600S1R2AT250XT
600S1R2AT250XT
    ATC
    贴片电容(MLCC) 0603 1.2pF ±0.05pF 250V C0G (NP0)
600S1R2AT250XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600S Ultra-Low ESR, High Q, NPO Capacitors FEATURES • • • • • Lowest ESR in Class Highest Working Voltage in Class - 250 V Standard EIA Size: 0603 Laser Marking (Optional) High Self-Resonance Frequencies 600 SERIES OVERVIEW APPLICATIONS Series Case Size EIA Case Size 600 L 0402 600 S 0603 600 F 0805 PACKAGING OPTIONS • Cellular Base Stations • Broadband Wireless Services • Satellite Communications • Subscriber-based Wireless Devices • WiFi (802.11) • Public Safety Radio Tape & Reel CIRCUIT APPLICATIONS Vertical Orientation Tape & Reel LEAD-FREE COMPATIBLE COMPONENT ENVIRONMENTAL CHARACTERISTICS • Filter Networks • High Q Frequency Sources • Matching Networks • Tuning, Coupling, Bypass and DC Blocking ELECTRICAL SPECIFICATIONS Capacitance 0.1 to 100 pF Tolerances See Cap Value Chart Working Voltage (WVDC) 250 V Quality Factor (Q) > 2000 @ 1 MHz Operating Temperature Range -55°C to +125°C Temperature Coefficient of Capacitance (TCC) 0 ± 30 ppm/°C, -55°C to +125° 105 MΩ min. at +25°C at rated WVDC 104 MΩ min. at +125°C at rated WVDC Dielectric Withstanding Voltage (DWV) 2.5 x WVDC for 5 seconds Aging None Piezo Effects None Themal Shock 5 Cycles, -55ºC to 125ºC Moisture Resistance Mil-STD-202, Method 106 Life Test 2000 hours at 125ºC at 2X WVDC Solderability Solder Coverage > 90% of end termination Terminal Strength 4 lbs. typ., 2 lb. min. Military Approval DSCC Drawing Number 05002 (no derating of working voltage) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070121 – rf microwave products – 507 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600S Ultra-Low ESR, High Q, NPO Capacitors CAPACITANCE VALUES Value (pF) 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 Cap Code 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R5 1R6 1R8 2R0 2R2 2R4 Marking Tolerances A9 H9 M9 d9 f9 m9 n9 t9 y9 A0 B0 C0 D0 E0 F0 G0 H0 J0 K0 A, B A, B A, B, C A, B, C A, B, C A, B, C A, B, C A, B, C A, B, C A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D Value (pF) 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 15 18 Cap Code 2R7 3R0 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 150 180 Marking Tolerances L0 M0 N0 P0 Q0 R0 S0 T0 U0 V0 W0 X0 Y0 Z0 A1 B1 C1 E1 G1 A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D B, C, J, K B, C, J, K B, C, J, K B, C, J, K F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M Value (pF) 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 Cap Code 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 Marking Tolerances H1 J1 K1 L1 M1 N1 P1 Q1 R1 S1 T1 U1 V1 W1 X1 Y1 Z1 A2 F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M HOW TO ORDER 600 S 0R2 B T 250 X** T Series Packaging Case Size T = Tape and Reel, 500 pcs T4K = Tape and Reel, 4000 pcs TV = Vertical Tape and Reel, 500 pcs See mechanical dimensions below Capacitance Code Laser Marking (Optional) EIA Capacitance Code in pF. Third digit = number of zeros or after “R” significant figures Voltage Rating Capacitance Tolerance Code Code Tol. A B C Termination Style Code D ±0.05 pF ±0.1 pF ±0.25 pF ±0.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% The above part number refers to a 600F Series (case size F) 10 pF capacitor, J tolerance (±5%), 250 WVDC, with T termination (Tin Plated over Nickel Barrier, RoHS Compliant), Laser Marking and Tape and Reel packaging. T = Tin Plated over Nickel Barrier (RoHS Compliant) TN = Tin Plated Non-Magnetic Barrier W = Tin/Lead Solder Nickel Barrier **Laser Marking is optional 508 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600S Ultra-Low ESR, High Q, NPO Capacitors The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 120320 – rf microwave products – 509 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600S Ultra-Low ESR, High Q, NPO Capacitors 600F Series Data Sheet Condition Description Capacitors horizontally mounted on 13.3 -mil thick Rogers R0435® softboard 29-mils wide 1/2 oz. Cu traces FSR = lowest frequency at which S11 response, referenced at capacitor edge, crosses real axis on Smith Chart. FPR = lowest frequency at which there is a notch in S21 magnitude response. 510 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 120320 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600S Ultra-Low ESR, High Q, NPO Capacitors OUTLINE DIMENSIONS Y S (0603) W L: .063 ± .006 (1.60 ± 0.15) W: .032 ± .006 (.81 ± 0.15) T: .035 max (0.89 max) Y: .014 ± .006 (0.36 ± 0.15) inches (mm) T L SUGGESTED MOUNTING PAD DIMENSIONS W L T B A B Case Size L, S, and F Case Size A Min. B Min. C Min. D Min. 0402 (1005) .0275 (0.70) .0354 (0.90) .0157 (0.40) .0866 (2.20) 0603 (1608) .0393 (1.00) .0433 (1.10) .0236 (0.60) .110 (2.80) 0805 (2012) .0590 (1.50) .0512 (1.30) .0236 (0.60) .1259 (3.20) inches (mm) C D DESIGN KITS Kit # Kit 25T Kit 26T Kit 27T RoHS Compliant Item # Description Cap. Value Range (pF) DK0025T 600S Series Ultra-low ESR, High Q Microwave Capacitors 16 different values, 15 pcs. min. per value 0.1 to 2.0 DK0026T 600S Series Ultra-low ESR, High Q Microwave Capacitors 16 different values, 15 pcs. min. per value 0.1 to 10 DK0027T 600S Series Ultra-low ESR, High Q Microwave Capacitors 16 different values, 15 pcs. min. per value 10 to 100 Cap. Value (pF) Tol. (pF) 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8,0.9, 1.0, 1.1, 1.2, 1.5...............................................±0.1% Price $100.00 1.6, 1.8, 2.0......................................................±0.25% 1.0, 1.2, 1.5, 1.8, 2.0. 2.2, 2.4, 2.7, 3.0, 3.3.....±0.1% 3.9, 4.7, 5.6, 6.8, 8.2........................................±0.25% $100.00 10.....................................................................±5% 10, 12, 15, 18, 20, 22, 24, 27, 30, 33, 39, 47 56, 68, 82, 100.................................................±5% $100.00 For Online Kit Orders, Catalog & Application Notes, Visit: www.avx.com The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 010621 – rf microwave products – 511
600S1R2AT250XT
物料型号:600S系列,属于RF/Microwave Multilayer Capacitors (MLC),由Kyocera和AVX生产。
器件简介:这些是超低等效串联电阻(ESR)、高Q值、NPO介质的射频/微波多层陶瓷电容器。
引脚分配:文档中没有明确提到引脚分配,但通常这类电容器是表面贴装的,具有两个端子用于连接。
参数特性: - 最低的ESR在同类产品中 - 最高的工作电压在同类产品中 - 250V - 标准EIA尺寸:0603 - 电容值范围:0.1到100pF - 公差:见电容值图表 - 工作电压(WVDC):250V - 品质因数(Q):在1MHz时大于2000 - 工作温度范围:-55°C至+125°C(工作电压不降低) - 电容的温度系数(TCC):0±30 ppm/°C,-55°C至+125°C - 介质耐电压(DWV):WVDC的2.5倍,持续5秒 - 老化:无 - 压电效应:无
功能详解: - 应用于滤波器网络、匹配网络、高Q频率源、调谐、耦合、旁路和直流阻断。
应用信息: - 用于蜂窝基站、用户基础的无线设备、宽带无线服务、Wi-Fi (802.11)、卫星、公共安全无线电通信等。
封装信息: - 提供标准EIA尺寸:0402、0603、0805。 - 包装选项包括胶带和卷轴、垂直方向胶带和卷轴。
环境特性: - 热冲击:5个周期,-55°C至125°C - 耐湿性:Mil-STD-202, 方法106 - 寿命测试:在125°C下2000小时,2倍WVDC - 可焊性:端头覆盖率超过90% - 端头强度:典型值4磅,最小值2磅 - 军事认可:DSCC图纸编号05002
电气规格详细列出了电容值、公差、工作电压、品质因数、操作温度范围、电容的温度系数、介质耐电压、老化和压电效应等参数。
600S1R2AT250XT 价格&库存
很抱歉,暂时无法提供与“600S1R2AT250XT”相匹配的价格&库存,您可以联系我们找货
