and contains information relative to the last packet that has been received or transmitted. This register is not valid for reading until after the Done interrupt occurs, which causes the register to update. Table 6. USB-A/USB-B USB Packet Status Register Definition when READ [Address 03h, 0Bh] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 STALL NAK Overflow Setup Sequence Time-out Error ACK Bit Position Bit Name Function 7 STALL Slave device returned a STALL. 6 NAK 5 Overflow Slave device returned a NAK. Overflow condition - maximum length exceeded during receives. For underflow, see USB-A/USB-B Host Transfer Count Register (Read), USB Address (Write) [Address = 04h, 0Ch]. 4 Setup This bit is not applicable for Host operation since a SETUP packet is generated by the host. 3 Sequence Sequence bit. ‘0’ if DATA0, ‘1’ if DATA1. 2 Time-out Timeout occurred. A timeout is defined as 18-bit times without a device response (in full speed). 1 Error Error detected in transmission. This includes CRC5, CRC16, and PID errors. 0 ACK Transmission Acknowledge. When written, this register provides the PID and Endpoint information to the USB SIE engine used in the next transaction. All 16 Endpoints can be addressed by the CBM9001A. Table 7. USB-A / USB-B Host PID and Device Endpoint Register when WRITTEN [Address 03h, 0Bh] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PID3 PID2 PID1 PID0 EP3 EP2 EP1 EP0 PID[3:0]: 4-bit PID Field (See following table), EP[3:0]: 4-bit Endpoint Value in Binary. PID TYPE D7–D4 SETUP 1101 (D Hex) IN 1001 (9 Hex) OUT 0001 (1 Hex) SOF 0101 (5 Hex) PREAMBLE 1100 (C Hex) NAK 1010 (A Hex) STALL 1110 (E Hex) DATA0 0011 (3 Hex) DATA1 1011 (B Hex) 专芯发展 • 用芯服务 • 创芯未来 -8- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet USB-A/USB-B Host Transfer Count Register (Read), USB Address (Write) [Address = 04h, 0Ch]. This register has two different functions depending on whether it is read or written. When read, this register contains the number of bytes remaining (from Host Base Length value) after a packet is transferred. For example, if the Base Length register is set to 0x040 and an IN Token was sent to the peripheral device. If, after the transfer is complete, the value of the Host Transfer Count is 0x10, the number of bytes actually transferred is 0x30. This is considered as an underflow indication. Table 8. USB-A / USB-B Host Transfer Count Register when READ [Address 04h, 0Ch] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 HTC7 HTC6 HTC5 HTC4 HTC3 HTC2 HTC1 HTC0 When written, this register contains the USB Device Address with which the Host communicates. Table 9. USB-A / USB-B USB Address when WRITTEN [Address 04h, 0Ch] Bit 7 Bit 6 Bit 5 Bit 4 Bit3 Bit 2 Bit 1 Bit 0 0 DA6 DA5 DA4 DA3 DA2 DA1 DA0 DA6-DA0 Device address, up to 127 devices can be addressed. DA7 Reserved bit must be set to zero. CBM9001A Control Registers The next set of registers are the Control registers and control more of the operation of the chip instead of USB packet type of transfers. Table 10 is a summary of the control registers. Table 10. Control Registers Summary Control Register 1 Register Name CBM9001A CBM9001A (hex) Address 05h Interrupt Enable Register 06h Reserved Register 07h Status Register 0Dh SOF Counter LOW (Write)/HW Revision Register (Read) 0Eh SOF Counter HIGH and Control Register 2 0Fh Memory Buffer 专芯发展 • 用芯服务 • 创芯未来 10h-FFh -9- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Control Register 1 [Address = 05h]. The Control Register 1 enables/disables USB transfer operation with control bits defined as follows. Table 11. Control Register 1 [Address 05h] Bit 7 Bit 6 Bit 5 Reserved Suspend USB Speed Bit Position Bit 4 Bit 3 J-K state force USB Engine Reset Bit Name Bit 2 Bit 1 Bit 0 Reserved Reserved SOF ena/dis Function 7 Reserved ‘0’ 6 Suspend ’1’ = enable, ‘0’ = disable. 5 USB Speed ’0’ setup for full speed, ‘1’ setup low speed. 4 J-K state force See Table 12. 3 USB Engine Reset USB Engine reset = ‘1’. Normal set ‘0’. When a device is detected, the first thing that to do is to send it a USB Reset to force it into its default address of zero. The USB 2.0 specification states that for a root hub a device must be reset for a minimum of 50 mS. 2 Reserved Some existing firmware examples set bit 2, but it is not necessary. 1 Reserved ‘0’ 0 SOF ena/dis ’1’ = enable auto Hardware SOF generation; ‘0’ = disable. In the CBM9001A, bit 0 is used to enable hardware SOF auto-generation. The generation of SOFs continues when set to ‘0’, but SOF tokens are not output to USB. At power-up this register is cleared to all zeros. There are two cases when communicating with a low speed device. When a low speed device is connected directly to the CBM9001A, bit 5 of Register 05h is set to ‘1’ and bit 6 of register 0Fh, Polarity Swap, is set to ‘1’ in order to change the polarity of D+ and D–. When a low speed device is connected via a HUB to CBM9001A, bit 5 of Register 05h is set to ‘0’ and bit 6 of register 0Fh is set to ’0’ in order to keep the polarity of D+ and D– for full speed. In addition, make sure that bit 7 of USB-A/USB-B Host Control registers [00h, 08h] is set to ‘1’ for preamble generation. Low-power Modes [Bit 6 Control Register, Address 05h] When bit 6 (Suspend) is set to ‘1’, the power of the transmit transceiver is turned off, the internal RAM is in suspend mode, and the internal clocks are disabled. Note Any activity on the USB bus (that is, K-State, etc.) resumes normal operation. To resume normal operation from the CPU side, a Data Write cycle (i.e., A0 set HIGH for a Data Write cycle) is done. This is a special case and not a normal direct write where the address is first written and then the data. To resume normal operation from the CPU side, you must do a Data Write cycle only. J-K Programming States [Bits 4 and 3 of Control Register 1, Address 05h] The J-K force state control and USB Engine Reset bits are used to generate a USB reset condition. Forcing K-state is used for Peripheral device remote wake up, resume, and other modes. These two bits are set to zero on power-up. Low Speed/Full Speed Modes [Bit 5 Control Register 1, Address 05h] The CBM9001A is designed to communicate with either full- or low speed devices. At power-up bit 5 is LOW, i.e., for full speed. Table 12. Bus Force States USB Engine Reset J-K Force State 0 0 Normal operating mode 0 1 Force USB Reset, D+ and D– are set LOW (SE0) 1 0 Force J-State, D+ set HIGH, D– set LOW 1 1 Force K-State, D– set HIGH, D+ set LOW Function 专芯发展 • 用芯服务 • 创芯未来 -10- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Interrupt Enable Register [Address = 06h]. The CBM9001A provides an Interrupt Request Output, which is activated for a number of conditions. The Interrupt Enable register allows the user to select conditions that result in an interrupt that is issued to an external CPU through the INTRQ pin. A separate Interrupt Status register reflects the reason for the interrupt. Enabling or disabling these interrupts does not have an effect on whether or not the corresponding bit in the Interrupt Status register is set or cleared; it only determines if the interrupt is routed to the INTRQ pin. The Interrupt Status register is normally used in conjunction with the Interrupt Enable register and can be polled in order to determine the conditions that initiated the interrupt (See the description for the Interrupt Status Register). When a bit is set to ’1’ the corresponding interrupt is enabled. So when the enabled interrupt occurs, the INTRQ pin is asserted. The INTRQ pin is a level interrupt, meaning it is not deasserted until all enabled inter- rupts are cleared. USB Reset Sequence After a device is detected, write 08h to the Control register (05h) to initiate the USB reset, then wait for the USB reset time (root hub should be 50 ms) and additionally some types of devices such as a Forced J-state. Lastly, set the Control register (05h) back to 0h. After the reset is complete, the auto-SOF generation is enabled. SOF Packet Generation The CBM9001A automatically computes the frame number and CRC5 by hardware. No CRC or SOF generation is required by external firmware for the CBM9001A, although it can be done by sending an SOF PID in the Host PID, Device Endpoint register. To enable SOF generation, assuming host mode is configured: 1. Set up the SOF interval in registers 0x0F and 0x0E. 2. Enable the SOF hardware generation in this register by setting bit 0 = ‘1’. 3. Set the Arm bit in the USB-A Host Control register. Table 13. Interrupt Enable Register [Address 06h] Bit 7 Reserved Bit Position Bit 6 Device Detect/Resum e Bit Name Bit 5 Inserted/ Removed Bit 4 Bit 3 Bit 2 SOF Timer Reserved Reserved Bit 1 USB-B DONE Bit 0 USB-A DONE Function 7 Reserved 6 Device Detect/Resume Enable Device Detect/Resume Interrupt. When bit 6 of register 05h (Control Register 1) is equal to ’1’, bit 6 of this register enables the Resume Detect Interrupt. Otherwise, this bit is used to enable Device Detection status as defined in the Interrupt Status register bit definitions. ‘0’ 5 Inserted/Removed Enable Slave Insert/Remove Detection is used to enable/disable the device inserted/removed interrupt. 4 SOF Timer 1 = Enable Interrupt for SOF Timer. This is typically at 1 mS intervals, although the timing is determined by the SOF Counter high/low registers. To use this bit function, bit 0 of register 05h must be enabled and the SOF counter registers 0E hand 0Fh must be initialized. 3 Reserved ‘0’ 2 Reserved ‘0’ 1 USB-B DONE USB-B Done Interrupt (see USB-A Done interrupt). 0 USB-A DONE USB-A Done Interrupt. The Done interrupt is triggered by one of the events that are logged in the USB Packet Status register. The Done interrupt causes the Packet Status register to update. USB Address Register, Reserved, Address [Address = 07h]. This register is reserved for the device USB Address in Slave operation. It should not be written by the user in host mode. Registers 08h-0Ch Host-B registers. Registers 08h-0Ch have the same definition as registers 00h-04h except they apply to Host-B instead of Host-A. 专芯发展 • 用芯服务 • 创芯未来 -11- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Interrupt Status Register, Address [Address = 0Dh]. The Interrupt Status register is a READ/WRITE register providing interrupt status. Interrupts are cleared by writing to this register. To clear a specific interrupt, the register is written with corresponding bit set to ‘1’. Table 14. Interrupt Status Register [Address 0Dh] Bit 7 Bit 6 Bit 5 Device Insert/Remove Detect/Resum e D+ Bit Position Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SOF timer Reserved Reserved USB-B USB-A Bit Name Function 7 D+ Value of the Data+ pin. Bit 7 provides continuous USB Data+ line status. Once it is determined that a device is inserted (as described below) with bits 5 and 6, bit 7 is used to detect if the inserted device is low speed (0) or full speed (1). 6 Device Detect/Resume Device Detect/Resume Interrupt. Bit 6 is shared between Device Detection status and Resume Detection interrupt. When bit-6 of register 05h is set to one, this bit is the Resume detection Interrupt bit. Otherwise, this bit is used to indicate the presence of a device, ‘1’ = device ‘Not present’ and ‘0’ = device ‘Present.’ In this mode, check this bit along with bit 5 to determine whether a device has been inserted or removed. 5 Insert/Remove Device Insert/Remove Detection. Bit 5 is provided to support USB cable insertion/removal for the CBM9001A in host mode. This bit is set when a transition from SE0 to IDLE (device inserted) or from IDLE to SE0 (device removed) occurs on the bus. 4 SOF timer ‘1’ = Interrupt on SOF Timer. 3 Reserved ‘0’ 2 Reserved ‘0’ 1 USB-B USB-B Done Interrupt. (See description in Interrupt Enable Register [address 06h].) 0 USB-A USB-A Done Interrupt. (See description in Interrupt Enable Register [address 06h].) Current Data Set Register/Hardware Revision/SOF Counter LOW [Address = 0Eh]. This register has two modes. Read from this register indicates the current CBM9001A silicon revision. Table 15. Hardware Revision when Read [Address 0Eh] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Hardware Revision Bit Position Bit Name Bit 1 Bit 0 Reserved Function 7-4 Hardware Revision CBM9001A rev1.2 Read = 1H; CBM9001A rev1.5 Read = 2. 3-2 Reserved Read is zero. 1-0 Reserved Reserved for slave. Writing to this register sets up auto generation of SOF to all connected peripherals. This counter is based on the 12 MHz clock and is not dependent on the crystal frequency. To set up a 1 ms timer interval, the software must set up both SOF counter registers to the proper values. Table 16. SOF Counter LOW Address when Written [Address 0Eh] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SOF7 SOF6 SOF5 SOF4 SOF3 SOF2 SOF1 SOF0 Example: To set up SOF for 1 ms interval, SOF counter register 0Eh should be set to E0h. 专芯发展 • 用芯服务 • 创芯未来 -12- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet SOF Counter High/Control Register 2 [Address = 0Fh]. When read, this register returns the value of the SOF counter divided by 64. The software must use this register to determine the available bandwidth in the current frame before initiating any USB transfer. In this way, the user is able to avoid babble conditions on the USB. For example, to determine the available bandwidth left in a frame do the following. Maximum number of clock ticks in 1 ms time frame is 12000 (1 count per 12 MHz clock period, or approximately 84 ns.) The value read back in Register 0FH is the (count × 64) × 84 ns = time remaining in current frame. USB bit time = one 12 MHz period. Value of register 0FH Available bit times left are between BBH 12000 bits to 11968 (187 × 64) bits BAH 11968 bits to 11904 (186 × 64) bits Note: Any write to the 0Fh register clears the internal frame counter. Write register 0Fh at least once after power-up. The internal frame counter is incremented after every SOF timer tick. The internal frame counter is an 11-bit counter, which is used to track the frame number. The frame number is incremented after each timer tick. Its contents are transmitted to the slave every millisecond in a SOF packet. Table 17. SOF High Counter when Read [Address 0Fh] Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 C13 C12 C11 C10 C9 C8 C7 C6 Bit 3 Bit 2 Bit 1 Bit 0 When writing to this register the bits definition are defined as follows. Table 18. Control Register 2 when Written [Address 0Fh] Bit 7 Bit 6 CBM9001A Master/Slave selection CBM9001A D+/D– Data Polarity Swap Bit Position Bit 5 Bit 4 SOF High Counter Register Bit Name Function 7 CBM9001A Master/Slave selection Master = 1, Slave = 0. 6 CBM9001A D+/D– Data Polarity Swap ’1’ = change polarity (low speed) ’0’ = no change of polarity (full speed). Write a value or read it back to SOF High Counter Register. 5-0 SOF High Counter Register Note Any write to Control register 0Fh enables the CBM9001A full features bit. This is an internal bit of the CBM9001A that enables additional features. The USB-B register set is used when CBM9001A full feature bit is enabled. Example. To set up host to generate 1 ms SOF time: The register 0Fh contains the upper 6 bits of the SOF timer. Register 0Eh contains the lower 8 bits of the SOF timer. The timer is based on an internal 12-MHz clock and uses a counter, which counts down to zero from an initial value. To set the timer for 1 ms time, the register 0Eh is loaded with value E0h and register 0Fh (bits 0–5) is loaded with 2Eh. To start the timer, bit 0 of register 05h (Control Register 1) is set to ’1’, which enables 专芯发展 • 用芯服务 • 创芯未来 -13- hardware SOF generation. To load both HIGH and LOW registers with the proper values, the user must follow this sequence: 1. Write E0h to register 0Eh. This sets the lower byte of the SOF counter 2. Write AEh to register 0Fh, AEh configures the part for full speed (no change of polarity) Host with bits 5–0 = 2Eh for upper portion of SOF counter. 3. Enable bit 0 in register 05h. This enables hardware generation of SOF. 4. Set the ARM bit at address 00h. This starts the SOF generation. www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Table 19. CBM9001A Slave Mode Registers Register Name Endpoint specific register addresses EP 0 – A EP 0 - B EP 1 – A EP 1 - B EP 2 - A 08h 10h 18h 20h 01h 09h 11h 19h 21h 29h 31h 0x39 02h 0Ah 12h 1Ah 22h 2Ah 0x32 0x3A 03h 0Bh 13h 1Bh 23h 2Bh 0x33 0x3B 04h 0Ch 14h 1Ch 24h 2Ch 0x34 0x3C EP Control Register 00h EP Base Address Register EP Base Length Register EP Packet Status Register EP Transfer Count Register Register Name 05h Interrupt Status Register 0Dh Interrupt Enable Register USB Address Register 06h Current Data Set Register 0Eh 07h Control Register 2 SOF Low Register (read only) 15h Reserved SOF High Register (read only) 16h Reserved 25h-27h Reserved 17h Reserved 2Dh-2Fh DMA Total Count Low Register 35h DMA Total Count High Register 36h Memory Buffer 30h EP 3 - B 0x38 0Fh 1Dh1Fh 37h 40h–FFh When in slave mode, the registers in the CBM9001A are divided into two major groups. The first group contains Endpoint regis- ters that manage USB control transactions and data flow. The second group contains the USB Registers that provide the con- trol and status information for all other operations. Endpoint Registers Communication and data flow on USB is implemented using endpoints. These uniquely identifiable entities are the terminals of communication flow between a USB host and USB devices. Each USB device is composed of a collection of independently operating endpoints. Each endpoint has a unique identifier, which is the Endpoint Number. For more information, see USB Specification 1.1 section 5.3.1. The CBM9001A supports four endpoints numbered 0–3. Endpoint 0 is the default pipe and is used to initialize and generically manipulate the device to configure the logical device as the Default Control Pipe. It also provides access to the device's configuration information, allows USB status and control access, and supports control transfers. Endpoints 1–3 support Bulk, Isochronous, and Interrupt transfers. Endpoint 3 is supported by DMA. Each endpoint has two sets of registers—the ‘A’ set and the ‘B’ set. This allows overlapped operation where one set of parameters is set up and the other is transferring. Upon completion of a transfer to an endpoint, the ‘next data set’ bit indicates whether set ‘A’ or set ‘B’ is used next. The ‘armed’ bit of the next data set indicates whether the CBM9001A is ready for the next transfer without inter- ruption. 专芯发展 • 用芯服务 • 创芯未来 28h Miscellaneous register addresses Control Register 1 Reserved EP 2 - B EP 3 - A -14- Endpoints 0–3 Register Addresses Each endpoint set has a group of five registers that are mapped within the CBM9001A memory. The register sets have address assignments Endpoint 0–3 Register Addresses as shown in the following table. Table 20. Endpoint 0–3 Register Addresses Endpoint Register Set Endpoint 0 – a Endpoint 0 – b Endpoint 1 – a Endpoint 1 – b Endpoint 2 – a Endpoint 2 – b Endpoint 3 – a Endpoint 3 – b Address (in Hex) 00 - 04 08 - 0C 10 - 14 18 - 1C 20 - 24 28 - 2C 30 - 34 38 - 3C For each endpoint set (starting at address Index = 0), the registers are mapped as shown in the following table. Table 21. Endpoint Register Indices Endpoint Register Sets (for Endpoint n starting at register position Index=0) Index Endpoint n Control Index + 1 Endpoint n Base Address Index + 2 Endpoint n Base Length Index + 3 Endpoint n Packet Status Index + 4 Endpoint n Transfer Count www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Endpoint Control Registers Endpoint n Control Register [Address a = (EP# * 10h), b = (EP# * 10h)+8]. Each endpoint set has a Control register defined as follows: Table 22. Endpoint Control Register [Address EP0a/b:00h/08h, EP1a/b:10h/18h, EP2a/b:20h/28h, EP3a/b:30h/38h] 7 6 5 4 3 2 1 0 Reserved Sequence Send STALL ISO Next Data Set Direction Enable Arm Bit Position Bit Name Function 7 Reserved 6 Sequence Sequence bit. ‘0’ if DATA0, ‘1’ if DATA1. 5 Send STALL When set to ‘1’, sends Stall in response to next request on this endpoint. 4 ISO When set to ‘1’, allows Isochronous mode for this endpoint. 3 Next Data Set '0' if next data set is ‘A’, ‘1’ if next data set is 'B'. 2 Direction When Direction = ‘1’, transmit to Host (IN). When Direction = ‘0’, receive from Host (OUT). 1 Enable When Enable = ‘1’, allows transfers for this endpoint. When set to ‘0’, USB transactions are ignored. If Enable = ‘1’ and Arm = ‘0’, the endpoint returns NAKs to USB transmissions. 0 Arm Allows enabled transfers when set = ‘1’. Clears to ‘0’ when transfer is complete. Endpoint Base Address [Address a = (EP# * 10h)+1, b = (EP# * 10h)+9]]. Pointer to memory buffer location for USB reads and writes. Table 23. Endpoint Base Address Reg [Address; EP0a/b:01h/09h, EP1a/b:11h/19h, EP2a/b:21h/29h, EP3a/b:31h/39h] 7 6 5 4 3 2 1 0 EPxADD7 EPxADD6 EPxADD5 EPxADD4 EPxADD3 EPxADD2 EPxADD1 EPxADD0 Endpoint Base Length [Address a = (EP# * 10h)+2, b = (EP# * 10h)+A]. The Endpoint Base Length is the maximum packet size for IN/OUT transfers with the host. Essentially, this designates the largest packet size that is received by the CBM9001A with an OUT transfer, or it designates the size of the data packet sent to the host for IN transfers. Table 24. Endpoint Base Length Reg [Address EP0a/b:02h/0Ah, EP1a/b:12h/1Ah, EP2a/b:22h/2Ah, EP3a/b:32h/3Ah] 7 6 5 4 3 2 1 0 EPxLEN7 EPxLEN6 EPxLEN5 EPxLEN4 EPxLEN3 EPxLEN2 EPxLEN1 EPxLEN0 专芯发展 • 用芯服务 • 创芯未来 -15- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Endpoint Packet Status [Address a = (EP# * 10h)+3, b = (EP# * 10h)+Bh]. The packet status contains information relative to the packet that is received or transmitted. The register is defined as follows: Table 25. Endpoint Packet Status Reg [Address EP0a/b:03h/0Bh, EP1a/b:13h/1Bh, EP2a/b:23h/2Bh, EP3a/b:33h/3Bh] 7 6 5 4 3 2 1 0 Reserved Reserved Overflow Setup Sequence Time-out Error ACK Bit Position Bit Name Function 7 Reserved Not applicable. 6 Reserved Not applicable. 5 Overflow Overflow condition - maximum length exceeded during receives. This is considered a serious error. The maximum number of bytes that can be received by an endpoint is determined by the Endpoint Base Length register for each endpoint. The Overflow bit is only relevant during OUT Tokens from the host. 4 Setup '1' indicates Setup Packet. If this bit is set, the last packet received was a setup packet. 3 Sequence This bit indicates if the last packet was a DATA0 (0) or DATA1 (1). 2 Time-out This bit is not used in slave mode. 1 Error Error detected in transmission, this includes CRC5/16 and PID errors. 0 ACK Transmission Acknowledge. Endpoint Transfer Count [Address a = (EP# * 10h)+4, b = (EP# * 10h)+Ch]. As a peripheral device, the Endpoint Transfer Count register is only important with OUT tokens (host sending the slave data). When a host sends the peripheral data, the Transfer Count register contains the difference between the Endpoint Base Length and the actual number of bytes received in the last packet. In other words, if the Endpoint Base Length register was set for 64 (40h) bytes and an OUT token was sent to the endpoint that only had 16 (10h) bytes, the Endpoint Transfer Count register has a value of 48 (30h). If more bytes were sent in an OUT token then the Endpoint Base Length register was programmed for, the overflow flag is set in the Endpoint Packet Status register and is considered a serious error. Table 26. Endpoint Transfer Count Reg [Address EP0a/b:04h/0Ch, EP1a/b:14h/1Ch, EP2a/b:24h/2Ch, EP3a/b:34h/3Ch] 7 6 5 4 3 2 1 0 EPxCNT7 EPxCNT6 EPxCNT5 EPxCNT4 EPxCNT3 EPxCNT2 EPxCNT1 EPxCNT0 USB Control Registers The USB Control registers manage communication and data flow on the USB. Each USB device is composed of a collection of independently operating endpoints. Each endpoint has a unique identifier, which is the Endpoint Number. For more details about USB endpoints, refer to the USB Specification 1.1, Section 5.3.1. The Control and Status registers are mapped as follows: Table 27. USB Control Registers Register Name Address (in Hex) Control Register 1 05h Interrupt Enable Register 06h USB Address Register 07h Interrupt Status Register 0Dh Current Data Set Register 0Eh Control Register 2 0Fh SOF Low Byte Register 15h SOF High Byte Register 16h DMA Total Count Low Byte Register 35h DMA Total Count High Byte Register 36h 专芯发展 • 用芯服务 • 创芯未来 -16- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Control Register 1, Address [05h]. The Control register enables or disables USB transfers and DMA operations with control bits. Table 28. Control Register 1 [Address 05h] 7 6 5 4 3 2 1 0 Reserved STBYD SPSEL J-K1 J-K0 DMA Dir DMA Enable USB Enable Bit Position Bit Name Function 7 Reserved Reserved bit - must be set to '0'. 6 STBYD XCVR Power Control. ‘1’ sets XCVR to low power. For normal operation set this bit to ‘0’. Suspend mode is entered if bit 6 = ‘1’ and bit ‘0’ (USB Enable) = ‘0’. 5 SPSEL 4 J-K Force State Speed Select. ‘0’ selects full speed. ‘1’ selects low speed (also see Table 33 on page 20). J-K1 and J-K0 force state control bits are used to generate various USB bus conditions. USB Engine Reset Forcing K-state is used for Peripheral device remote wake-up, Resume, and other modes. These two bits are set to zero on power-up, see Table 12 on page 11 for functions. DMA Transfer Direction. Set equal to ‘1’ for DMA READ cycles from CBM9001A. Set equal DMA Dir to ‘0’ for DMA WRITE cycles. 3 2 1 DMA Enable Enable DMA operation when equal to ‘1’. Disable = ‘0’. DMA is initiated when DMA Count High is written. 0 USB Enable Overall Enable for Transfers. ‘1’ enables and’ ‘0 disables. Set this bit to ‘1’ to enable USB communication. Default at power-up = ‘0’ JK-Force State USB Engine Reset 0 0 Normal operating mode Function 0 1 Force SE0, D+ and D– are set low 1 0 Force K-State, D– set high, D+ set low 1 1 Force J-State, D+ set high, D– set low Interrupt Enable Register, Address [06h] . The CBM9001A provides an Interrupt Request Output that is activated resulting from a number of conditions. The Interrupt Enable register allows the user to select events that generate the Interrupt Request Output assertion. A separate Interrupt Status register is read in order to determine the condition that initiated the interrupt (see the description in section Interrupt Status Register, Address [0Dh]). When a bit is set to ‘1’, the corresponding interrupt is enabled. Setting a bit in the Interrupt Enable register does not effect the Interrupt Status register’s value; it just determines which interrupts are output on INTRQ. Table 29. Interrupt Enable Register [Address: 06h] 7 6 5 4 3 2 1 0 DMA Status USB Reset SOF Received DMA Done Endpoint 3 Done Endpoint 2 Done Endpoint 1 Done Endpoint 0 Done Bit Position Bit Name 7 DMA Status When equal to ‘1’, indicates DMA transfer is in progress. When equal to ‘0’, indicates DMA transfer is complete. 6 USB Reset Enable USB Reset received interrupt when = ‘1’. 5 SOF Received Enable SOF Received Interrupt when = ‘1’. 4 DMA Done Enable DMA done Interrupt when = ‘1’. 3 Endpoint 3 Done Enable Endpoint 3 done Interrupt when = ‘1’. 2 Endpoint 2 Done Enable Endpoint 2 done Interrupt when = ‘1’. 1 Endpoint 1 Done Enable Endpoint 1 done Interrupt when = ‘1’. 0 Endpoint 0 Done Enable Endpoint 0 done Interrupt when = ‘1’. 专芯发展 • 用芯服务 • 创芯未来 Function -17- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet USB Address Register, Address [07h] This register contains the USB Device Address after assignment by USB host during configuration. On power-up or reset, USB Address register is set to Address 00h. After USB configuration and address assignment, the device recognizes only USB transactions directed to the address contained in the USB Address register. Table 30. USB Address Register [Address 07h] 7 6 5 4 3 2 1 0 USBADD7 USBADD6 USBADD5 USBADD4 USBADD3 USBADD2 USBADD1 USBADD0 Interrupt Status Register, Address [0Dh] This read/write register serves as an Interrupt Status register when it is read, and an Interrupt Clear register when it is written. To clear an interrupt, write the register with the appropriate bit set to ‘1’. Writing a ‘0’ has no effect on the status. Table 31. Interrupt Status Register [Address 0Dh] 7 6 5 4 DMA Status USB Reset SOF Received DMA Done 3 Endpoint 3 Done 2 Endpoint 2 Done 1 Endpoint 1 Done 0 Endpoint 0 Done Bit Position Bit Name 7 DMA Status Function When equal to ‘1’, indicates DMA transfer is in progress. When equal to 0, indicates DMA transfer is complete. An interrupt is not generated when DMA is complete. 6 USB Reset USB Reset Received Interrupt. 5 SOF Received SOF Received Interrupt. 4 DMA Done DMA Done Interrupt. 3 Endpoint 3 Done Endpoint 3 Done Interrupt. 2 Endpoint 2 Done Endpoint 2 Done Interrupt. 1 Endpoint 1 Done Endpoint 1 Done Interrupt. 0 Endpoint 0 Done Endpoint 0 Done Interrupt. Current Data Set Register, Address [0Eh]. This register indicates current selected data set for each endpoint. Table 32. Current Data Set Register [Address 0Eh] 7 6 5 Reserved Bit Position 7–4 Bit Name 4 3 2 1 0 Endpoint 3 Endpoint 2 Endpoint 1 Endpoint 0 Function Reserved Not applicable. 3 Endpoint 3 Done Endpoint 3a = 0, Endpoint 3b = 1. 2 Endpoint 2 Done Endpoint 2a = 0, Endpoint 2b = 1. 1 Endpoint 1 Done Endpoint 1a = 0, Endpoint 1b = 1. 0 Endpoint 0 Done Endpoint 0a = 0, Endpoint 0b = 1. 专芯发展 • 用芯服务 • 创芯未来 -18- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Control Register 2, Address [0Fh]. Control Register 2 is used to control if the device is configured as a master or a slave. It can change the polarity of the Data+ and Data- pins to accommodate both full- and low speed operation. Table 33. Control Register 2 [Address 0Fh] Bit 7 Bit 6 CBM9001A Master/Slave selection CBM9001A D+/D– Data Polarity Swap Bit 5 Bit 4 Bit 3 Bit Position Bit Name Function 7 CBM9001A Master/Slave selection Master = ‘1’ Slave = ‘0’ 6 CBM9001A D+/D– ’1’ = change polarity (low speed) Data Polarity Swap ’0’ = no change of polarity (full speed) Reserved NA 5–0 Bit 2 Bit 1 Bit 0 Reserved SOF Low Register, Address [15h]. Read only register contains the 7 low order bits of Frame Number in positions: bit 7:1. Bit 0 is undefined. Register is updated when a SOF packet is received. Do not write to this register. transferred between a peripheral to the CBM9001A. The count may sometimes require up to 16 bits, therefore the count is represented in two registers: Total Count Low and Total Count High. EP3 is only supported with DMA operation. SOF High Register, Address [16h]. Read only register contains the 4 low order bits of Frame Number in positions: bit 7:4. Bits 3:0 are undefined and should be masked when read by the user. This register is updated when a SOF packet is received. The user should not write to this register. DMA Total Count High Register, Address [36h]. The DMA Total Count High register contains the high order 8 bits of DMA count. When written, this register enables DMA if the DMA Enable bit is set in Control Register 1. The user should always write Low Count register first, followed by a write to High Count register, even if high count is 00h. DMA Total Count Low Register, Address [35h]. The DMA Total Count Low register contains the low order 8 bits of DMA count. DMA total count is the total number of bytes to be 专芯发展 • 用芯服务 • 创芯未来 -19- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Physical Connections These parts are offered in 48-pin TQFP package. The 48-pin TQFP package is the CBM9001A. 48-Pin TQFP Physical Connections 48-Pin TQFP Pin Layout Figure 4. 48-pin TQFP USB Host/Slave Controller Pin Layout NC NC NC NC nDACK* VDD D7 nRD NC nDRQ* A0 M/S 37 1 36 48 NC NC NC NC nWR NC nCS D6 CM D5 48-Pin TQFP VDD1 Data+ D4 GND Data- D3 USBGnd D2 NC D1 NC NC 12 NC 24 13 NC NC nRST GND Clk/X1 D0 VDD INTRQ X2 NC NC 25 NC NC *See Table 34 for Pin and Signal Description for Pins 43 and 44 in Host Mode. The diagram below illustrates a simple +3.3 V voltage source. Figure 5. Sample VDD Generator +5V (USB) R1 45 Ohms 2N2222 Zener 3.9v, 1N52288CTGND +3.3 V (VDD) Sample VDD Generator Note NC. Indicates No Connection. NC Pins must be left unconnected. 专芯发展 • 用芯服务 • 创芯未来 -20- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet USB Host Controller Pins Description The CBM9001A is packaged in a 48-pin TQFP. These devices require a 3.3 VDC power source and an external 12 or 48 MHz crystal or clock. . Table 34. Pin and Signal Description for Pins 48-Pin TQFP Pin No. 1 Pin Type Pin Name Pin Description NC NC No connection. 2 NC NC 3 IN nWR No connection. Write Strobe Input. An active LOW input used with nCS to write to registers/data memory. 4 IN nCS Active LOW 48-Pin TQFP Chip select. Used with nRD and nWr when accessing the 48-Pin TQFP. Clock Multiply. Select 12 MHz/48 MHz Clock Source. 5 IN CM 6 VDD1 +3.3 VDC 7 BIDIR DATA + Power for USB Transceivers. VDD1 may be connected to VDD. USB Differential Data Signal HIGH Side. 8 BIDIR DATA - USB Differential Data Signal LOW Side. 9 GND USB GND 10 NC NC Ground Connection for USB. No connection. 11 NC NC No connection. 12 NC NC No connection. 13 NC NC No connection. No connection. 14 NC NC 15 VDD +3.3 VDC 16 IN CLK/X1 17 OUT X2 18 IN nRST Device active low reset input. 19 OUT INTRQ Active HIGH Interrupt Request output to external controller. 20 GND GND 21 BIDIR D0 Data 0. Microprocessor Data/Address Bus. 22 NC NC No connection. 23 NC NC No connection. 24 NC NC No connection. 25 NC NC No connection. 26 NC NC No connection. 27 BIDIR D1 Data 1. Microprocessor Data/Address Bus. 28 BIDIR D2 Data 2. Microprocessor Data/Address Bus. 29 BIDIR D3 Data 3. Microprocessor Data/Address Bus. 30 GND GND 31 BIDIR D4 Data 4. Microprocessor Data/Address Bus. 32 BIDIR D5 Data 5. Microprocessor Data/Address Bus. Device VDD Power. Clock or External Crystal X1 connection. The X1/X2 Clock requires external 12 or 48 MHz matching crystal or clock source. External Crystal X2 connection. Device Ground. Device Ground. Notes 1. The CM Clock Multiplier pin must be tied HIGH for a 12 MHz clock source and tied to ground for a 48 MHz clock source. 2. VDD can be derived from the USB supply. See Figure 5. 专芯发展 • 用芯服务 • 创芯未来 -21- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Table 34. Pin and Signal Description for Pins 48-Pin TQFP Pin No. 33 Pin Type Pin Name Pin Description BIDIR D6 Data 6. Microprocessor Data/Address Bus. 34 NC NC No connection. 35 NC NC No connection. 36 NC NC No connection. 37 NC NC No connection. 38 NC NC No connection. 39 BIDIR D7 Data 7. Microprocessor Data/Address Bus. 40 IN M/S Master/Slave Mode Select. ‘1’ selects Slave. ‘0’ = Master. 41 VDD +3.3 VDC 42 IN A0 43 IN nDACK DMA Acknowledge. An active LOW input used to interface to an external DMA controller. DMA is enabled only in slave mode. In host mode, the pin should be tied HIGH (logic ‘1’). 44 OUT nDRQ DMA Request. An active LOW output used with an external DMA controller. nDRQ and nDACK form the handshake for DMA data transfers. In host mode, leave the pin unconnected. 45 IN nRD Read Strobe Input. An active LOW input used with nCS to read registers/data memory. 46 NC NC No connection. 47 NC NC No connection. 48 NC NC No connection. Device VDD Power. A0 = ‘0’. Selects address pointer. Register A0 = ‘1’. Selects data buffer or register. Notes 3. VDD can be derived from the USB supply. Figure 5 shows a simple method to provide 3.3 V/30 mA. Another option is to use a Torex Semiconductor, Ltd. 3.3 V SMD regulator (part number XC62HR3302MR). 4. The A0 Address bit is used to access address register or data registers in I/O Mapped or Memory Mapped applications. 专芯发展 • 用芯服务 • 创芯未来 -22- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Electrical Specifications Absolute Maximum Ratings This section lists the absolute maximum ratings of the CBM9001A. Exceeding maximum ratings may shorten the useful life of the device. User guidelines are not tested. Description Condition Storage Temperature –40 °C to 125 °C Voltage on any pin with respect to ground –0.3 V to 6.0 V Power Supply Voltage (VDD) 4.0 V Power Supply Voltage (VDD1) Lead Temperature (10 seconds) 180°C 4.0 V Recommended Operating Conditions Min Typical Max Power Supply Voltage, VDD Parameter 3.0 V 3.3 V 3.45 V Power Supply Voltage, VDD1 3.0 V 3.45 V Operating Temperature 0 °C 65 °C Crystal Requirements, (X1, X2) Operating Temperature Range Min Typical 0°C Parallel Resonant Frequency Max 65 °C 48 MHz Frequency Drift over Temperature ±50 ppm Accuracy of Adjustment ±30 ppm Series Resistance 100 Ohms Shunt Capacitance 3 pF Load Capacitance 6 pF 20 pF Drive Level 20 µW 5 mW Mode of Vibration Third Overtone[5] External Clock Input Characteristics (X1) Parameter Clock Input Voltage at X1 (X2 Open) Min Typical Max 1.5 V 48 MHz Clock Frequency[6] Notes 5. Fundamental mode for 12 MHz Crystal. 6. The CBM9001A can use a 12 MHz Clock Source. 专芯发展 • 用芯服务 • 创芯未来 -23- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet DC Characteristics Parameter Description Min Typ Max VIL Input Voltage LOW –0.3 V 0.8 V VIH Input Voltage HIGH (5 V Tolerant I/O) 2.0 V 6.0 V VOL Output Voltage LOW (IOL = 4 mA) VOH Output Voltage HIGH (IOH = –4 mA) 2.4 V IOH Output Current HIGH 4 mA IOL Output Current LOW 4 mA ILL Input Leakage 0.4 V ±1 µA CIN Input Capacitance ICC Supply Current (VDD) inc USB at FS 21 mA 25 mA Supply Current (VDD) Suspend w/Clk & Pll Enb 4.2 mA 5 mA Supply Current (VDD) Suspend no Clk & Pll Dis 50 µA 60 µA [7] ICCsus1 ICCsus2 [8] [9] 10 pF IUSB Supply Current (VDD1) 10 mA IUSBSUS Transceiver Supply Current in Suspend 10 µA USB Host Transceiver Characteristics Parameter Description Min Typ[10] Max VIHYS Differential Input Sensitivity (Data+, Data–) 0.2 V 200 mV VUSBIH USB Input Voltage HIGH Driven 2.0 V VUSBIL USB Input Voltage LOW 0.8 V VUSBOH USB Output Voltage HIGH 2.0 V VUSBOL USB Output Voltage LOW 0.0 V 0.3 V ZUSBH [11] Output Impedance HIGH STATE 36 Ohms 42 Ohms ZUSBL[11] Output Impedance LOW STATE 36 Ohms 42 Ohms IUSB Transceiver Supply p-p Current (3.3 V) 10 mA at FS Every VDD pin, including USB VDD, must have a decoupling capacitor to ensure clean VDD (free of high frequency noise) at the chip input point (pin) itself. The best way to do this is to connect a ceramic capacitor (0.1 µF, 6 V) between the pin itself and a good ground. Keep capacitor leads as short as possible. Use surface mount capacitors with the shortest traces possible (the use of a ground plane is strongly recommended). Notes 7. ICC measurement includes USB Transceiver current (IUSB) operating at full speed. 8. ICCsus1 measured with 12 MHz Clock Input and Internal PLL enabled. Suspend set –(USB transceiver and internal Clocking disabled). 9. ICCsus2 measured with external Clock, PLL disabled, and Suspend set. For absolute minimum current consumption, ensure that all inputs to the device are at static logic level. 10. All typical values are VDD = 3.3 V and TAMB= 25°C. 11. ZUSBX impedance values includes an external resistor of 24 Ohms ± 1% (CBM9001A revision 1.2 requires external resistor values of 33 Ohms ±1%). 专芯发展 • 用芯服务 • 创芯未来 -24- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Bus Interface Timing Requirements I/O Write Cycle twrhigh twr nWR twasu twahld twdsu twdhld A0 Register or Memory Address D0-D7 twcsu twdsu twdhld DATA twshld nCS Tcscs See Note. I/O Write Cycle to Register or Memory Buffer Parameter Description Min tWR Write pulse width 85 ns tWCSU Chip select set-up to nWR LOW Chip select hold time After nWR HIGH 0 ns A0 address setup time 85 ns A0 address hold time 10 ns tWDSU tWDHLD Data to Write HIGH set-up time 85 ns Data hold time after Write HIGH 5 ns tCSCS nCS inactive to nCS* asserted 85 ns NWR HIGH 85 ns tWSHLD tWASU tWAHLD tWRHIGH Typ Max 0 ns Note nCS an be held LOW for multiple Write cycles provided nWR is cycled. Write Cycle Time for Auto Inc Mode Writes is 170 ns minimum. 专芯发展 • 用芯服务 • 创芯未来 -25- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet I/O Read Cycle twr twrrdl nWR twasu twahld A0 trdp nRD twdsu twdhld Register or Memory Address D0-D7 tracc trdhld DATA trcsu trshld nCS Tcscs *Note I/O Read Cycle from Register or Memory Buffer Parameter Description Min tWR Write pulse width 85 ns tRD Read pulse width 85 ns tWCSU tWASU Chip select set-up to nWR A0 address set-up time 85 ns tWAHLD A0 address hold time 10 ns tWDSU tWDHLD Data to Write HIGH set-up time 85 ns Data hold time after Write HIGH 5 ns tRACC Data valid after Read LOW 25 ns tRDHLD tRCSU Data hold after Read HIGH 40 ns Chip select LOW to Read LOW 0 ns tRSHLD NCS hold after Read HIGH 0 ns TCSCS* tWRRDL nCS inactive to nCS *asserted 85 ns nWR HIGH to nRD LOW 85ns Typ Max 0 ns 85 ns Note nCS can be kept LOW during multiple Read cycles provided nRD is cycled. Rd Cycle Time for Auto Inc Mode Reads is 170 ns minimum. 专芯发展 • 用芯服务 • 创芯未来 -26- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet DMA Write Cycle tackrq tdakrq nDRQ tdack n DACK tdwrlo D0-D 7 DATA tdsu tdwrp tdhld nW R tackwrh DMA Write Cycle Parameter Description Min tdack nDACK low 80 ns tdwrlo nDACK to nWR low delay 5 ns tdakrq nDACK low to nDRQ high delay 5 ns tdwrp nWR pulse width 65 ns tdhld Data hold after nWR high 5 ns tdsu Data set-up to nWR strobe low 60 ns tackrq NDACK high to nDRQ low 5 ns tackwrh NDACK high to nDRQ low twrcycle DMA Write Cycle Time Typ Max 5 ns 150 ns Note nWR must go low after nDACK goes low in order for nDRQ to clear. If this sequence is not implemented as requested, the next nDRQ is not inserted. 专芯发展 • 用芯服务 • 创芯未来 -27- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet DMA Read Cycle n DRQ tdckdr tdakrq tdack n DACK tddrdlo D0-D 7 DATA tdaccs tdhld tdrdp n RD CBM9001A DMA Read Cycle Timing Parameter Description Min tdack nDACK low tddrdlo nDACK to nRD low delay tdckdr nDACK low to nDRQ high delay 5 ns tdrdp nRD pulse width 90 ns tdhld Date hold after nDACK high 5 ns tddaccs Data access from nDACK low 85 ns tdrdack nRD high to nDACK high 0 ns tdakrq nDRQ low after nDACK high 5 ns trdcycle DMA Read Cycle Time Typ Max 100 ns 0 ns 150 ns Note Data is held until nDACK goes high regardless of state of nREAD. Reset Timing treset nRST tioact nRD or nWR Reset Timing Parameter tRESET tIOACT Description Min nRst Pulse width 16 clocks nRst HIGH to nRD or nWR active 16 clocks Typ Max Note Clock is 48 MHz nominal. 专芯发展 • 用芯服务 • 创芯未来 -28- www. corebai. com Embedded USB Host/Slave Controller CBM9001A Datasheet Clock Timing Specifications tclk tlow CLK thigh tfall trise CLOCK TIMING Clock Timing Parameter Description Min Typ 20.0 ns 20.8 ns tCLK Clock Period (48 MHz) tHIGH Clock HIGH Time 9 ns tLOW tRISE Clock LOW Time 9 ns Clock Rise Time tFALL Clock Fall Time Clock Duty Cycle Max 11 ns 11 ns 5.0 ns 5.0 ns 45% 55% Package Diagram Ordering Information Part Number CBM9001A-48AG 专芯发展 • 用芯服务 • 创芯未来 Package Type 48-pin TQFP (7 × 7 × 1.4 mm) Pb-free -29- – www. corebai. com
CBM9001A-48AG 价格&库存
很抱歉,暂时无法提供与“CBM9001A-48AG”相匹配的价格&库存,您可以联系我们找货
CBM9001A-48AG
  • 1+13.80000
  • 10+13.20000
