X503224MSB4SI
X503224MSB4SI
    YXC(扬兴科技)
    SMD5032_4P
    无源晶振 24MHz 20pF - ±10ppm -40℃~+85℃ SMD5032_4P
X503224MSB4SI 数据手册
CRYSTAL UNIT YSX531SL Applications Features ‧Industrial Control Consumers. ‧Dimensions:5.00 x 3.20 x 0.90 mm. ‧High precision and high frequency stability. ‧Standard Frequency: 8~54MHz ‧Extremely good for reducing EMI effect. Specifications Standard Frequency 8~54 MHz Vibration Mode AT Fundamental Load Capacitance 10pF,20pF,or specify Frequency Tolerance (at 25 ) ±10ppm,±20ppm,or specify Frequency Versus Temperature Characteristics Operating Temperature ±20ppm,or specify -20~+70℃,-40~+85℃,or specify Storage Temperature -55~+125℃ or specify Shunt Capacitance 5 pF Max. Level of Drive 1~200μWMax.(100uW typical) Aging (at 25 ℃ ) ±3ppm/year Max. Equivalent Series Resistance(ESR) 8 ~ 12MHz 12 ~ 25 MHz 25 ~ 54 MHz Fundamental Dimensions and Patterns [unit:mm] 60~80 Ω Max. 40~60 Ω Max. 30~40 Ω Max. Package Size – Dimensions (Unit: mm) www.yxc.hk 第1页共2页 CRYSTAL UNIT YSX531SL Reflow Soldering Profile Temperature Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C Heating Temperature TMlt = + 220 °C Peek Temperature TMax. = + 260 °C +260℃ TMax. +220℃ Tmlt Point of measuring In case of Solder ability Terminal. In case of Resistance to soldering heat Surface. Tp2 Tp1 35s 100s t(time) Taping Specification(Unit: mm) Size A B C D E F G H SMD-5032 180±2.0 12.0±0.3 5.40±0.1 3.60±0.1 8.00±0.3 1.45±0.1 61.0±1.0 12.0±1.0 1000 pcs per reel www.yxc.hk 第2页共2页
X503224MSB4SI 价格&库存
很抱歉,暂时无法提供与“X503224MSB4SI”相匹配的价格&库存,您可以联系我们找货
X503224MSB4SI
  • 1+0.87040
  • 30+0.83840
  • 100+0.80640
  • 500+0.74240
  • 1000+0.71040
  • 2000+0.69120
X503224MSB4SI
  • 10+3.42190
  • 100+2.04120
  • 500+1.42890
  • 1000+1.02060
  • 2000+0.96960
  • 10000+0.89820
库存:776
X503224MSB4SI
  • 1+1.19900
  • 50+0.91850
  • 1000+0.84700
库存:928
X503224MSB4SI
库存:1006000
X503224MSB4SI
  • 1+0.95790
库存:18
X503224MSB4SI
  • 5+2.21830
  • 50+1.75530
  • 150+1.55680
  • 1000+1.15020
  • 2000+1.04010
库存:1000
