X503225MSB4SI
X503225MSB4SI
    YXC(扬兴科技)
    SMD5032_4P
    无源晶振 25MHz ±10ppm 20pF -40℃~+85℃
X503225MSB4SI 数据手册
CRYSTAL UNIT YSX531SL Applications Features ‧Industrial Control Consumers. ‧Dimensions:5.00 x 3.20 x 0.90 mm. ‧High precision and high frequency stability. ‧Standard Frequency: 8~54MHz ‧Extremely good for reducing EMI effect. Specifications Standard Frequency 8~54 MHz Vibration Mode AT Fundamental Load Capacitance 10pF,20pF,or specify Frequency Tolerance (at 25 ) ±10ppm,±20ppm,or specify Frequency Versus Temperature Characteristics Operating Temperature ±20ppm,or specify -20~+70℃,-40~+85℃,or specify Storage Temperature -55~+125℃ or specify Shunt Capacitance 5 pF Max. Level of Drive 1~200μWMax.(100uW typical) Aging (at 25 ℃ ) ±3ppm/year Max. Equivalent Series Resistance(ESR) 8 ~ 12MHz 12 ~ 25 MHz 25 ~ 54 MHz Fundamental Dimensions and Patterns [unit:mm] 60~80 Ω Max. 40~60 Ω Max. 30~40 Ω Max. Package Size – Dimensions (Unit: mm) www.yxc.hk 第1页共2页 CRYSTAL UNIT YSX531SL Reflow Soldering Profile Temperature Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C Heating Temperature TMlt = + 220 °C Peek Temperature TMax. = + 260 °C +260℃ TMax. +220℃ Tmlt Point of measuring In case of Solder ability Terminal. In case of Resistance to soldering heat Surface. Tp2 Tp1 35s 100s t(time) Taping Specification(Unit: mm) Size A B C D E F G H SMD-5032 180±2.0 12.0±0.3 5.40±0.1 3.60±0.1 8.00±0.3 1.45±0.1 61.0±1.0 12.0±1.0 1000 pcs per reel www.yxc.hk 第2页共2页
X503225MSB4SI 价格&库存
很抱歉,暂时无法提供与“X503225MSB4SI”相匹配的价格&库存,您可以联系我们找货
X503225MSB4SI
  • 5+2.17318
  • 50+1.74431
  • 150+1.56050
  • 1000+1.22883
  • 2000+1.12666
库存:4319
X503225MSB4SI
  • 10+3.13270
  • 100+1.86870
  • 500+1.30810
  • 1000+0.93440
  • 2000+0.88770
  • 10000+0.82220
X503225MSB4SI
  • 1+1.04520
  • 30+1.00620
  • 100+0.96720
  • 500+0.88920
  • 1000+0.85020
  • 2000+0.82680
库存:2217
X503225MSB4SI
  • 5+2.14320
  • 50+1.71810
  • 150+1.53530
  • 1000+1.20620
  • 2000+1.10430
  • 5000+1.04430
库存:166
X503225MSB4SI
  • 1+1.10210
  • 50+0.84769
  • 1000+0.78074
库存:1647
X503225MSB4SI
库存:2030
X503225MSB4SI
  • 5+1.97196
  • 50+1.58280
  • 200+1.41600
  • 400+1.39476
  • 1000+1.11504
库存:1001
