KCMB2819-222N
KCMB2819-222N
    KONENELEK(坤恩)
    共模电感 2819 20mΩ 2.2mH 6A
KCMB2819-222N 数据手册
Winding Wound Common Mode THT Choke-KCMB Series Features  Broadband filterring due to low capacitance winding technique;  High suppression of asymmetrical interferences also at low frequency range;  Very compact design;  Highest possible rated current by small size;  Flammability corresponding to UL 94 V-0;  Certified according to IEC 60938-2;  Operating temperature range -55℃~125℃(Including self - temperature rise; Application  Power line input and output filter.  Filterring of devices without any ground connection.  Suppression of radio interferences in motors.  Suppression of common mode noice. Product Identification KCMB ① 1 2 ③ ④ 2819 - 102 N ③ ④ ② Series name: Wire Wound Common Mode THT Choke Chip Size: 28×19×33mm Inductance: 1000 uH Tolerance: ±30% SHAPE AND DIMENSIONS Recommended Layout: Series KCMB2819 Schematic: Mechanical Dimensions(mm) Land Pattern(mm) LMax WMax HMax a b c dTyp e f Ø 28 19 33 12±0.5 10±0.5 5.0±0.5 1.0 12.0 10.0 1.3 Konen Elektronik (shenzhen) Co.,Ltd www.konen-elek.com 1 Tel: +86 755 2733 7940 sales@konen-elek.com Winding Wound Common Mode THT Choke-KCMB Series SPECIFICATIONS KCMB 2819 Series Part Number L(μH) IR(A) DCR(mΩ) UR(Vac) UT(Vac) Core Material Test Condition KCMB2819-102N 1000 10 7 250 1500 Mn-Zn 10KHz/0.25V KCMB2819-222N 2200 6.0 20 250 1500 Mn-Zn 10KHz/0.25V KCMB2819-332N 3300 4.0 35 250 1500 Mn-Zn 10KHz/0.25V KCMB2819-103N 10000 3.0 105 250 1500 Mn-Zn 10KHz/0.25V KCMB2819-203N 20000 2.0 220 250 1500 Mn-Zn 10KHz/0.25V L: Inductance; IR: Rated Current; UR: Rated Voltage; UT: Insulation TestVoltage TYPICAL ELECTRICAL CHARACTERISTICS KCMB2819 series Konen Elektronik (shenzhen) Co.,Ltd www.konen-elek.com 2 Tel: +86 755 2733 7940 sales@konen-elek.com
KCMB2819-222N
- 物料型号:KCMB系列,例如KCMB2819-102N、KCMB2819-222N等。 - 器件简介:宽带滤波器,由于低电容绕组技术,具有在低频范围内高抑制不对称干扰的能力,非常紧凑的设计。 - 引脚分配:文档中未明确提供引脚分配信息,但提供了推荐布局和原理图。 - 参数特性:包括电感值(L)、额定电流(IR)、直流电阻(DCR)、额定电压(UR)和绝缘测试电压(UT)。 - 功能详解:用于电源线输入和输出滤波、无接地设备的滤波、电机中无线电干扰的抑制、共模噪声的抑制。 - 应用信息:适用于电源线输入输出滤波、无接地设备的滤波、电机无线电干扰和共模噪声的抑制。 - 封装信息:提供了KCMB2819系列的机械尺寸和焊盘图案尺寸。
具体型号的参数特性如下: - KCMB2819-102N:1000μH电感,10A额定电流,7mΩ直流电阻,250Vac额定电压,1500Vac绝缘测试电压。 - KCMB2819-222N、KCMB2819-332N等型号也有相应的参数,电感值、额定电流、直流电阻会有所不同。
KCMB2819-222N 价格&库存
很抱歉,暂时无法提供与“KCMB2819-222N”相匹配的价格&库存,您可以联系我们找货
KCMB2819-222N
  • 1+10.40000
  • 10+9.60000
  • 30+9.44000
