AC0805KKX8R9BB223
AC0805KKX8R9BB223
    YAGEO(国巨)
    22NF ±10% 50V
AC0805KKX8R9BB223 数据手册
85 DATA SHEET SURFACE MOUNT MULTILAYER CERAMIC CAPACITORS Automotive grade High Temperature Application X8G / X8R 16 V TO 100 V 1 nF to 100 nF Product Specification – October 3, 2019 V.1 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X8G / X8R 16 V to 100 V 2 17 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes Automotive grade X8G / X8R series chip capacitors with leadfree terminations and used for automotive equipments. All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. GLOBAL PART NUMBER AC XXXX X X XXX X (1) APPLICATIONS Decoupling, smoothing, snubber and resonant of high temperature operating equipment. FEATURES  AEC-Q200 qualified  Operating temperature range: -55 to 150°C  MSL class: MSL 1  Soldering is compliant with JSTD-020D  Halogen free epoxy  RoHS compliant  Reduce environmentally hazardous waste  High component and equipment reliability  The capacitors are 100% performed by automatic optical inspection prior to taping. (2) (3) (4) B (5) X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0805 (2012) (2) TOLERANCE F = ± 1% G = ± 2% J = ± 5% K = ± 10% M = ± 20% (3) PACKING STYLE (SEE TABLE 3) R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL X8G : 0± 30 ppm/°C X8R : ± 15% (5) RATED VOLTAGE 7 = 16 V 8 = 25 V 9 = 50 V 0 = 100 V (6) PROCESS N = Class I MLCC (X8G) B = Class II MLCC (X8R) (7) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Oct. 03,2019 V.1 3 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X8G / X8R 17 16 V to 100 V CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. terminations electrodes The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (Matte Sn). The terminations are leadfree. A cross section of the structure is shown in Fig.1. MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION OUTLINES Table 1 For outlines see fig. 2 TYPE 0805 L1 (mm) W (mm) T (MM) 2.0 ± 0.10 1.25 ± 0.10 0.60 ± 0.10 2.0 ± 0.10 1.25 ± 0.10 0.85 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 1.25 ± 0.20 L2 / L3 (mm) L4 (mm) min. max. min. 0.25 0.75 0.70 For dimension see Table 1 W T L2 L4 L1 CAPACITANCE RANGE & THICKNESS FOR X8G L3 MBB211 Fig. 2 Surface mounted multilayer ceramic capacitor dimension Table 2-1 Size 0805 0805 CAP. 50 V 100 V 1 nF 0.6± 0.1 0.6± 0.1 1.2 nF 0.6± 0.1 0.6± 0.1 1.5 nF 0.6± 0.1 0.6± 0.1 1.8 nF 0.6± 0.1 0.6± 0.1 2.7 nF 0.6± 0.1 0.6± 0.1 3.3 nF 0.6± 0.1 0.6± 0.1 3.9 nF 0.6± 0.1 0.6± 0.1 4.7 nF 0.6± 0.1 0.6± 0.1 5.6 nF 0.6± 0.1 0.6± 0.1 6.8 nF 0.85± 0.1 0.85± 0.1 8.2 nF 0.85± 0.1 0.85± 0.1 10 nF 0.85± 0.1 0.85± 0.1 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Oct. 03,2019 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X8G / X8R 16 V to 100 V 4 17 CAPACITANCE RANGE & THICKNESS FOR X8R Table 2-2 Size 0805 0805 CAP. 16 V 25 V 50 V 22 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 33 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 47 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 68 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 100 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request THICKNESS CLASSES AND PACKING QUANTITY Table 3 SIZE CODE 0805 THICKNESS CLASSIFICATION PACKING CODE QUANTITY PER REEL TAPE WIDTH Ø 180 MM / 7 INCH Paper Blister Ø 330 MM / 13 INCH Paper Blister 7 INCH 13 INCH 0.60 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 www.yageo.com Oct. 03,2019 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X8G / X8R 5 17 16 V to 100 V PAPER/PE TAPE SPECIFICATION P0 D0 T P2 E F cover tape W B0 K0 A0 P1 MBG251-1 Fig. 3 Paper/PE tape Table 4 Dimensions of paper/PE tape for relevant chip size; see Fig.3 SIZE Unit: mm SYMBOL CODE A0 B0 W E F P0 (1) P1 P2 Ø D0 K0 T 0.38 ± 0.05 (0.47 / 0.55)±0.10 0201 0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03 0402 0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75 / 0.60)±0.10 (0.85 / 0.70)±0.10 0603 1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 0805 1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 1206 1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95 / 0.75)±0.10 (1.05 / 0.85)± 0.10 NOTE 1. P0 pitch tolerance over any 10 pitches is 0.2 mm www.yageo.com Oct. 03,2019 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X8G / X8R 16 V to 100 V 6 17 BLISTER TAPE SPECIFICATION P0 D0 K0 P2 E F cover tape W B0 A0 T2 SCM015 D1 P1 direction of unreeling Table 5 Dimensions of blister tape for relevant chip size; see Fig.4 SYMBOL SIZE B0 CODE A0 Unit: mm K0 W E F Min. Max. Min. Max. Min. Max. Ø D0 Ø D1 P0 (2) P1 P2 T2 Min. Min. Max. 0805 1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67 1206 1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20 1210 2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97 1808 2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50 1812 3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45 NOTE 1. Typical capacitor displacement in pocket 2. P0 pitch tolerance over any 10 pitches is ±0.2 mm www.yageo.com Oct. 03,2019 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X8G / X8R 16 V to 100 V 7 17 REEL SPECIFICATION W2 C N A HBK039 W1 Table 6 Reel dimensions; see Fig.5 TAPE WIDTH SYMBOL Unit: mm A N C W1 W2max. 8 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 9.4 ± 1.5 14.4 8 (Ø 330 mm/13") 330 ± 1.0 100 ± 1.0 13 +0.50/-0.20 9.0 ± 0.2 14.4 12 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 13.4 ± 1.5 18.4 P ROPERTIES OF REEL Material: polystyrene Surface resistance:
AC0805KKX8R9BB223 价格&库存
很抱歉,暂时无法提供与“AC0805KKX8R9BB223”相匹配的价格&库存,您可以联系我们找货
AC0805KKX8R9BB223
  • 1+2.911781+0.37853
  • 10+1.6841410+0.21894
  • 50+1.2171950+0.15823
  • 100+1.07256100+0.13943
  • 500+0.82998500+0.10790
库存:588
AC0805KKX8R9BB223
  • 3000+0.662953000+0.08618
  • 9000+0.595299000+0.07739
库存:588
