Multilayer Chip Inductors -YL1608 Series
■ Features
● Monolithc structure for highly reliable surface mount applications.
● Excellent solderability and high heat resistance for either flow or reflow
soldering.
● No cross coupling between inductors due to magnetic shield.Ideal for high
density installation.
● Operating temperature:-40℃ ~ +85℃.
■ Applications
● Prevention of electromagnetic interference to signals on the secondary side of
electric equipment
■ Product Identification
⑴ :Type
⑵ :Dimensions
⑶ :Inductance value
⑷ :Inductance Tolerance;N=±30%,M=±20%,K=±10%
深圳市益嘉源电子有限公司
http://www.yjycoin.com
Tel:0755-27803896
Mob:(86)13682526134
-1-
■ Shapes and Dimensions (Unit:mm)
TYPE
L
W
T
A
YL160808 [0603]
1.60±0.20
0.80±0.20
0.80±0.20
0.30±0.20
■ YL1608 Series
Inductance
Part Number
Test Freq.
Min.SRF
DCR MAX.
Max.Rated
(MHz)
(MHz)
(Ω)
Current (mA)
Q Min.
(uH)
YL160808-47N□
0.047
10
50
260
0.30
50
YL160808-68N□
0.068
10
50
250
0.30
50
YL160808-82N□
0.082
10
50
245
0.30
50
YL160808-R10□
0.100
15
25
240
0.50
50
YL160808-R12□
0.120
15
25
205
0.50
50
YL160808-R15□
0.150
15
25
180
0.60
50
YL160808-R18□
0.180
15
25
165
0.60
50
YL160808-R22□
0.220
15
25
150
0.80
50
YL160808-R27□
0.270
15
25
136
0.80
80
YL160808-R33□
0.330
15
25
125
0.85
35
YL160808-R39□
0.390
15
25
110
1.00
35
YL160808-R47□
0.470
15
25
105
1.35
35
YL160808-R56□
0.560
15
25
95
1.55
35
YL160808-R68□
0.680
15
25
90
1.70
35
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-2-
■ YL1608 Series
Inductance
Part Number
Test Freq.
Min.SRF
DCR MAX.
Max.Rated
(MHz)
(MHz)
(Ω)
Current (mA)
Q Min.
(uH)
YL160808-R82□
0.820
15
25
85
2.10
35
YL160808-1R0□
1.0
35
10
75
0.60
25
YL160808-1R1□
1.1
35
10
75
0.60
25
YL160808-1R2□
1.2
35
10
65
0.80
25
YL160808-1R5□
1.5
35
10
60
0.80
25
YL160808-1R8□
1.8
35
10
55
0.95
25
YL160808-2R2□
2.2
35
10
50
1.15
15
YL160808-2R7□
2.7
35
10
45
1.35
15
YL160808-3R3□
3.3
35
10
40
1.55
15
YL160808-3R9□
3.9
35
10
35
1.70
15
YL160808-4R7□
4.7
35
10
33
2.10
15
YL160808-5R6□
5.6
35
4
22
1.55
5
YL160808-6R8□
6.8
35
4
5
YL160808-8R2□
8.2
35
4
18
2.10
5
YL160808-100□
10
30
2
17
1.85
3
YL160808-120□
12
30
2
15
2.10
3
YL160808-150□
15
14
1.70
1
YL160808-180□
18
13
1.85
1
YL160808-220□
22
11
2.10
1
YL160808-270□
27
10
2.75
1
YL160808-330□
33
9
2.95
1
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-3-
■ Reliability test
Items
Requirements
Test Methods and Remarks
Operating
Temperature
Range
-40℃ to + 85℃
Storage
Temperature
Range
-40℃ to + 85℃
Terminal
Strength
Resistance
to Flexure
No removal or split of the termination
or other defects shall occur
No visible mechanical damage.
①
Solder the inductor to the testing jig(glass epoxy
board shown as the following figure)using eutectic
solder.Then apply a force in the direction of the
arrow.
②
③
④
⑤
⑥
2N force for 0603 series.
5N force for 1005 and 1608 series.
10N force for 2012 3216 3225 4532 series.
Keep time :10±1s.
Speed:1.0mm/s.
①
Solder the inductor to the test jig(glass epoxy
board) using a eutectic solder.Then apply a force in
the direction of the arrow shown as the following
figure.
② Flexure:2mm.
③ Pressurizing Speed:0.5mm/sec.
④ Keep time:≥30 sec.
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-4-
■ Reliability test
Items
Vibration
Requirements
① No visible mechanical damage.
② Inductance change: Within
±10%.
① Solder the inductor to the testing jig using eutectic
solder.
③ Q factor change: Within
±30%.
Dropping
Temperature
Solderability
Resistance
to Soldering
Heat
② Inductance change:Within
±20%.
±30%.
Inductance change should be
within ±20% of initial value
measuring at 20℃.
Drop chip inductor 10 times on a concrete floor from a
height of 100 cm.
Temperature range: -40℃ to +85℃
Reference temperature:+20℃
② Wetting shall exceed 95%
coverage.
① Solder temperature: 240±2℃.
coverage.
① Solder temperature: 260±3℃.
③ Inductance change:Within
±10%.
④ Q factor change: Within
±30%.
Thermal
Shock
② The inductor shall be subjected to a simple
harmonic motion having total amplitude of 1.5 mm, the
frequency being varied uniformly between the
approximate limits of 10 and 55 Hz.
③ The frequency range from 10 to 55 Hz and return to
10 Hz shall be traversed in approximately 1 minute.
This motion shall be applied for a period of 2 hours in
each 3mutually perpendicular directions (total of 6
hours).
±10%.
±30%.
深圳市益嘉源电子有限公司
② Duration: 3 sec.
③ Solder: Sn/3.0Ag/0.5Cu.
④ Flux: 25% Resin and 75% ethanol in weight.
② Duration: 5 sec.
⑤ The chip shall be stabilized at normal condition for
1~2 hours before measuring.
① Temperature and time:
-40℃ for 30±3 min →85℃ for 30±3min.
② Transforming interval: Max.20 sec.
③ Tested cycle: 100 cycles.
④ The chip shall be stabilized at normal condition for
Tel:0755-27803896
Mob:(86)13682526134
-5-
■ Reliability test
Items
Resistance to
Low
Temperature
Requirements
±10%.
±30%.
Resistance to
High
Temperature
±10%.
±30%.
Damp Heat
(Steady
States)
±10%.
±30%.
Loading
Under Damp
Heat
± 10% for inductance ≤12 μH,
Within ± 15% for inductance ≥
15μH.
±30%.
Loading at
High
Temperature
(Life Test)
② Inductance change: Within ±
10% for inductance ≤ 12 μ H,
Within±15% for inductance≥
15μH.
① Temperature: -40±2℃.
② Duration: 1000+24 hours.
③ The chip shall be stabilized at normal condition for
① Temperature: 85±2℃.
①
Temperature: 60±2℃.
② Humidity: 90% to 95% RH.
③ Duration: 1000+24 hours.
①
②
③
④
⑤
Temperature: 60±2℃.
Applied current: Rated current.
①
②
③
④
Temperature: 85±2℃.
±30%.
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-6-
■ Taping Dimensions(Unit:mm)
TYPE
Chip
Thickness
W
A
B
D
P
YL160808
0.80
8.0
1.00
1.80
3.50
4.0
K Max T Max
1.10
0.30
MPQ
4000
■ Reel Dimensions(Unit:mm)
TYPE
W
W1
A
B
C
D
178±2.0
8.40±1.50
4.3±0.20
5.0±0.10
3.0±0.10
58±2.0
178±2.0
12.40±1.50
4.3±0.20
5.0±0.10
3.0±0.10
58±2.0
YL Series
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-7-
■ Leader and Blank portion
1.Missing chips number within 0.1% of the number per reel or 1pcs, whichever is greater, and
are not continuous.
2.The top tape and bottom tape shall not protrude beyond the edges of the tape and shall not
cover sprocket hole.
3.Cumulative tolerance of sprocket holes, 10 pitches: ±0.3mm.
4.Peeling off force: 10gf to 100gf in the direction show below for 8mm carrier tapes and 10gf to
130gf for 12mm to 56mm wide carrier tapes.
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-8-
很抱歉,暂时无法提供与“YL160808-1R0K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.44110
- 200+0.14630
- 2000+0.09185
- 4000+0.07293
- 国内价格
- 20+0.14040
- 200+0.11070
- 600+0.09418
- 4000+0.07928
- 8000+0.07074
- 20000+0.06610
