CBM232
DATASHEET
GENERAL DESCRIPTION
FEATURES
CBM232 is purposed for application in
Output voltage levels are compatible with
high-performance
input levels of K-MOS, N-MOS and TTL
systems
integrated circuits
Supply voltage : 5V
Low input current: 1.0μA; 0.1μA at Т =
Output current 24mA
Latching current not less than 450mA at Т
Enhanced ESD Specifications:
±15kV
±8kV
devices
of
APPLICATIONS
= 25℃
control
processing
application.
25℃
and
information
IEC61000-4-2 Air Discharge
IEC61000-4-2 Contact Discharge
Computers
Peripherals
Modems
Printers
Instruments
Pin symbols in package
Inputs
Outputs
RIN, TIN
ROVT, TOVT
H
L
L
H
Note:
H – voltage high level;
L – low voltage level
1
www.corebai.com
wide
CBM232
DATASHEET
Table of pin description
Pin No.
Symbol
Pin name
01
C1+
Output of external capacitance of positive voltage multiplier unit
02
V+
Output of positive voltage of multiplier unit
03
C1-
04
C2+
Output of external capacitance of negative voltage multiplier unit
05
C2-
06
V-
Output of negative voltage of multiplier unit
07
T2OUT
Output of transmitter data (levels RS– 232)
08
R2IN
Input of receiver data (levels RS – 232)
09
R2OUT
10
T2IN
Input of transmitter data (levels TTL/KMOS)
11
T1IN
12
R1OUT
13
R1IN
14
T1OUT
Output of transmitter data (levels RS – 232)
15
GND
Common output
16
VCC
Output of receiver data (levels TTL/KMOS)
Supply output of voltage source
Maximum conditions
Symbol
Rate
Parameter
Min
Max
-0.3
6.0
VCC
Supply voltage
V+
Transmitter high output voltage
VCC -0.3
14
V-
Transmitter low output voltage
-0.3
-14
VTIN
Transmitter input voltage
-0.3
V+ +0.3
VRIN
Receiver input voltage
-30
30
842
Unit
V
Dissipated power
PD
DIP – package
SO – package
mW
762
ISC
Output current of transmitter short circuit
Тs
Storage temperature
Continu-ously
mA
-60
150
* Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device.
These are stress ratings only and functional operation of the device at these or any other conditions beyond
those indicated under “recommended operating conditions” is not implied.
Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
2
www.corebai.com
CBM232
DATASHEET
Recommended Operating Conditions
Symbol
Rate
Parameter
Min
Max
Unit
VCC
Supply voltage
4.5
5.5
V+
Transmitter output high voltage
5.0
V-
Transmitter output low voltage
-5.0
VCC
-30
30
±60
mA
-40
125
VTIN
VRIN
ISC
Transmitter short circuit output current
Та
Ambient temperature
V
3
www.corebai.com
CBM232
DATASHEET
Static parameters
Rate
Symbol
ICC
Parameter
Test conditions
Consumption current
VCC =5.0 V
static
VIL = 0 V
-40℃ to 125℃
25℃
Min
Max
Min
Max
10.0
14.0*
0.2
0.9
0.2
1.0
2.4
2.3
0.8
0.9
Unit
mA
Receiver electrical parameters
Vh
VOn
Voff
Hysteresis voltage
VCC =5.0 V
On
VO≤0.1 V
(operation)
voltage
Off (dropout) voltage
IOL≤20uA
VO≥VCC -0.1 V
IOH≤-20uA
V
IOL = 3.2mА
VOL
Output low voltage
VСС = 4.5 V
0.3
0.4
3.6
3.5
3.0
7.0
3.0
7.0
-5.2
5.0
VIH = 2.4 V
IOH = -1.0 mA
VOH
Output high voltage
VСС = 4.5 V
VIL = 0.8 V
RI
Input resistance
VСС = 5.0 V
kOhm
Transmitter electrical parameters
VСС = 4.5V
VOL
Output low voltage
VIH = 2.0V
RL = 3.0kOhm
V
VСС = 4.5V
VOH
Output high voltage
VIL = 0.8V
5.2
5.0
-1.0
-10.0
RL = 3.0kOhm
IIL
IIH
SR
RО
Input low current
Input high current
Speed of output front
change
Output resistance
VСС =5.5V
VIL = 0V
uA
VСС =5.5V
VIH = VСС
1.0
10.0
3.0
30
2.7
27
V/μs
350
300
Ohm
VСС =5.0V
СL=50 - 1000pF
RL=3.0-7.0kOhm
VСС=V+=V-=0V
VO=2V
4
www.corebai.com
CBM232
DATASHEET
VСС =5.5 V
Short
ISC
circuit
output
current
VO = 0 V
VI = VСС
-50
-60
VI = 0 V
50
60
mA
VСС =4.5 V
Speed of information
ST
transmission
СL = 1000 pF
RL = 3.0kOhm
140
120
9.7
10
kbps
tW = 7us (for
extreme -tW = 8us)
Dynamic parameters
VСС = 4.5V
tPHLR
(tPLHR)
Signal propagation
СL = 150pF
delay time when
VIL = 0V
switching on (off)
VIH = 3.0V
tLH = tHL≤10 ns
us
VСС = 4.5V
tPHLT
(tPLHT)
Signal propagation
delay time when
switching on (off)
СL = 2500pF
VIL = 0V
VIH = 3.0 V
5.0*
6.0*
RL = 3kOhm
tLH = tHL≤10 ns
Capacitance
Symbol
Parameter
CIN
Input capacitance
CPD
Dynamic capacitance
VCC,
5.0
Rate
9.0
90
Unit
pF
5
www.corebai.com
CBM232
DATASHEET
Timing diagram when measuring IC dynamic parameters
6
www.corebai.com
CBM232
DATASHEET
7
www.corebai.com
CBM232
DATASHEET
PACKAGE
NOTES: 1. Dimensions A and B do not include mold flash or protrusion.
2.
Maximum mold flash or protrusion 0.15 mm (0.006) per side for A; for B ‑ 0.25 mm
(0.010) per side.
Symbol
Dimensions ,mm
Min
Max
A
9.8
10
B
3.8
4
C
1.35
1.75
D
0.33
0.51
F
0.4
1.27
G
1.27
H
5.72
J
0°
8°
K
0.1
0.25
M
0.19
0.25
P
5.8
6.2
R
0.25
0.5
8
www.corebai.com
CBM232
DATASHEET
PACKAGE/ORDERING INFORMATION
PRODUCT
ORDERING
NUMBER
TEMPRANGE
PACKAGE
PAKEAGE
TRANSPOT
MARKING
MEDIA,QUANTILY
CBM232AS16
-40℃~125℃
SOP-16
CBM232A
Tape and Reel,2500
CBM232ACS16
-0℃~70℃
SOP-16
CBM232AC
Tape and Reel,2500
CBM232
9
www.corebai.com
很抱歉,暂时无法提供与“CBM232AS16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.90000
- 10+3.60000
- 30+3.54000
- 国内价格
- 1+3.60720
- 10+2.90520
- 30+2.55960
- 100+2.20320
- 500+1.99800
- 1000+1.89000
