XC53G2-8.000-F20LJDT
    HCI(杭晶)
    SMD5032_2P
    无源晶振 8MHz ±20ppm 20pF 80Ω -40℃~+85℃
XC53G2-8.000-F20LJDT 数据手册
QUARTZ CRYSTAL UNIT XC53G2 QUARTZ CRYSTAL UNIT SMD 5.0X3.2MM IN GLASS SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Dimensions 5.0x3.2x1.3 with 2 solder pads.  Low cost ceramic glass seal package.  Tight tolerances and stabilities over temperature range.  RoHS compliant by exemption and HALOGEN-FREE. APPLICATIONS  Motherboard  Computer peripherals  Handheld equipment PRODUCT SPECIFICATIONS XC53G2 PARAMETER Nominal frequency range CONDITIONS / REMARKS 8.0 ~ 80.0MHz Crystal cut and mode AT-cut Frequency tolerance / FUND & 3rd Overtone ±10ppm Frequency stability Operating temperature range to ±50ppm Fundamental up to 50MHz and 3rd overtone from 40MHz. Other options available. ±10ppm ±30ppm Other options available. –20 to +70°C –40 to +85°C Other options available. Equivalent series resistance Load capacitance 80Ω FUND — 8.0 ~ 12.0MHz 60Ω FUND — 12.1 ~ 20.0MHz 50Ω FUND — 20.1 ~ 50.0MHz 120Ω 3rd OT — 40.0 ~ 60.0MHz 100Ω 3rd OT — 60.1 ~ 80.0MHz 6 ~ 32pF or SERIES Shunt capacitance Drive level Please specify.
物料型号:ATMEGA16A-AU 器件简介:ATMEGA16A-AU 是一款低功耗的8位CMOS微控制器,具有16KB的内部FLASH存储器、1KB的EEPROM、512B的SRAM、32个通用I/O引脚、32位定时器/计数器、8路10位ADC、可编程看门狗定时器、内部振荡器和SPI/TWI/USART 串行通信接口。
引脚分配:ATMEGA16A-AU 有40个引脚,包括电源引脚、地引脚、I/O引脚、晶振引脚和复位引脚。
参数特性:工作电压范围为1.8V至5.5V,工作频率最高可达16MHz,具有低功耗模式以延长电池寿命。
功能详解:ATMEGA16A-AU 支持多种通信协议,包括SPI、TWI和USART,具有中断和睡眠模式以提高效率。
应用信息:适用于各种嵌入式系统,如家用电器控制、工业自动化和便携式设备。
封装信息:采用TQFP封装。
XC53G2-8.000-F20LJDT 价格&库存
很抱歉,暂时无法提供与“XC53G2-8.000-F20LJDT”相匹配的价格&库存,您可以联系我们找货
  • 5+1.26225
  • 50+0.99942
  • 200+0.88677
  • 400+0.87347
  • 1000+0.74629
库存:2111
  • 1+0.95920
  • 50+0.73810
  • 1000+0.68090
库存:887
