S3A-S3M
SURFACE MOUNT GENERAL RECTIFIER
SMB/DO-214AA
FEATURES
Plastic package has underwrites laboratory flammability
Classification 94V-0
For surface mounted applications
Low profile package
Built-in strain relief, ideal for automated placement
Glass Passivated chip junction
High temperature soldering:
250℃/10 second at terminals
MECHANICAL DATA
Case: JEDED DO-214AA molded plastic over glass passivated chip
Terminals: Solder plated, Solderable per MIL-STD-750, method 2026
Polarity: Color band denotes cathode end
Weight: 0.007ounce, 0.25 gram
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified
Maximum Repetitive Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
at TL =100℃ (NOTE 3)
Peak Forward Surge Current
8.3ms single half sine wave superimposed on
rated load (JEDEC method) T L=100℃
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
at rated DC Blocking Voltage
TA = 25℃
TA = 125℃
Typical Reverse Recovery Time (NOTE 1)
Typical junction capacitance (NOTE 2)
Typical Thermal Resistance (NOTE 3)
Operating and Storage Temperature Range
SYMBOLS
VRRM
VRMS
VDC
S3A
50
35
50
S3B
100
70
100
S3D
200
140
200
S3G
400
280
400
S3K
800
560
800
S3M
1000
700
1000
UNIT
Volts
Volts
Volts
I(AV)
3.0
Amps
IFSM
100
Amps
VF
Volts
Trr
1.15
10.0
250
2.5
CJ
RθJL
RθJA
TJ,TSTG
60
47
13
-55 to +150
pF
IR
Notes:
1. Reverse recovery test conditions: IF =0.5A, IR =1.0A, Irr =0.25A
2. Measured at 1.0MHz and applied reverse voltage of 4.0 Volts
3. Thermal resistance from Junction to ambient and from junction to lead mounted on
P.C.B.with 0.3×0.3″(8.0 × 8.0mm) copper pad areas.
www.slkormicro.com
S3J
600
420
600
1
µA
µs
℃/W
S3A-S3M
RATINGS AND CHARACTERISTIC
F1G.2-MAXIMUM NON-REPETITIVE PEAK
FORWARD SURGE CURRENT
200
3.5
3.0
2.5
2.0
1.5
1.0
P.C.B MOUNTED on
0.3X0.3″(8.0X8.0mm)
COPPER PAD AREAS
0.5
T L =100℃
CURRENT, AMPERES
Resistive or Inductive Load
PEAK FORWARD SURGE
AVERAGE FORWARD CURRENT
AMPERES
F1G.1-FORWARD CURRENT DERATING CURVE
8.3ms Single Half Sine-Wave
(JEDEC Method)
100
60
70
80
90 100 110 120 130 140 150 160
10
LEAD TEMPERATURE,( ℃)
1
10
100
NUMBER OF CYCLES AT 60Hz
F1G.4-TYPICAL REVERSE
CHARACTERISTICS
100
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD CURRENT, AMPERES
F1G.3-TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
10
T J =25℃
Pulse Width=300us
1% Duty Cycle
1.0
0.1
0.01
0.6
0.7
0.8
0.9
1.0
1.1
1.2
100
TJ =125℃
10
1.0
T J =25℃
0.1
60
80
100
PERCENT OF RATED PEAK
REVERSE VOLTAGE,(%)
1.3
TRANSIENT THERMAL IMPEDANCE(℃ /W)
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
F1G.5-TYPICAL JUNCTION CAPACITANCE
100
T J =25℃
f=1MHz
Vsig=50mVp-p
10
1
1.0
10
100
REVRESE VOLTAGE, VOLTS
www.slkormicro.com
2
F1G.6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
Mounted ON 0.20X0.27″(5X7mm)
COPPER PAD AREAS
10
1
0.1
0.01
0.1
1.0
10
T, PULSE DURATION, SEC.
100
很抱歉,暂时无法提供与“S3M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13392
- 500+0.10563
- 3000+0.08414
- 6000+0.07463
- 24000+0.06642
- 51000+0.06210
- 国内价格
- 5+0.13941
- 20+0.12711
- 100+0.11481
- 500+0.10250
- 1000+0.09676
- 2000+0.09266
