X5032110592MSB4SI
X5032110592MSB4SI
    YXC(扬兴科技)
    SMD5032_4P
    无源晶振 11.0592MHz ±10ppm 20pF -40℃~+85℃
X5032110592MSB4SI 数据手册
CRYSTAL UNIT YSX531SL Applications Features ‧Industrial Control Consumers. ‧Dimensions:5.00 x 3.20 x 0.90 mm. ‧High precision and high frequency stability. ‧Standard Frequency: 8~54MHz ‧Extremely good for reducing EMI effect. Specifications Standard Frequency 8~54 MHz Vibration Mode AT Fundamental Load Capacitance 10pF,20pF,or specify Frequency Tolerance (at 25 ) ±10ppm,±20ppm,or specify Frequency Versus Temperature Characteristics Operating Temperature ±20ppm,or specify -20~+70℃,-40~+85℃,or specify Storage Temperature -55~+125℃ or specify Shunt Capacitance 5 pF Max. Level of Drive 1~200μWMax.(100uW typical) Aging (at 25 ℃ ) ±3ppm/year Max. Equivalent Series Resistance(ESR) 8 ~ 12MHz 12 ~ 25 MHz 25 ~ 54 MHz Fundamental Dimensions and Patterns [unit:mm] 60~80 Ω Max. 40~60 Ω Max. 30~40 Ω Max. Package Size – Dimensions (Unit: mm) www.yxc.hk 第1页共2页 CRYSTAL UNIT YSX531SL Reflow Soldering Profile Temperature Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C Heating Temperature TMlt = + 220 °C Peek Temperature TMax. = + 260 °C +260℃ TMax. +220℃ Tmlt Point of measuring In case of Solder ability Terminal. In case of Resistance to soldering heat Surface. Tp2 Tp1 35s 100s t(time) Taping Specification(Unit: mm) Size A B C D E F G H SMD-5032 180±2.0 12.0±0.3 5.40±0.1 3.60±0.1 8.00±0.3 1.45±0.1 61.0±1.0 12.0±1.0 1000 pcs per reel www.yxc.hk 第2页共2页
X5032110592MSB4SI 价格&库存
很抱歉,暂时无法提供与“X5032110592MSB4SI”相匹配的价格&库存,您可以联系我们找货
X5032110592MSB4SI
  • 10+3.42190
  • 100+2.04120
  • 500+1.42890
  • 1000+1.02060
  • 2000+0.96960
  • 10000+0.89820
X5032110592MSB4SI
  • 1+1.20100
  • 50+0.92230
  • 1000+0.84980
库存:1765
X5032110592MSB4SI
  • 5+1.80153
  • 50+1.41708
  • 150+1.25234
库存:200
X5032110592MSB4SI
  • 1+1.04520
  • 30+1.00620
  • 100+0.96720
  • 500+0.88920
  • 1000+0.85020
  • 2000+0.82680
库存:19
X5032110592MSB4SI
  • 1+0.92410
库存:392
