CBM2004A
OPERATION INSTRUCTION
Features And Application
500-mA Rated Collector Current (Single Output)
High-Voltage Outputs . . . 50 V
Output Clamp Diodes
Inputs Compatible With Various Types of Logic
Relay Driver Applications
Description
The CBM2004A are monolithic high-voltage, high-current Darlington transistor arrays. Each
consists of seven n-p-n Darlington pairs that feature high-voltage outputs with
common-cathode clamp diodes for switching inductive loads.
The collector-current rating of a single Darlington pair is 500 mA.
The Darlington pairs may be paralleled for higher current capability. Applications include
relay drivers, hammer drivers, lamp drivers, display drivers (LED and gas discharge), line drivers,
and logic buffers.
The CBM2004A has a 10.5kΩ series base resistor for each Darlington pair for operation
directly with 6-15V CMOS devices.
LOGIC SYMBOL
LOGIC DIAGRAM
SCHEMATICS (each Darlington Pair)
CBM2004: RB = 10.5kΩ
All resistor values shown are nominal.
1
www.corebai.com
CBM2004A
Absolute Maximum Ratings (Ta =25℃)
Parameter
Symbol
Values
Unit
50
V
30
V
500
mA
500
mA
-2.5
A
Collector-emitter voltage
Input voltage(see Note 1)
VI
Peak collector current (see Figures 14 and 15)
Output clamp current
IOK
Total emitter-terminal current
Continuous total power dissipation
See Dissipation Rating Table
Operating free-air temperature range
Storage temperature range
TA
–40 to 85
Tstg
–55 to 150
260
Lead temperature 1,6 mm (1/16 inch) from case
for 10 seconds
NOTE 1: All voltage values are with respect to the emitter/substrate terminal E, unless otherwise
noted.
TA=25°C
DERATING FACTOR
TA=85°C
POWER RATING
above TA=25°C
POWER RATING
D
1210mW
7.6mW/℃
494mW
N
1420mW
9.2mW/℃
598mW
PACKAGE
2
www.corebai.com
CBM2004A
Electrical Characteristics, TA= 25℃ (unless otherwise noted)
Symbol
Parameter
Test Fig.
Test Conditions
Min
Typ
Max
Unit
VCE=2V
Vi(on)
VCE(sat)
ICEX
VF
Input Voltage
6
Collector-emitter
Saturation Voltage
Output
Leakage
Current
Clamp Diode Forward
Voltage
5
IC = 125mA
5
IC = 200mA
6
IC = 275mA
7
IC = 350mA
8
IC = 100mA
IB = 250mA
0.9
1.1
IC = 200 mA
IB = 350mA
1.1
1.3
IC = 350 mA
IB = 500mA
1.3
1.6
2
VCE = 50V, Vi = 1V
8
IF = 350mA
Ii(off)
Off-state Input Current
3
Ii
Input Current
4
IR
Clamp Reverse Current
7
Ci
Input Capacitance
VCE=50V, Tamb = 70°C,
IC = 500mA
1.7
50
V
V
500
uA
2
V
65
uA
Vi = 5V
0.35
0.5
Vi = 12V
1
1.45
VR = 50V
50
Tamb = 70°C, VR = 50V
100
mA
uA
15
25
pF
Switching Characteristics, TA=25℃
tPLH
Turn-on Delay Time
See Fig.9
0.25
1
us
tPHL
Turn-off Delay Time
See Fig.9
0.25
1
us
VOH
High level output
voltage after switching
VS=50V, IO=300mA See Fig.10
VS-20
mV
3
www.corebai.com
CBM2004A
PARAMETER MEASUREMENT INFORMATION
4
www.corebai.com
CBM2004A
Figure 9. Propagation Delay-Time Waveforms
Figure 10. Latch-Up Test Circuit and Voltage Waveforms
NOTES: A. The pulse generator has the following characteristics: PRR = 12.5 kHz, ZO=50.
B.
CL includes probe and jig capacitance.
C.
VIH = 12 V;
5
www.corebai.com
CBM2004A
TYPICAL CHARACTERISTICS
COLLECTOR-EMITTER
COLLEC TOR-EM ITTER
SATURATION VOLTAGE
SATURATION VOLTAGE
VS
vs
COLLECTOR CURRENT
TOTAL COLLECTOR CURRENT
(ONE DARLINGTON)
TWO DARLINGTONS PARALLELED)
COLLECTOR CURRENT
vs
INPUT CURRENT
6
www.corebai.com
CBM2004A
THERMAL INFORMATION
D PACKAGE
N PACKAGE
MAXIMUM COLLECTOR CURRENT
Vs
Vs
DUTY CYCLE
DUTY CYCLE
Figure 14
Figure 15
7
www.corebai.com
CBM2004A
APPLICATION INFORMATION
8
www.corebai.com
CBM2004A
Package Dimensions
DIP-16
SYMBOL
MILLIMETER
SYMBOL
MILLIMETER
MIN
MAX
A
18.67
19.69
H
B
6.10
7.11
J
0°
10°
5.33
K
2.92
3.81
C
MIN
MAX
7.62
D
0.36
0.56
L
7.62
8.26
F
1.14
1.78
M
0.20
0.36
N
0.38
G
2.54
NOTES: 1. Dimensions “A”, “B” do not include mold flash or protrusions.
2. Maximum mold flash or protrusions 0.25 mm (0.010) per side.
9
www.corebai.com
CBM2004A
SOP-16
SYMBOL
MILLIMETER
SYMBOL
MILLIMETER
MIN
MAX
A
9.80
10.00
H
B
3.80
4.00
J
0°
8°
C
1.35
1.75
K
0.10
0.25
D
0.33
0.51
M
0.19
0.25
F
0.40
1.27
P
5.80
6.20
R
0.25
0.50
G
1.27
NOTES: 1.
2.
MIN
MAX
5.72
Dimensions A and B do not include mold flash or protrusion.
Maximum mold flash or protrusion 0.15 mm (0.006) per side for A; for B ‑ 0.25 mm (0.010) per
side.
10
www.corebai.com
CBM2004A
PACKAGE/ORDERING INFORMATION
PRODUCT
ORDERING
TEMPRANGE
PACKAGE
PAKEAGE
TRANSPOT
CBM2004
CBM2004AS16
-40℃~85℃
SOP-16
CBM2004AS
Tape and Reel,2500
CBM2004
CBM2004ADP16
-40℃~85℃
DIP-16
CBM2004AD
Tape and Reel,50
11
www.corebai.com
很抱歉,暂时无法提供与“CBM2004AS16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.09088
- 50+1.65629
- 150+1.46999
- 500+1.23758
- 2500+1.13411
- 5000+1.07201
- 国内价格
- 1+1.04000
- 10+0.96000
- 30+0.94400
