200B104MT50XT
200B104MT50XT
    ATC
    贴片电容(MLCC) 1111 100nF ±20% 50V BX
200B104MT50XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 200B Series BX Ceramic FEATURES • • • • • • • GENERAL DESCRIPTION Case B Size (.110” x .110”) Lowest ESR/ESL Rugged Construction Extended WVDC Available Capacitance Range 5000 pF to 0.1 µF Mid-K High Reliability PACKAGING OPTIONS KYOCERA AVX, the industry leader, offers new improved ESR/ESL performance for the 200 B Series Capacitors. This Series exhibits high volumetric efficiency with superior IR characteristics. Ceramic construction provides a rugged, hermetic package. Tape & Reel Typical functional applications: Bypass, Coupling and DC Blocking. Vertical Orientation Tape & Reel Cap-Pak® (100 pcs) Typical circuit applications: Switching Power Supplies and High Power Broadband Coupling. ENVIRONMENTAL CHARACTERISTICS ELECTRICAL SPECIFICATIONS Temperature Coefficient (TCC) ±15% maximum (-55°C to +125°C) Capacitance Range 510 pF to 0.01 μF From -55°C to +125°C Operating Temperature (No derating of working voltage). Dissipation Factor 2.5% max. @ 1 KHz Insulation Resistance (IR) 5000 pF to 0.1 MFd: 104 Megohms min. @ +25°C at rated WVDC. 103 Megohms min. @ +125°C at rated WVDC. Dielectric Absorption 2% Typical Working Voltage (WVDC) See Capacitance Values table Thermal Shock MIL-STD-202, Method 107, Condition A. Moisture Resistance MIL-STD-202, Method 106. Low Voltage Humidity MIL-STD-202, Method 103, Condition A, with 1.5 Volts DC applied while subjected to an environment of 85°C with 85% relative humidity for 240 hours min. Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C. 200% WVDC applied. Termination Styles Available in various surface mount styles. See Mechanical Configurations, page 3 Terminal Strength Terminations for chips and Pellets withstand a pull of 5 lbs. min., 10 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Test per MIL-STD-202, method 211 Dielectric Withstanding Case B: 250% of rated WVDC for 5 secs. Voltage (DWV) Aging Effects 3% maximum per decade hour. Piezoelectric Effects Negligible Capacitance Drift ± (0.02% or 0.02 pF), whichever is greater 482 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032521 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 200B Series BX Ceramic CAPACITANCE VALUES 562 5600 682 6800 822 8200 103 10,000 123 12,000 153 15,000 183 18,000 203 20,000 223 22,000 STD EXT.* K, M, N 50 100 CAP. CODE CAP. (pF) 273 27,000 333 33,000 393 39,000 473 47,000 503 50,000 563 56,000 683 68,000 823 82,000 104 100,000 TOL. RATED WVDC STD EXT.* 50 100 VOLTAGE 5000 RATED WVDC K, M, N EXTENDED 502 TOL. VOLTAGE CAP. (pF) EXTENDED CAP. CODE VRMS = 0.707 x WVDC • SPECIAL VALUES, TOLERANCES, HIGHER WVDC AND MATCHING AVAILABLE. PLEASE CONSULT FACTORY. * Extended WVDC offereing meets X7R characteristics HOW TO ORDER 200 B 822 M W 50 X T Series Packaging Case Size Capacitance Please see last Column Mechanical Configuration Table for other options EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Laser Marking (Optional) WVDC Capacitance Tolerance Code Code K M N Tol. ±10% ±20% ±30% T = Tape and Reel, 500 pc qty. TV = Vertical Orientation of Product Tape and Reel, 500 pc qty. Termination Style Code Please see 2nd Column Mechanical Configuration Table The above part number refers to a 200 B Series (case size B) 8200 pF capacitor, M tolerance (±20%), 50 WVDC, with W termination (Tin / Lead, Solder Plated over Nickel Barrier), laser marking and KYOCERA AVX Cap-Pac® packaging. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032521 – rf microwave products – 483 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 200B Series BX Ceramic MECHANICAL CONFIGURATION SERIES & CASE SIZE TERM. CODE 200B W CASE SIZE & TYPE OUTLINES W/T IS A TERMINATION SURFACE B Y W Solder Plate B 200B L Y P W Pellet B 200B T T L Y W Solderable Nickel Barrier B 200B T T L Y CA W Gold Chip L T TL LL WL .102 (2.59) max. Tin/Lead, Solder Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Vertical T&R, 1000 pcs or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 .110 +.035 -.010 (2.79 +0.89 -0.25) .110 ±.015 (2.79 ±0.38) .102 (2.59) Heavy Tin/Lead Coated, over Nickel Barrier Termination T&R, 1000 or 500 pcs Vertical T&R, 1000 pcs or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 .110 +.020 -.010 (2.79 +0.51 -0.25) .110 ±.015 (2.79 ±0.38) .102 (2.59) RoHS Compliant Tin Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Vertical T&R, 1000 pcs or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 .110 +.020 -.010 (2.79 +0.51 -0.25) .110 ±.015 (2.79 ±0.38) .102 (2.59) RoHS Compliant Gold Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Vertical T&R, 1000 pcs or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 Cap Pac, 20 pcs C20 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 .015 (0.38) ±.010 (0.25) max. TL WL .135 ±.015 (3.43 ±0.38) W T L Length (LL) .120 (3.05) max. T L LL AR .110 ±.015 (2.79 ±0.38) W B 200B .250 (6.35) min. Axial Ribbon B 200B LL RR W T L .110 ±.015 (2.79 ±0.38) WL TL LL WL L W T Radial Ribbon B 200B T T .093 ±. 005 .004 ± .001 (2.36 ± 0.13) (.102 ± .025) N/A AW Axial Wire WL L W .145 ±.020 (3.68 ±0.51) B .500 (12.7) LL L W LL • • T L L #26 AWG., .016 (.406) dia. nominal • T W • • 484 Thickness (TL) LL W L Radial Wire 200B Width (WL) .100 (2.54) max. LL RW Pkg Code .110 +.020 -.010 (2.79 +0.51 -0.25) TL LL WL Microstrip Pkg Type T B MS LEAD AND TERMINATION DIMENSIONS AND MATERIALS OVERLAP MATERIALS (Y) W L 200B BODY DIMENSIONS INCHES (mm) LENGTH WIDTH THICKNESS (L) (W) (T) LL W • T The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 200B Series BX Ceramic NON-MECHANICAL CONFIGURATION OUTLINES SERIES MIL-PRF- CASE SIZE W/T IS A TERM. & CASE 55681 & TYPE TERMINATION CODE SIZE SURFACE BODY DIMENSIONS INCHES (mm LENGTH (L) WIDTH (W) THICKNESS (T) LEAD AND TERMINATION DIMENSIONS AND MATERIALS OVERLAP (Y) B 200B WN Meets Rqmts. .110+.025 .110 ±.015 -.010 (2.79 (2.79 ±0.38) +0.64 -0.25) Y W Non-Mag Solder Plate T L B 200B PN Meets Rqmts. .110+.035 .110 ±.015 -.010 (2.79 (2.79 ±0.38) +0.89 -0.25) Y W Non-Mag Pellet T L Tin/Lead, Solder Plated over Non-Magnetic Barrier Termination .102 (2.59) max.. .015 (0.38) ±.010 (0.25) Heavy Tin/Lead, Coated over Non-Magnetic Barrier Termination B 200B TN Meets Rqmts. Non-Mag Solderable Barrier W T L B 200B MN Meets Rqmts. .110+.025 .110 ±.015 -.010 (2.79 (2.79 ±0.38) +0.64 -0.25) Y Length (LL) W T L .120 (3.05) max. TL LL Non-Mag Microstrip RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination TL LL WL WL W T L Pkg Type Pkg Code MATERIALS Width (WL) Thickness (TL) T&R, 1000 or 500 pcs Vertical T&R, 1000 pcs or 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs Vertical T&R, 1000 pcs or 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs Vertical T&R, 1000 pcs or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 Cap Pac, 20 pcs C20 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 B 200B 200B 200B AN FN RN Meets Rqmts. Meets Rqmts. Meets Rqmts. TL W T L Non-Mag Axial Ribbon B BN .093 ± .005 .004 ± . 001 (2.36 ± 0.13) (.102 ± .025) TL W T L .110 ±.015 (2.79 ±0.38) LL W Non-Mag Radial Ribbon B .250 (6.35) min. LL WL WL L T N/A .100 (2.54) max. LL W WL L T LL T Non-Mag Axial Wire B L W Meets Rqmts. .500 (12.7) min. .145 ±.020 (3.68 ±0.51) LL • • T L 200B .135 ±.015 (3.43 ±0.38) LL WL W #26 AWG., .016 (.406) dia. nominal LL W L • T Non-Mag RadialWire Additional lead styles available: Narrow Microstrip (DN), Narrow Axial Ribbon (GN) and Vertical Narrow Microstrip (HN). Other lead lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. • • L LL W • T The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – 485 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 200B Series BX Ceramic SUGGESTED MOUNTING PAD DIMENSIONS Dimensions are in inches. Pad Size Normal All Values High Density A Min. .120 .100 B Min. .050 .030 C Min. .075 .075 D Min. .175 .135 Pad Size Normal All Values High Density Horizontal Mount A Min. B Min. .130 .050 .110 .030 C Min. .075 .075 D Min. .175 .135 PERFORMANCE DATA ESR VS. CAPACITANCE AVX SERIES 200, CASE B 10 Q 1 ESR (Ohms) Q VS CAPACITANCE AVX SERIES 200, CASE B 0.1 30 MHz 30 MHz (Typical) 1 (Typical) 0.01 0.001 0.01 0.001 0.1 0.01 0.1 CAPACITANCE (mF) CAPACITANCE (mF) SERIES RESONANCE VS CAPACITANCE AVX SERIES 200, CASE B CURRENT RATING VS CAPACITANCE AVX SERIES 200, CASE B 100 RMS CURRENT (Amps) FREQUENCY (MHz) 1000 100 The current rating is based on a 65°C mounting surface and a device thermal resistance of 20°C/W. A power dissipation of 3W will result in a case temperature of 125°C. 10 30 MHz (Typical) 10 0.001 0.01 Dotted line = Power dissipation limited 0.1 1 0.001 CAPACITANCE (mF) 0.01 CAPACITANCE (mF) 486 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032521 – rf microwave products – 0.1
200B104MT50XT 价格&库存
很抱歉,暂时无法提供与“200B104MT50XT”相匹配的价格&库存,您可以联系我们找货
