Wire Wound Common Mode Choke
-YLM4520 Series
■ Features
● SMD construction,and low profile.
● High Impedance and Excelletn Frequency Characteristic.
● Self Electromagnetic Shielding.
● Low Magnetic Flux Leakage.
■ Applications
● LED Light,TV game,Monitor,etc.
● EMI common-mode noise.
■ Product Identification
⑴ :Type
⑵ :Dimensions
⑶ :Impedance
⑷ :Taping
深圳市益嘉源电子有限公司
http://www.yjycoin.com
Tel:0755-27803896
Mob:(86)13682526134
-1-
-YLM4520 Series
■ Shapes and Dimensions (Unit:mm)
TYPE
A
B
C Max
D Typ
E
F
G Typ
YLM4520
4.7±0.5
4.5±0.5
2.0
2.7
0.75±0.2
1.25±0.2
1.0
■ Circuit Diagram
■ YLM4520 Series
Part Number
Z (Ω)
DC
@100MHz/0.1V
Resistance
Rated Current
Rated Volt.
IR(MΩ)
(A) max.
(V)max.
min.
Marking
Min
Typ
(mΩ) Max.
YLM4520-301T
100
300
45
3.0
50
10
301
YLM4520-401T
200
400
50
2.5
50
10
401
YLM4520-701T
500
700
59
2.2
50
10
701
YLM4520-901T
700
900
68
2.1
50
10
901
YLM4520-102T
800
1000
68
2.1
50
10
102
YLM4520-122T
1000
1200
74
2.0
50
10
122
YLM4520-142T
1200
1400
81
1.9
50
10
142
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-2-
-YLM4520 Series
■ Materlal List
NO.
ITEM
DESCRIPTION
SUPPLIER
1
CORE
FERRITE
SINCORES OR EQ
2
WIRE
2UEW P180
PACIFIC OR EQ
3
TAPE
DM TAPE
HENGRENXIN OR EQ
4
SOLDER
Sn Cu
SHENMAO OR EQ
5
INK
Black
BON MARK
■ Reliability Testing
Operating Temperature
- 30 to + 100 ℃ ( Contain Heating coil )
Appearance Inspection
No external defects by visual inspection
Terminal Strength
After soldering , between copper plaet and terminals
of coils , push in two directions of X , Y with
standing 10N(1.02kg) for10+/-2 sec.
Terminal should not peel off. ( Refer to figure at right )
Heat endurance of reflow
Refer to figure
soldering
Insulating resistance
Over 100 MΩ at 100V D.C . between wire and core .
Dielectric Strength
Apply at 0.5KV 3mA for 1 minute between wire and core .
Temperature
Inductance coefficient ( 0~2,000 ) × 10 / ℃( - 30 ~ + 100 ℃ )
characteristics
Humidity characteristics
Inductance deviation within ± 10% , after 96 hours in 90~95%
relative humidity at 40 ± 2 ℃ and 1 hours drying under normal condition .
A test is made under the above mentioned condition , and it is kept for 2 hours in the normal
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-3-
-YLM4520 Series
■ Recommended soldering temp.Graph
■ Taping Dimensions(Unit:mm)
TYPE
W
A
B
D
P
K
T
MPQ
YLM4520
16.0±0.3
6.9±0.3
8.4±0.3
7.5±0.1
12±0.1
4.2±0.1
0.40±0.05
1000
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-4-
-YLM4520 Series
■ Reel Dimensions(Unit:mm)
TYPE
W
W1
A
B
C
D
YLM4520
330±2.0
16.4±2.0
13.0±0.50
21.0±0.80
2.0±0.50
100Min
■ Direction of rolling
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-5-
-YLM4520 Series
■ Cover tape peel off condition
Cover tape peel force shall be 0.1N to 1.3N.
Reference peel speed 300±10mm/min.
深圳市益嘉源电子有限公司
Tel:0755-27803896
Mob:(86)13682526134
-6-
很抱歉,暂时无法提供与“YLM4520-701T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.32972
- 10+3.48840
- 30+3.06774
- 100+2.64708
- 500+2.39058
- 1000+2.26746
- 国内价格
- 1+2.60000
- 10+2.40000
- 30+2.36000
