YLM3216-161T
YLM3216-161T
    YJYCOIN(益嘉源)
    CHOKE_3.2X1.6MM_SM
    共模电感 350mA ±25% 400mΩ 160Ω CHOKE_3.2X1.6MM_SM
YLM3216-161T 数据手册
SMD Common Mode Choke -YLM3216 Series ■ Features ● This filter is characterized by small size, highly effective in noise suppression. ● High common mode impedance at noise band and low differential mode impedance at signal band.Due to the low differential mode impedance with high coupling factor,there is almost no distortion on high speed transmission of high resolution video signals. ■ Applications ● YLM Series is suited for use on the USB2.0 line and IEEE1394 line of Notebook PC,LVDS lines of PC,LCD Monitor, PCI express,small digital AV equipment such as digital Camera and Free disk,MP3 player and Serial-ATA. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Identification Code ⑷ :Impedance ⑸ :Taping 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Mob:(86)13682526134 -1- SMD Common Mode Choke -YLM3216 Series ■ Shapes and Dimensions (Unit:mm) TYPE A B C D E YLM3216 3.2±0.2 1.6±0.2 2.0±0.2 0.50±0.1 F 0.50±0.1 0.50±0.1 G H I J 0.40 1.60 1.60 3.70 ■ YLM3216 Series Common mode DC Rated Impedance Resistance Current (Ω) @100MHz (Ω) Max (mA) max YLM3216□-900T 90±25% 0.30 YLM3216□-121T 120±25% YLM3216□-161T Rated Volt. Withstand IR(MΩ) (Vdc)max. Volt.(Vdc)max. min. 400 50 125 10 0.30 350 50 125 10 160±25% 0.40 350 50 125 10 YLM3216□-221T 220±25% 0.45 300 50 125 10 YLM3216□-261T 260±25% 0.50 300 50 125 10 YLM3216□-361T 360±25% 0.60 300 50 125 10 YLM3216□-601T 600±25% 0.80 300 50 125 10 YLM3216□-102T 1000±25% 1.00 200 50 125 10 YLM3216□-222T 2200±25% 1.20 200 50 125 10 Part Number 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Mob:(86)13682526134 -2- SMD Common Mode Choke -YLM3216 Series ■ Recommended soldering temp.Graph ■ Mechanical reliability ■ Endurance Reliability 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Mob:(86)13682526134 -3- SMD Common Mode Choke -YLM3216 Series ■ Taping Dimensions(Unit:mm) TYPE W A B D P K T MPQ YLM3216 8.0±0.2 1.88±0.1 3.50±0.1 3.5±0.05 4.0±0.1 2.20±0.1 0.26±0.05 2000 ■ Reel Dimensions(Unit:mm) TYPE W W1 A B C D YLM3216 178±2.0 9.00±0.50 4.3±0.20 5.0±0.10 3.0±0.10 60±2.0 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Mob:(86)13682526134 -4- SMD Common Mode Choke -YLM3216 Series ■ Direction of rolling ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Mob:(86)13682526134 -5-
YLM3216-161T 价格&库存
很抱歉,暂时无法提供与“YLM3216-161T”相匹配的价格&库存,您可以联系我们找货
YLM3216-161T
  • 10+0.68000
  • 100+0.62000
  • 500+0.56000
  • 1000+0.50000
  • 2000+0.46000
  • 4000+0.44800
