山东晶导微电子有限公司
Jingdao Microelectronics
SS52 THRU SS520
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 5.0A
PINNING
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS52~SS520
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 60mg / 0.0021oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS52
SS54
SS56
SS58
SS510
SS512
SS515
SS520
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
5.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage at 5 A
VF
0.55
0.70
0.85
1.0
50
Maximum DC Reverse Current T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
IR
500
Cj
V
mA
300
pF
RθJA
60
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.11
SMA-S-SS52~SS520-5A200V
Page 1 of 3
山东晶导微电子有限公司
SS52 THRU SS520
Fig.2 Typical Reverse Characteristics
6.0
5.0
4.0
3.0
2.0
1.0
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
T J =75°C
10 2
10 1
T J =25°C
10 0
Case Temperature (°C)
80
100
T J =25°C
Junction Capacitance ( pF)
1
SS52/SS54
SS56/SS58
SS510/SS520
0.1
1.0
1.5
1000
500
100
SS52/SS54
SS56~SS520
10
2.0
0.1
175
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Transient Thermal Impedance( °C /W)
200
25
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
60
Fig.4 Typical Junction Capacitance
Instaneous Forward Voltage (V)
Fig.6- Typical Transient Thermal Impedance
100
Number of Cycles at 60Hz
2016.11
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
T J =100°C
10 3
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS52 THRU SS520
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
a
0.3
12
SS26F
The recommended mounting pad size
Marking
Type number
SS22F
SS24F
2.2
(86)
mm
Unit :
(mil)
2016.11
SS52
SS52
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
611296B0
SS54
SS54
SS56
SS56
SS58
SS58
SS510
SS510
SS512
SS512
SS515
SS515
SS520
SS520
Page 3 of 3
很抱歉,暂时无法提供与“SS54”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32690
- 100+0.26275
- 1000+0.20661
- 2000+0.20351
- 5000+0.18345
- 国内价格
- 10+0.34410
- 100+0.27310
- 300+0.23950
- 1000+0.21430
- 2500+0.19010
- 7500+0.18010
- 国内价格
- 10+0.34770
- 100+0.27870
- 300+0.24420
- 1000+0.21860
- 5000+0.19410
- 10000+0.18390
- 国内价格
- 5000+0.13108
- 10000+0.12760
- 国内价格
- 1+0.32560
- 500+0.21780
- 2500+0.18920
- 5000+0.17160
- 国内价格
- 10+0.35662
- 100+0.28664
- 300+0.25164
- 1000+0.22540
- 5000+0.20013
- 10000+0.18954
