YAGEO CORPORATION MULTILAYER CERAMIC CHIP CAPACITOR
Multilayer Ceramic
Chip Capacitor
CC Series
FEATURES
Standard EIA Chip Size Available
Wide Range of Capacitance 0.47pF~10uF is Available for Various Circuit Needs
The CC Series is Available in Both Paper and Plastic Embossed Tape and Reel Packaging
for Automatic SMD Placement
Rugged Termination is Capable to Use at Both Reflow and Wave Soldering System
INTRODUCTIONS
Yageo CC Series MLCC is Made by Either Pd/
Ag or Nickel Electrode System and Offering
Cera
mic
Full Range of Chip Ceramic Capacitor in 10,
Body
16, 25, 50, 100, 200, 250, 500V Ratings.
The Dielectric Material of CC Series Ranging is
involved NP0, X7R, Y5V.
The CC Series Chip Capacitor Has Much
Electrodes
Lower ESR and ESL Than Most Leaded Type
Metalization
Capacitor, and Its Lower Dissipation Factor
Nickel Barrier Layer
Leads to Lower Power is Wasted Than
Aluminum Electrolytic and Tantalum Capacitors.
Solder Plated (Pure Sn)
DIMENSIONS
Unit : mm
T
W
L1 : L2
L3
STYLE
L
W
Min.
Max.
Min.
Max.
Min.
CC0402
1.0± 0.05
0.5± 0.05
0.45
0.55
0.15
0.30
0.40
CC0603
1.6± 0.10
0.8± 0.07
0.73
0.87
0.20
0.60
0.40
CC0805
2.0± 0.10
1.25± 0.10
0.50
1.35
0.25
0.75
0.55
CC1206
3.2± 0.15
1.6± 0.15
0.50
1.75
0.25
0.75
1.40
CC1210
3.2± 0.20
2.5± 0.20
0.50
1.80
0.25
0.75
1.40
CC1812
4.5± 0.20
3.2± 0.20
0.50
1.80
0.25
0.75
2.20
T
L1
L3
L
L2
30
ELECTRICAL CHARACTERISTICS
CAHRACTERISTICS
REQUIREMENT
CLASS I
NP0
TEST CONDITIONS
Operation Temperture Range
Temperature
Characteristic/Coefficient (TC)
Capacitance Tolerance
Dissipation Factor (Tanδ)
Insulation Resistance (IR)
Dielectric Withstanding Voltage
With Respect to 20ºC (25ºC for Y5V)
Within Operation Temperature Range
NP0 :
C ≤ 1000pF; 1Vrms/1MHz
-55ºC to 125ºC
NP0 16V, 0± 60ppm/K
NP0 > 16V, 0± 30ppm/K
In Accordance with Specification
C < 10pF :
Tanδ ≤ 10 (3/C+0.7) x 10 -4
or 30 x 10-4
C > 1000pF; 1Vrms/1kHz
X7R/Y5V :
1Vrms/1kHz
Whichever is Less
C ≥ 10pF
Tanδ ≤ 10 x 10-4
At Ur (Rated Voltage) for
1 Minute
500V for Ur ≥ 500V
At 2.5Ur (for Ur ≤ 100V)
1.5Ur + 100V (for Ur > 100V)
Rins ≥ 10GΩ or
Rins x C ≥ 500s
Whichever is Less
No Breakdown
CLASS II
X7R
Y5V
-55ºC to 125ºC
± 15%
-25ºC to 85ºC
+30% to -80%
Ur = 10V; Tanδ ≤ 5%
Ur = 10V; Tanδ ≤ 12.5%
Ur = 16V; Tanδ ≤ 3.5%
Ur = 16V; Tanδ ≤ 9% or ≤ 12.5%
Depending on Capacitance Value
Ur ≥ 25V; Tanδ ≤ 2.5%
Ur ≥ 25V; Tanδ ≤ 5% or ≤ 7%
Rins ≥ 10GΩ or
Rins x C ≥ 100s
Whichever is Less
Rins ≥ 10GΩ or
Rins x C ≥ 500s
Whichever is Less
ENVIRONMENTED CHARACTERISTICS
IEC
384-10
4.9
4.10
TEST ITEMS
Bending
Resistance to
Soldering Heat
Solderability
4.11
4.12
Rapid Change
of Temperature
4.14
Damp Heat,
Steady State
4.15
CONDITIONS
Bending Rate 1mm/s, Jig.
Radius 340mm
260 ± 5ºC for 10± 0.5s in Static
Soldering Bath
235 ± 5ºC for 2± 0.5s in a Static
Soldering Bath
NP0/X7R :
-55ºC to +125ºC, 5Cycles
Y5V : -25ºC to +85ºC, 5Cycles
At 40ºC, 90 to 95% R.H. and Ur
Applied (Max. 500V, No Voltage
for Ur ≥ 1000V) for 56 Days
(500 Hours for Y5V)
REQUIREMENT
NP0
∆C/C ≤ 1%
Y5V
∆C/C ≤ 20%
∆C/C ≤ 0.5% or 0.5pF
-5% ≤ ∆C/C ≤ 10%
Whichever is Greater
75% Minimum Coverage of Metallic Area
-10% ≤ ∆C/C ≤ 20%
∆C/C ≤ 1% or 1pF
∆C/C ≤ 15%
∆C/C ≤ 20%
∆C/C ≤ 15%
∆C/C ≤ 30%
Tanδ : ≤ 5%, 7%
IR : 1000MΩ or RxC ≥ 25s
Whichever is Less
∆C/C ≤ 20%
Tanδ : ≤ 7%, 12.5%, 15%
Whichever is Less
∆C/C ≤ 30%
Tanδ : ≤ 5%, 7%
IR : 2000MΩ or RxC ≥ 50s
Whichever is Less
Whichever is Less
∆C/C ≤ 2% or 1pF
Tanδ : ≤ 2 x Specified Value
IR : 2500MΩ or RxC ≥ 25s
Whichever is Less
At Upper Category Temperature,
∆C/C ≤ 2% or 1pF
2 x Ur Applied (1.5Ur for Ur > 50V, Whichever is Greater
1.2 x Ur for Ur ≥ 1000V)
Applied for 1000 Hours
IR : 4000MΩ or RxC ≥ 40s
Whichever is Less
Endurance
X7R
∆C/C ≤ 10%
CAPACITANCE - TEMPERATURE CHARACTERISTICS
∆C/C (%)
NPO
∆C/C (%)
0.40
15
0.20
10
0.10
5
0.00
-5
-0.20
-10
-0.30
-15
-0.40
X7R
40
30
-20
-30
-40
-50
-60
-70
-80
-20
-80 -60 -40 -20 0 20 40 60 80 100 120 140
Temperature (deg.C)
Y5V
∆C/C (%)
Temperature (deg.C)
-40
-20
60
80
100
Temperature (deg.C)
31
SPECIFICATION & PACKING
Tape Width : 8mm
NP0
16V
CAP.
CODE 15~17
CC0402
(pF) 270
271
0.5± 0.05
330
331
390
391
470
471
560
561
680
681
820
821
1000
102
1200
122
1500
152
1800
182
2200
222
2700
272
3300
332
CC0603
In Columns :
Thickness Class
0.8± 0.07
THICKNESS CLASS AND PACKAGING QUANTITIES
8mm Tape Width Quantity Per Reel
180mm/7”
330mm/13”
Quantity Per Bulk Case
Paper
Paper
CC0402
CC0603
0.5± 0.05
10000
50000
50000
0.8± 0.07
4000
15000
15000
Thickness
Classes (mm)
32
Tape Width : 8mm
NP0
25V
CAP.
CODE 15~17
CC0402
CC0603
CC0805
(pF) 270
271
0.5± 0.05
330
331
390
391
470
471
560
561
680
681
820
821
1000
102
1200
122
1500
152
1800
182
2200
222
2700
272
3300
332
0.85± 0.1
3900
392
1.25± 0.1
4700
472
5600
562
6800
682
8200
822
10000
103
12000
123
15000
153
18000
183
22000
223
CC1206
CC1210
In Columns :
Thickness Class
0.8± 0.07
0.85± 0.1
0.5 to 1.0
0.9 to 1.3
Thickness
Classes (mm)
180mm/7”
330mm/13”
Paper
Blister
Paper
Blister
CC0402
CC0603
CC0805
0.5± 0.05
10000
50000
50000
0.8± 0.07
4000
15000
15000
0.85± 0.1
4000
15000
8000
0.5 to 1.0
4000
10000
0.9 to 1.3
3000
10000
1.25± 0.1
3000
10000
5000
33
Tape Width : mm
NP0
TAPE WIDTH
8
12
50V
50V
CAP.
CODE 15~17
CC0402
CC0603
CC0805
CC1206
(pF) 0.47
R47
0.5± 0.05
0.8± 0.07
0.6± 0.1
0.6± 0.1
0.56
R56
0.68
R68
0.82
R82
1.0
1R0
1.2
1R2
1.5
1R5
1.8
1R8
2.2
2R2
2.7
2R7
3.3
3R3
3.9
3R9
4.7
4R7
5.6
5R6
6.8
6R8
8.2
8R2
10
100
12
120
15
150
18
180
22
220
27
270
33
330
39
390
47
470
56
560
68
680
82
820
100
101
120
121
150
151
180
181
220
221
270
271
330
331
390
391
470
471
CC1210
In Columns :
Thickness Class
CC1812
34
Tape Width : mm
NP0
TAPE WIDTH
CAP.
CODE 15~17
(pF) 560
561
680
681
820
821
1000
102
1200
122
1500
152
1800
182
2200
222
2700
272
3300
332
3900
392
4700
472
5600
562
6800
682
8200
822
10000
103
12000
123
15000
153
18000
183
22000
223
8
12
50V
50V
CC0402
CC0603
CC0805
CC1206
CC1210
CC1812
0.5 to 1.0
0.85± 0.1
1.25± 0.1
0.5 to 1.0
0.85± 0.1
1.5± 0.1
0.9 to 1.3
12mm Tape Width
Quantity Per Reel
180mm/7”
Thickness
Classes (mm) Paper
330mm/13”
180mm/7”
Blister
Paper
Blister
Blister
CC0402
CC0603
CC0805
0.5± 0.05
10000
50000
50000
0.6± 0.1
4000
20000
10000
0.8± 0.07
4000
15000
15000
0.85± 0.1
4000
15000
8000
0.5 to 1.0
4000
10000
2000
0.9 to 1.3
3000
10000
1500
1.15± 0.1
3000
10000
1.25± 0.1
3000
10000
5000
35
NP0
TAPE WIDTH
CAP.
CODE 15~17
(pF) 10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
390
470
560
680
820
1000
1200
1500
1800
2200
2700
3300
3900
4700
5600
6800
8200
10000
12000
15000
18000
22000
100
120
150
180
220
270
330
390
470
560
680
820
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
Tape Width : mm
8
100V
CC0603
CC0805
CC1206
0.8±0.07
0.6± 0.1
0.6± 0.1
12
100V
CC1812
CC1210
In Columns :
Thickness Class
0.85± 0.1
1.25± 0.1
0.85± 0.1
1.15± 0.1
0.5 to 1.0
0.5 to 1.0
0.9 to 1.3
Thickness
Classes (mm)
0.6± 0.1
0.8± 0.07
0.85±0.1
0.5 to 1.0
0.9 to 1.3
1.15±0.1
1.25±0.1
180mm/7”
Paper
Blister
4000
4000
4000
4000
3000
3000
3000
330mm/13”
Paper
20000
15000
15000
Blister
10000
10000
10000
10000
12mm Tape Width
Quantity Per Reel
180mm/7”
Blister
2000
1500
CC0603
CC0805
10000
15000
8000
5000
36
NP0
TAPE WIDTH
CAP.
(pF) 10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
390
470
560
680
820
1000
1200
1500
1800
2200
2700
3300
3900
4700
5600
CODE 15~17
100
120
150
180
220
270
330
390
470
560
680
820
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
8
200V
CC0805
0.6± 0.1
Tape Width : mm
CC1206
0.6±0.1
CC1210
12
200V
CC1812
8
500V
CC1206
0.6± 0.1
CC1210
12
500V
CC1812
In Columns :
Thickness Class
0.8 to 1.0
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.1
1.15± 0.1
0.9 to 1.3
1.15± 0.1
0.8 to 1.0
0.9 to 1.3
1.2 to 1.75
0.9 to 1.3
0.8 to 1.0
0.9 to 1.3
Thickness
Classes (mm)
0.6± 0.1
0.85± 0.07
0.8 to 1.0
0.9 to 1.3
1.15± 0.1
1.25± 0.1
1.2 to 1.75
180mm/7”
Paper
Blister
4000
4000
4000
3000
3000
3000
2500
330mm/13”
Paper
20000
15000
Blister
10000
10000
10000
10000
10000
12mm Tape Width
Quantity Per Reel
180mm/7”
Blister
2000
1500
1200
CC0805
10000
8000
5000
37
Tape Width : 8mm
X7R
10V
CAP.
CODE 15~17
CC0603
(pF) 150000
154
0.8±0.07
CC0805
220000
224
0.6± 0.1
330000
334
0.85± 0.1
470000
474
680000
684
1000000
105
1500000
155
2200000
225
3300000
335
4700000
475
CC1206
1.25± 0.1
In Columns :
Thickness Class
0.85± 0.1
1.15± 0.1
1.60± 0.15
180mm/7”
330mm/13”
Thickness
Classes (mm)
Paper
Blister
Paper
Blister
CC0603
CC0805
0.6± 0.1
4000
20000
10000
0.8± 0.07
4000
15000
15000
0.85±0.1
4000
15000
8000
1.15±0.1
3000
10000
1.25±0.1
3000
10000
5000
1.60±0.15
2500
7000
38
Tape Width : 8mm
X7R
16V
CAP.
CODE 15~17
(pF) 3300
332
4700
472
6800
682
10000
103
15000
153
22000
223
33000
333
47000
473
68000
683
100000
104
150000
154
220000
224
330000
334
470000
474
680000
684
1000000
105
CC0402
25V
CC0603
CC0805
CC1206
CC0402
CC0603
CC0805
0.8± 0.07
0.6± 0.01
CC1206
CC1210
0.5± 0.05
0.5± 0.05
In Columns :
Thickness Class
0.8± 0.07
0.6± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.5 to 1.0
1.25± 0.1
1.15± 0.1
1.15± 0.1
8mm Tape Width
Quantity Per Reel
Thickness
Classes (mm)
180mm/7”
Paper
180mm/7”
Blister
Paper
330mm/13”
Blister
Blister
CC0402
CC0603
CC0805
0.5± 0.05
10000
50000
50000
0.6± 0.1
4000
20000
10000
0.8± 0.07
4000
15000
15000
0.85± 0.1
4000
15000
8000
0.5 to 1.0
4000
10000
0.9 to 1.3
3000
10000
1500
1.15± 0.1
3000
10000
1.25± 0.1
3000
10000
5000
1.2 to 1.75
2500
10000
39
Tape Width : mm
X7R
TAPE WIDTH
8
12
50V
CAP.
CODE 15~17
CC0402
CC0603
(pF) 100
101
0.5±0.05
0.8± 0.07
150
151
220
221
330
331
470
471
680
681
1000
102
1500
152
2200
222
3300
332
4700
472
6800
682
10000
103
15000
153
22000
223
33000
333
47000
473
68000
683
100000
104
150000
154
220000
224
330000
334
470000
474
680000
684
1000000
105
CC0805
CC1206
0.6± 0.1
0.85± 0.1
CC1210
8
12
50V
100V
CC1812
CC0805
CC1206
100V
0.6±0.1
0.85± 0.1
CC1210
CC1812
In Columns :
Thickness Class
0.5 to 1.0
0.85± 0.1
0.85± 0.1
0.5 to 1.0
1.25± 0.1
1.15± 0.1
0.9 to 1.3
0.9 to 1.3
1.15± 0.1
0.9 to 1.3
0.9 to 1.3
1.2 to 1.75
8mm Tape Width
Quantity Per Reel
Thickness
Classes (mm)
180mm/7”
Paper
180mm/7”
Blister
Paper
330mm/13”
Blister
Blister
CC0402
CC0603
CC0805
0.5± 0.05
10000
50000
50000
0.6± 0.1
4000
20000
10000
0.8± 0.07
4000
15000
15000
0.85±0.1
4000
15000
8000
0.5 to 1.0
4000
10000
0.9 to 1.3
3000
10000
1500
1.15±0.1
3000
10000
1.25±0.1
3000
10000
5000
1.2 to 1.75
2500
10000
40
Tape Width : mm
X7R
TAPE WISTH
8
12
8
12
200V
200V
500V
500V
CC1812
CC1206
CAP.
CODE 15~17
CC0805
(pF) 220
221
0.85± 0.1
330
331
470
471
680
681
1000
102
1500
152
2200
222
3300
332
4700
472
6800
682
10000
103
15000
153
22000
223
33000
333
47000
473
68000
683
100000
104
CC1206
CC1210
CC1210
CC1812
1.15± 0.1
0.85± 0.1
In Columns :
Thickness Class
0.9 to 1.3
1.25± 0.1
1.2 to 1.75
0.9 to 1.3
1.15± 0.1
0.9 to 1.3
0.9 to 1.3
12mm Tape Width
180mm/7”
Thickness
Classes (mm)
Quantity Per Reel
330mm/13”
Paper
Blister
Paper
Blister
180mm/7”
Blister
CC0805
0.85± 0.1
4000
15000
8000
0.9 to 1.3
3000
10000
15000
1.15± 0.1
3000
10000
1.25± 0.1
3000
10000
5000
1.2 to 1.75
2500
10000
Tape Width : 8mm
Y5V
10V
CAP.
CODE 15~17
CC0603
CC0805
(µF) 1.0
105
0.8± 0.07
0.85± 0.1
2.2
225
4.7
475
10
106
CC1206
In Columns :
Thickness Class
1.6± 0.15
180mm/7”
330mm/13”
Thickness
Classes (mm)
Paper
Blister
Paper
Blister
CC0603
CC0805
0.8± 0.07
4000
15000
15000
0.85± 0.1
3000
10000
5000
1.6± 0.15
2500
7000
41
Tape Width : 8mm
Y5V
16V
25V
CAP.
CODE 15~17
CC0402
CC0603
CC0805
(pF) 10000
103
0.5± 0.05
22000
223
47000
473
100000
104
220000
224
470000
474
0.85±0.1
1000000
105
1.25±0.1
2200000
225
4700000
475
CC1206
CC0603
CC0805
CC1206
0.6± 0.1
0.6± 0.1
0.8± 0.07
In Columns :
Thickness Class
0.8± 0.1
0.85± 0.1
1.25± 0.1
0.85±0.1
0.85± 0.1
1.15±0.1
1.15± 0.1
180mm/7”
330mm/13”
Thickness
Classes (mm)
Paper
Blister
Paper
Blister
CC0402
CC0603
CC0805
0.5 ± 0.05
10000
50000
50000
0.6 ± 0.1
4000
20000
10000
0.8 ± 0.07
4000
15000
15000
0.85 ± 0.1
4000
15000
8000
1.15 ± 0.1
3000
10000
1.25 ± 0.1
3000
10000
5000
Tape Width : 8mm
Y5V
50V
CAP.
CODE 15~17
CC0603
CC0805
(pF) 10000
103
0.8±0.07
0.6± 0.1
22000
223
47000
473
100000
104
220000
224
470000
474
1000000
105
CC1206
0.6± 0.1
0.85± 0.1
In Columns :
Thickness Class
0.85± 0.1
1.15± 0.1
180mm/7”
330mm/13”
Thickness
Classes (mm)
Paper
Blister
Paper
Blister
CC0402
CC0603
CC0805
0.5 ± 0.05
10000
50000
50000
0.6 ± 0.1
4000
20000
10000
0.8 ± 0.07
4000
15000
15000
0.85 ± 0.1
4000
15000
8000
1.15 ± 0.1
3000
10000
1.25 ± 0.1
3000
10000
5000
42
EMBOSSED TAPING
Unit : mm
Feeding Hole
Chip Pocket
øD0
E
A
F
B
t
P1
Chip Component
P2
B
øD1
P0
Tape Running Direction
STYLE
A
0805
B
1.45± 0.1
W
2.2± 0.1
8.0± 0.2
E
1.75± 0.1
F
3.5± 0.05
P0
P1
4± 0.1
P2
4± 0.1
øD0
2± 0.05
øD1
Tmax
+0.1
-0
≥1
2.0± 0.1
+0.1
-0
1.5
1206
1.9± 0.15
3.5± 0.15
8.0± 0.2
1.75± 0.1
3.5± 0.05
4± 0.1
4± 0.1
2± 0.05
1.5
≥1
2.5± 0.1
1210
3.0 (Max.)
3.0 (Max.)
8.1± 0.2
1.75± 0.1
3.5± 0.05
4± 0.1
4± 0.1
2± 0.05
1.5+0.1
-0
≥1
3.5 (Max.)
2± 0.05
+0.1
-0
1.5
3.5 (Max.)
1812
4.0 (Max.)
4.0 (Max.)
12.0± 0.2
1.75± 0.1
5.5± 0.05
4± 0.1
8± 0.1
1.5
RECOMMENDED LAND PATTERN DESIGN
Unit : mm
REFLOW SOLDERING
A
B
D
C
FOOTPRINT DIMENSION (mm)
PLACEMENT
STYLE
A
B
C
D
ACCURACY (mm)
0402
1.5
0.5
0.5
0.5
± 0.15
0603
2.3
0.5
0.9
0.9
± 0.25
0805
2.8
0.9
0.95
1.4
± 0.25
1206
4.0
2.0
1.0
1.8
± 0.25
1210
4.0
2.0
1.0
2.7
± 0.25
1808
5.4
3.3
1.05
2.3
± 0.25
1812
5.4
3.3
1.05
3.5
± 0.25
WAVE SOLDERING
PLACEMENT
STYLE
A
B
C
D
ACCURACY (mm)
0603
2.7
0.9
0.9
0.8
± 0.25
0805
3.4
1.3
1.05
1.3
± 0.25
1206
4.8
2.3
1.25
1.7
± 0.25
1210
5.3
2.3
1.50
2.6
± 0.25
Soldering Pad
TAPING REEL
T
øB
øC
STYLE
0402/0603/0805/1206
øA
TAPE WIDE
8
øA
øB
+0
-3
180
øC
W
TMax.
20.5
9.0± 0.3
11.4± 1
60
+1
-0
+1
-0
20.5
9.0± 0.3
11.4± 1
20.5
12.4+2
-0
18.4 (Max.)
0402/0603/0805/1206
8
330± 3
60
1812
12
180
62± 1.5
W
43
TAPING REEL
Feeding Hole
Chip Pocket
øD0
E
A
F
B
P1
Chip Component
t
P2
B
P0
STYLE
A
B
W
E
F
P0
P1
P2
øD0
Tmax
0402
0.62± 0.05
1.12± 0.05
8.0± 0.2
1.75± 0.1
3.5± 0.05
4± 0.05
2± 0.05
2± 0.05
1.5+0.1
-0
0.6± 0.05
0603
1.10± 0.1
1.9± 0.1
8.0± 0.2
1.75± 0.1
3.5± 0.05
4± 0.1
4± 0.1
2± 0.05
1.5+0.1
-0
1.0± 0.05
0805
1.65± 0.1
2.4± 0.1
8.0± 0.2
1.75± 0.1
3.5± 0.05
4± 0.1
4± 0.1
2± 0.05
1.5+0.1
-0
1.0± 0.05
1206
2.0± 0.1
3.5± 0.1
8.0± 0.2
1.75± 0.1
3.5± 0.05
4± 0.1
4± 0.1
2± 0.05
1.5+0.1
-0
1.0± 0.05
TAPING REEL
20º Max. Component
Rotation
Typical Component
Cavity Center Line
No Components
Min. 50
Components
No Components
Min. 50
Start
Typical
Component
Center Line
Top Cover Tape
Empty Components
Pockets Sealed
with Cover Tape
BULK CASSETTE
PAPER CARRIER
EMBOSSED PLASTIC CARRIER
This slot to be coupled
with bulk cassette.
Top and Bottom Cover
Tape Thickness .004 (0.1) Max.
Shutter
Knob
Paper Carrier
Top Cover Tape
Chip Component Inlet
Embossed
Carrier
Dimension of Bulk Case
110 x 36 x 12 mm ( L x W x T )
Bulk case was standardized in Mar. 1992 (EIA-7201).
Feeding End
Feeding End
YAGEO CORPORATION
1. SUBJECT : This specification applies on the chip capactor made by Yageo Corpration.
2. PART NUMBER : Part number of the chip capacitor is identified by the size, tolerance, packing, material and capacitor value.
Example :
CC
0805
K
K
X7R
B
9
Code 1~2
Series Name
Code 8
Packing Style
Code 9~11
TC Material
Code 13
Termination
CC = Multi-Layer
Chip Cap.
R = PaperTape Reel ϕ 7 inch
P = PaperTape Reel ϕ13 inch
K = Embossed Plastic
Tape Reel ϕ 7 inch
F = Embossed Plastic
Tape Reel ϕ 13 inch
C = Bulk Cassette
NPO
X7R
Y5V
B = Ni-Barrier
Code 3~6
Size Code
inches (mm)
0402
0603
0805
1206
1210
1812
A = ± 0.05pF
B = ± 0.10pF
C = ± 0.25pF
D= ± 0.5pF
F = ± 1%
0= x 1
1 = x 10
2
2 = x 10
3
x
3 = 10
4
4 = x 10
5
5 = x 10
6
6 = x 10
5 = 6.3V
6 = 10V
7 = 16V
8 = 25V
9 = 50V
0 = 100V
A = 200V
B = 500V
Y = 250V
G= ± 2%
J = ± 5%
K = ± 10%
M= ± 20%
Z = –20~+80%
104
Code 15~17
Capacitance Value
(2 Significant Digits
+No. of Zeros)
The 3rd Digit :
Letter R is Decimal Point
Code 12
Rated Voltage
Code 7
(1005)
(1608)
(2012)
(3216)
(3225)
(4532)
B
Code 14
Process Code
N= Non BME
B = BME
STANDARD SERIES OF VALUES
E6 SERIES
10
15
22
33
47
68
E12 SERIES
10
12
15
18
22
27
33
39
47
56
68
82
很抱歉,暂时无法提供与“CC0805GRNPOABN471”相匹配的价格&库存,您可以联系我们找货
