CBM706P/706R/706S/706T/708R/708S/708T
OPERATION INSTRUCTION
FEATURES
GENERAL DESCRIPTION
The
Precision supply voltage monitor
2.63 V (CBM706P, CBM706R, CBM708R)
CBM706T
2.93 V (CBM706S, CBM708S)
/CBM708T
CBM706P/CBM706R/CBM706S/
and
the
CBM708R/CBM708S
microprocessor
supervisory
circuits are suitable for monitoring either 3 V
3.08 V (CBM706T, CBM708T)
or 3.3 V power supplies.
100 µA quiescent current
200 ms reset pulse width
Debounced manual reset input (MR)
Independent watchdog timer
power-up,
1.6 sec timeout (CBM706P, CBM706R,
conditions.
The
CBM706S,CBM706T)
operational
with VCC
Voltage monitor for power fail or low
Independent watchdog monitoring circuitry is
The CBM706P/ CBM706R/ CBM706S/
CBM706T provide power supply monitoring
circuitry that generate a reset output during
Guaranteed RESET valid with VCC = 1 V
Superior upgrade for ADM706P/R/S/T,
reset
and
brownout
output
as
low
remains
as
1
V.
also provided. This activates if the watchdog
battery warning
power-down,
input does not toggle within 1.6 sec.
In addition, there is a 1.25 V threshold
detector for a power fail warning, low battery
ADM708R/S/T
detection, or to monitor an additional power
supply. An active low debounced MR input is
APPLICATIONS
also included.
The CBM706R, CBM706S, and CBM706T
Microprocessor systems
Computers
are identical except for the reset threshold
Controllers
monitor levels, which are 2.63 V, 2.93 V, and
Intelligent instruments
Critical microprocessor monitoring
Battery operated systems
Portable instruments
3.08 V, respectively. The CBM706P is identical
to the CBM706R in that the reset threshold is
2.63 V. It differs only in that it has an active
high reset output.
The
provide
CBM708R/CBM708S/CBM708T
similar
functio-nality
as
the
CBM706R/CBM706S/CBM706T and only differ
in that a watchdog timer function is not
available. Instead, an active high reset output
(RESET) is provided in addition to the active
low (RESET) output.
All devices are available in narrow 8-lead
PDIP and 8-lead SOIC packages.
1
www.corebai.com
FUNCTIONAL BLOCK DIAGRAMS
*VOLTAGE REFERENCE = 2.63V (P/R), 2.93V (S), 3.08V (T)
Figure 1. CBM706P/CBM706R/CBM706S/CBM706T
* VOLTAGE REFERENCE = 2.63V (R), 2.93V (S), 3.08V (T)
Figure 2. CBM708R/CBM708S/CBM708T
2
www.corebai.com
SPECIFICATIONS
VCC = 2.70 V to 5.5 V (CBM706P/CBM706R/CBM708R), VCC = 3.00 V to 5.5 V (CBM70XS), VCC =
3.15 V to 5.5 V (CBM70XT), TA = TMIN to TMAX unless otherwise noted.
Table 1.
Parameter
Min
Typ
Max
Unit
Test Conditions/Comments
5.5
V
200
μA
VCC < 3.6 V
150
μA
VCC < 5.5 V
POWER SUPPLY
VCC Operating Voltage Range
1.0
Supply Current
100
LOGIC OUTPUT
Reset Threshold(VRST)
2.55
2.63
2.70
V
2.85
2.93
3.00
V
CBM706S/CBM708S
3.00
3.08
3.15
V
CBM706T/CBM708T
Reset Threshold Hysteresis
RESET PULSE WIDTH
160
mV
200
280
ms
CBM706P/CBM706R/CBM708R,
VCC=3V
VCC = 3.3 V
200
ms
VCC = 5.0 V
RESET OUTPUT VOLTAGE (CBM706R/CBM708R/CBM706S/CBM708S/CBM706T/CBM708T)
VOH
0.8 × VCC
VOL
0.3
VOH
VCC−1.5V
V
VRST(max)
很抱歉,暂时无法提供与“CBM708RAS8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.60000
- 10+2.40000
- 30+2.36000
- 国内价格
- 5+2.24090
- 50+1.80136
- 150+1.61298
- 500+1.34919
- 2500+1.24454
- 5000+1.18175
