RNCP1206FTD15K0
RNCP1206FTD15K0
    SEI
    电阻器 15KΩ ±1% 0.5W ±100ppm/℃ 1206
RNCP1206FTD15K0 数据手册
RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Features: • • • • • • • Higher power ratings than standard thick film chips Absolute TCRs to ± 100 ppm/C Inner termination engineered to deter sulfur contamination Absolute tolerances to 1% 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type / Code (1) (2) Power Rating (W) @ 70°C (1) Maximum Working Voltage (V)(2) Maximum Overload Voltage (V) RNCP0402 0.1 50 100 RNCP0603 0.125 150 300 RNCP0805 0.25 RNCP1206 0.5 200 400 TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance 1%, 5% 1 - 10K 1 - 47K ± 100 1 - 100K Power rating for each package size is valid if ambient temp ≤ 80ºC and terminal temp ≤ 105ºC Lesser of √PR or maximum working voltage Certain resistance values will require a higher minimum order quantity. Contact Stackpole Customer Service for details. Please refer to the High-Power Resistor Application Note (page 5) for more information on designing and implementing high power resistor types. Mechanical Specifications Type / Code L Body Length W Body Width H Body Height a Top Termination b Bottom Termination Unit RNCP0402 0.039 ± 0.004 1.00 ± 0.10 0.020 ± 0.002 0.50 ± 0.05 0.012 ± 0.002 0.30 ± 0.05 0.010 ± 0.006 0.25 ± 0.15 0.012 ± 0.006 0.30 ± 0.15 inches mm RNCP0603 0.061 ± 0.008 1.55 ± 0.20 0.031 ± 0.004 0.80 ± 0.10 0.016 ± 0.006 0.40 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 inches mm RNCP0805 0.079 ± 0.006 2.00 ± 0.15 0.049 ± 0.006 1.25 ± 0.15 0.020 ± 0.006 0.50 ± 0.15 0.016 ± 0.010 0.40 ± 0.25 0.020 ± 0.012 0.50 ± 0.30 inches mm RNCP1206 0.122 ± 0.008 3.10 ± 0.20 0.059 ± 0.008 1.50 ± 0.20 0.020 ± 0.006 0.50 ± 0.15 0.022 ± 0.024 0.55 ± 0.60 0.024 ± 0.012 0.60 ± 0.30 inches mm Performance Characteristics Test Item Temperature Coefficient of Resistance Short Time Overload Reference Standard MIL-STD-202F Method 304; JIS-C5201-1-4.8 MIL-R-55342D Paragraph 4.7.5; JIS-C5201-1-4.13 High Temperature Exposure (Storage) MIL-STD-202 Method 108 Rev Date: 03/09/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Condition of Test Test Limits (ΔR) + 25 ~ +125ºC ±100 ppm/ºC 2.5 times rated voltage for 5 seconds. F: ± (1% + 0.1 Ω) J: ± (2% + 0.1 Ω) 1000 hours at T = 125ºC. Unpowered. Measurement at 24 ± 2 hours after test conclusion. F: ± (2% + 0.1 Ω) J: ± (2% + 0.1 Ω) 1 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Item Reference Standard Temperature Cycling JESD22 Method JA-104 Moisture Resistance MIL-STD-202 Method 106 Biased Humidity MIL-STD-202 Method 103 Operational Life MIL-STD-202 Method 108 Resistance to Soldering Heat MIL-STD-202 Method 210 Solderability J-STD-002 Board Flex (Bending) AEC-Q200-005 3 mm deflection. F: ± (0.5% + 0.05 Ω) J: ± (1% + 0.1 Ω) AEC-Q200-006 Pressure X kgf a R0.5 pressure rod for 60 seconds. 0201: NA 0402: 0.5 Kg, 0805: 1 Kg 0603: 0.5 Kg, 1206: 1.8 Kg F: ± (0.5% + 0.05 Ω) J: ± (1% + 0.1 Ω) Terminal Strength (SMD) Condition of Test 1000 cycles (-55ºC to +125ºC). Measurement at 24 ± 2 hours after test conclusion. 1000 hours, T = 24 hours/cycle Notes: Steps 7a & 7b not required. Unpowered. 1000 hours 85ºC / 85% RH. Specified conditions: 10% of operating power. Measurement at 24 ± 2 hours after test conclusion. 1000 hours TA = 125ºC at rated power. Measurement at 24 ± 2 hours after test conclusion. Remark: Mounted quantity: Mounted 2 pieces on 1 PCB. Condition B: Immerse the specimens in an eutectic solder at 260 ± 5ºC for 10 ± 1 seconds. 245 ± 5ºC solder, 2 ± 0.5 seconds. dwell Solder: Sn 96.5 / Ag 3.0 / Cu 0.5. Test Limits (ΔR) F: ± (0.5% + 0.05 Ω) J: ± (1% + 0.1 Ω) Note: R ≤ 10 Ω: F/J: ± (1% + 0.1 Ω) F: ± (1% + 0.05 Ω) J: ± (2% + 0.1 Ω) F: ± (3% + 0.1 Ω) J: ± (3% + 0.1 Ω) F: ± (1% + 0.05 Ω) J: ± (3% + 0.1 Ω) F: ± (0.5% + 0.05 Ω) J: ± (1% + 0.1 Ω) >95% area covered with tin Operating temperature range is -55°C to +155°C Power Derating Curve: 100 -55 ºC 70 ºC Power Load (%) 80 60 40 20 0 -60 155 ºC 0 20 40 60 80 100 120 140 160 180 Ambient Temperature (ºC) Rev Date: 03/09/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Packaging Specifications RNCP0402 (2 mm Pitch Paper) RNCP0603, 0805, 1206 (4 mm Pitch Paper) Type / Code Paper Tape Pitch A B W E F Unit 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 0.028 ± 0.002 0.70 ± 0.05 0.047 ± 0.002 1.20 ± 0.05 0.315 ± 0.008 8.00 ± 0.20 0.069 ± 0.004 1.75 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 inches mm 0.043 ± 0.004 1.10 ± 0.10 0.075 ± 0.004 1.90 ± 0.10 0.315 ± 0.008 8.00 ± 0.20 0.069 ± 0.004 1.75 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 inches mm 0.063 ± 0.006 1.60 0.15 0.094 ± 0.008 2.40 ± 0.20 0.315 ± 0.008 8.00 ± 0.20 0.069 ± 0.004 1.75 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 inches mm 0.079 ± 0.006 2.00 ± 0.15 0.142 ± 0.008 3.60 ± 0.20 0.315 ± 0.008 8.00 ± 0.20 0.069 ± 0.004 1.75 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 inches mm Type / Code P1 P2 P0 D0(ø) T Unit RNCP0402 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 inches mm RNCP0603 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.025 ± 0.004 0.64 ± 0.10 inches mm RNCP0805 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.004 0.84 ± 0.10 inches mm RNCP1206 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.004 0.84 ± 0.10 inches mm RNCP0402 RNCP0603 RNCP0805 RNCP1206 Rev Date: 03/09/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Reel Specifications Type / Code RNCP ØA 7.008 ± 0.079 178.00 ± 2.00 ØB 2.362 ± 0.039 60.00 ± 1.00 Øc 0.512 ± 0.039 13.00 ± 1.00 W 0.354 ± 0.039 9.00 ± 1.00 T 0.453 ± 0.039 11.50 ± 1.00 Unit inches mm Peel-off Force Specifications Peel-off force of paper and blister tape is in accordance with “JIS-C5202”, that is, 0.1 to 0.7N at a peel-off speed of 300 mm/minute. Solder Land Pattern Type / Code 0402 0603 0805 1206 A 0.016 0.40 0.026 0.65 0.039 1.00 0.079 2.00 Rev Date: 03/09/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. B 0.059 1.50 0.083 2.10 0.118 3.00 0.165 4.20 4 C 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 Unit inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Recommended IR – Reflow Profile (Solder: Sn96.5 / Ag3 / Cu0.5) Peak: 250 +5 / -0 °C, 5 seconds Pre-heat Zone: 150 °C to 180 °C, 90 ± 30 seconds Soldering Zone: 230 °C or higher, 30 ± 10 seconds High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR ½ 100 milliohms at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. Rev Date: 03/09/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50 milliohms. This should be taken into account when designing. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RNCP Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) High Power Anti-Sulfur Thin Film Chip Resistor SMD YES 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 03/09/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 R N C P 0 6 0 3 F T D 4 K 7 5 Product Series High Power RNCP Anti-Sulfur Thin Film Power Rating Size W 0402 0.1 0603 0.125 0805 0.25 0.5 1206 Tolerance Code Tol Value F 1% E96, E24 J 5% E24 Packaging Code Description T 7" Reel - Paper Tape Size Quantity 0402 10000 0603, 0805, 1206 5000 Certain resistance values will require a higher minimum order quantity. Contact Stackpole Customer Service for details. Rev Date: 03/09/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 7 TCR Code ppm D 100 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 47 Kohm = 47K0 100 Kohm = 100K www.seielect.com marketing@seielect.com
RNCP1206FTD15K0
物料型号:RNCP系列
器件简介: - 由Stackpole Electronics, Inc.生产 - 具有比标准厚膜芯片更高的功率等级 - 绝对温度系数(TCR)达到±100 ppm/°C - 内部终端设计防止硫污染 - 符合RoHS标准,无铅 - 符合REACH标准,无卤素
引脚分配:文档中未明确列出引脚分配,但提供了不同尺寸的电阻器的机械规格,例如RNCP0402、RNCP0603、RNCP0805和RNCP1206。
参数特性: - 电气规格包括工作电压、TCR等 - 机械规格包括尺寸、高度、终止层厚度等 - 性能特性包括电阻温度系数、短时过载、高温暴露、温度循环、湿度电阻、偏置湿度、操作寿命、耐焊热、可焊性、板弯曲和端子强度等测试项
功能详解: - 提供了详细的性能测试条件和限制 - 强调了在设计和实施高功率电阻器时需要注意的热管理问题
应用信息: - 适用于需要高功率和抗硫特性的应用 - 提供了焊接曲线和热管理建议
封装信息: - 提供了不同尺寸的封装规格,包括0402、0603、0805和1206 - 包括了封装的尺寸、纸带间距、卷轴规格等信息
订购信息: - 提供了如何根据电阻值、公差、尺寸、TCR等参数进行订购的指南
环保合规性: - 符合RoHS和REACH标准 - 承诺不使用来自刚果民主共和国东部冲突地区的金属 - 遵循环保政策,致力于减少环境污染
订购代码示例: - RNCP0603FTD4K75:表示0603尺寸、1%公差、100 ppm/°C TCR、4.75欧姆的电阻器,以7英寸纸带卷的形式提供
RNCP1206FTD15K0 价格&库存
很抱歉,暂时无法提供与“RNCP1206FTD15K0”相匹配的价格&库存,您可以联系我们找货
RNCP1206FTD15K0
    • 1405+0.12508
    库存:1405
