CRYSTAL UNIT
YSX531SL
Applications
Features
‧Industrial Control
Consumers.
‧Dimensions:5.00 x 3.20 x 0.90 mm.
‧High precision and high frequency stability.
‧Standard Frequency: 8~54MHz
‧Extremely good for reducing EMI effect.
Specifications
Standard Frequency
8~54 MHz
Vibration Mode
AT Fundamental
Load Capacitance
10pF,20pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±20ppm,or specify
Frequency Versus Temperature Characteristics
Operating Temperature
±20ppm,or specify
-20~+70℃,-40~+85℃,or specify
Storage Temperature
-55~+125℃ or specify
Shunt Capacitance
5 pF Max.
Level of Drive
1~200μWMax.(100uW typical)
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
8 ~ 12MHz
12 ~ 25 MHz
25 ~ 54 MHz
Fundamental
Dimensions and Patterns [unit:mm]
60~80 Ω Max.
40~60 Ω Max.
30~40 Ω Max.
Package Size – Dimensions (Unit: mm)
www.yxc.hk
第1页共2页
CRYSTAL UNIT
YSX531SL
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-5032
180±2.0
12.0±0.3
5.40±0.1
3.60±0.1
8.00±0.3
1.45±0.1
61.0±1.0
12.0±1.0
1000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X503224576MSB4SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.10250
- 50+0.84630
- 1000+0.77910
- 国内价格
- 10+3.42190
- 100+2.04120
- 500+1.42890
- 1000+1.02060
- 2000+0.96960
- 10000+0.89820
- 国内价格
- 5+1.98018
- 50+1.55488
- 150+1.37258
- 1000+1.14524
- 2000+1.04393
- 5000+0.98313
- 国内价格
- 1+0.92400
- 30+0.89100
- 100+0.85800
- 500+0.79200
- 1000+0.75900
- 2000+0.73920
