SL9945
SL9945
    SLKOR(萨科微)
    SOIC-8
    Dual N-Channel Vdss:60V Id:3.6A Pd:2.1W SOIC8_150MIL
SL9945 数据手册
SL9945 60V N+N-Channel Enhancement Mode MOSFET N-Channel 60-V (D-S) MOSFET These miniature surface mount MOSFETs utilize a high cell density trench process to provide low rDS(on) and to ensure minimal power loss and heat dissipation. Typical applications are DC-DC converters and power management in portable and battery-powered products such as computers, printers, PCMCIA cards, cellular and cordless telephones. • • • • PRODUCT SUMMARY VDS (V) rDS(on) m(Ω) 89 @ VGS = 10V 60 104 @ VGS = 4.5V Low rDS(on) provides higher efficiency and extends battery life Low thermal impedance copper leadframe SOP-8 saves board space Fast switching speed High performance trench technology TA=25oC Pulsed Drain Current o TA=70 C b 8 2 7 3 6 4 5 TA=25 C o TA=70 C Maximum Junction-to-Ambienta 2.1 Symbol t
SL9945
- 物料型号:SL9945 - 器件简介:微型表面贴装MOSFET,采用高密度沟道工艺,具有低导通电阻(rDS(on)),减少功率损耗和散热。 - 引脚分配:文档中未明确列出,但封装信息显示为SO-8,即8个引脚。 - 参数特性: - 漏源电压(VDS):60V - 栅源电压(VGS):正负20V - 连续漏源电流(ID):最大2A - 工作结温(TJ, Tstg):-55至150摄氏度 - 功率耗散(PD):根据脉冲宽度和热阻不同而变化 - 热阻(RA):最大结到环境热阻125摄氏度/瓦 - 功能详解:适用于DC-DC转换器和便携式、电池供电产品的电源管理,如计算机、打印机、PCMCIA卡、手机和无绳电话。 - 应用信息:文档中未提供具体应用案例,但提到了典型应用场景。 - 封装信息:SO-8封装,8个引脚。
SL9945 价格&库存
很抱歉,暂时无法提供与“SL9945”相匹配的价格&库存,您可以联系我们找货
SL9945
库存:1251
SL9945
  • 5+1.78576
  • 50+1.45730
  • 500+1.04123
  • 1000+1.02561
  • 2500+0.96311
库存:2350
