SAFC1812X7R202-472KNE 数据手册
SAFC
SERIES
SAFETY CERTIFIED CAPACITORS
FEATURES:
• Multi-layer Ceramic Capacitors are safety standard
approved by IEC60384-14 and UL 60950-1
and UL60384-14
• UL Certified: E511154 & E511217
• TUV Certified: R50450826
PART NUMBER STRUCTURE
SAFC
1808
X7R
502
Series
Safety
Approved
MLCC
Size
1808
1812
2211
2208
2220
Temperature
Characteristic
(Dielectric)
C0G
X7R
Class
202 = X2
502 = X1/Y2
102
K
N
E
Capacitance
(picofarads)
1st two digits are
significant, followed by
number of zeroes.
R denotes decimal
e.g:
101 = 100pF
333 = 0.033uF, etc
Tolerance
J = 5%
K = 10%
M = 20%
Termination/Special
N = standard termination
X = Soft/Flex Termination
S = Arc Prevention Coating
Z=A
+ Soft/Flex Termination
Packaging
E = Embossed Tape
(7” reels)
Example P/N: SAFC1808X7R502-102KNE
APPLICATIONS
The X2 and X1/Y2 (250Vac) are specially designed for use in modems, telephone and telecommunication equipment,
electronic equipment for lighting and surge protection, EMI filtering and Isolation.
PERFORMANCE SPECIFICATIONS
Rated Voltage (Ur)
250Vac
Temperature Coefficient
C0G: < 30ppm/˚C , -55˚C ~ +125˚C (EIA Class I)
X7R: < ±15% , -55˚C ~ +125˚C (EIA Class II)
Capacitance Range
X1/Y2, 250Vac: 2pF ~ 4700pF
X2, 250Vac: 2pF ~ 56nF
Quality and Dissipation Factor
C0G: Q ≥ 1000 , X7R : D.F. ≤ 2.5%
Environmental Testing
-55˚C (cold); +125˚C (hot); 21 days under damp heat (steady state)
Insulation Resistance
≥ 10GΩ
Voltage Rating DC
X1/Y2: 2KV Vdc
X2: 1.5KV Vdc
Voltage Proof
(Dielectric Withstanding Voltage)
X2 Capacitor: 1075Vdc (4.3Ur)
X1/Y2 Capacitor: 1500Vac min.
Peak Impulse Voltage
X2: 2.5KV , X1/Y2: 5KV, each per IEC60384-14:2013
Operating Temperature
-55˚C to +125˚C
Dielectric Aging
C0G: 0 % , X7R: 1.0 % per decade hr., typical
Test Conditions per IEC60384-14
Voltage: 1.0 Vrms
C < 100pF at 1MHz
C ≥ 100pF at 1KHz
SAFETY DETAILS OF SPECIFICATIONS
IEC 660384-14: 2013, 4th Edition
EN 60384-1 4: 2013, 4th Edition
Meets the electrical requirements and certification for equipment requiring Class X1/Y2
and X2 devices.
UL 60384-14 : 2014, 2nd Edition
Component certified for equipment requiring UL-60384-14 compliance
UL 60950-1 : 2007, 2nd Edition
TNV/SELV isolation capacitors certified To UL 60950-1
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 09/2020-A
1
SAFC
SERIES
DIMENSIONS
Unit: inches (mm)
SIZE
L
W
T (MAX)
EB (MIN)
1808
0.18 ± 0.011
(4.60 ± 0.30)
0.08 ± 0.008
(2.00 ± 0.20)
0.088
(2.20)
0.008
(0.20)
1812
0.18 ± 0.011
(4.60 ± 0.30)
0.12 ± 0.012
(3.20 ± 0.30)
0.104
(2.60)
0.008
(0.20)
2208
0.22 ± 0.016
(5.70 ± 0.40)
0.08 ± 0.008
(2.00 ± 0.20)
0.088
(2.20)
0.012
(0.30)
2211
0.22 ± 0.016
(5.70 ± 0.40)
0.11 ± 0.012
(2.80 ± 0.30)
0.120
(3.00)
0.012
(0.30)
2220
0.22 ± 0.016
(5.70 ± 0.40)
0.20 ± 0.016
(5.00 ± 0.40)
0.120
(3.00)
0.012
(0.30)
VOLTAGE AND CAPACITANCE RANGE
X2 CLASS - C0G DIELECTRIC
Values that are typically available.
SIZE
Code
1808
Value
Rated Max
Voltage (Vac)
Certificate
TUV/UL
2R0
2pF
250
5R0
5pF
250
TUV/UL
6R8
6.8pF
250
TUV/UL
8R2
8.2pF
250
TUV/UL
100
10pF
250
TUV/UL
120
12pF
250
TUV/UL
150
15pF
250
TUV/UL
180
18pF
250
TUV/UL
220
22pF
250
TUV/UL
270
27pF
250
TUV/UL
330
33pF
250
TUV/UL
360
36pF
250
TUV/UL
390
39pF
250
TUV/UL
470
47pF
250
TUV/UL
560
56pF
250
TUV/UL
680
68pF
250
TUV/UL
820
82pF
250
TUV/UL
101
100pF
250
TUV/UL
121
120pF
250
TUV/UL
131
130pF
250
TUV/UL
151
150pF
250
TUV/UL
181
180pF
250
TUV/UL
221
220pF
250
TUV/UL
271
270pF
250
TUV/UL
331
330pF
250
TUV/UL
391
390pF
250
TUV/UL
471
470pF
250
TUV/UL
561
560pF
250
TUV/UL
681
680pF
250
TUV/UL
821
820pF
250
TUV/UL
102
1000pF
250
TUV/UL
122
1200pF
250
152
1500pF
250
182
1800pF
250
222
2200pF
250
272
2700pF
250
332
3300pF
250
472
4700pF
250
1812
2208
2211
2220
Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available.
Web: www.venkel.com
Rev: 09/2020-A
2
SAFC
SERIES
X2 CLASS - X7R DIELECTRIC
SIZE
Code
1808
Value
Rated Max
Voltage (Vac)
Certificate
151
150pF
250
TUV/UL
181
180pF
250
TUV/UL
221
220pF
250
TUV/UL
271
270pF
250
TUV/UL
331
220pF
250
TUV/UL
391
390pF
250
TUV/UL
471
470pF
250
TUV/UL
561
560pF
250
TUV/UL
681
680pF
250
TUV/UL
821
820pF
250
TUV/UL
102
1000pF
250
TUV/UL
122
1200pF
250
TUV/UL
152
1500pF
250
TUV/UL
182
1800pF
250
TUV/UL
222
2200pF
250
TUV/UL
272
2700pF
250
TUV/UL
332
3300pF
250
TUV/UL
472
4700pF
250
TUV/UL
103
0.01uF
250
TUV/UL
TUV/UL
153
0.015uF
250
223
0.022uF
250
TUV/UL
333
0.033uF
250
TUV/UL
473
0.047uF
250
563
0.056uF
250
1812
2208
2211
2220
Web: www.venkel.com
Rev: 09/2020-A
3
SAFC
SERIES
X1/Y2 CLASS - C0G DIELECTRIC
SIZE
Code
1808
Value
Rated Max
Voltage (Vac)
Certificate
2R0
2pF
250
TUV/UL
5R0
5pF
250
TUV/UL
6R8
6.8pF
250
TUV/UL
8R2
8.2pF
250
TUV/UL
100
10pF
250
TUV/UL
120
12pF
250
TUV/UL
150
15pF
250
TUV/UL
TUV/UL
180
18pF
250
220
22pF
250
TUV/UL
270
27pF
250
TUV/UL
330
33pF
250
TUV/UL
360
36pF
250
TUV/UL
390
39pF
250
TUV/UL
470
47pF
250
TUV/UL
560
56pF
250
TUV/UL
680
68pF
250
TUV/UL
820
82pF
250
TUV/UL
101
100pF
250
TUV/UL
121
120pF
250
TUV/UL
131
130pF
250
TUV/UL
151
150pF
250
TUV/UL
181
180pF
250
TUV/UL
221
220pF
250
TUV/UL
271
270pF
250
TUV/UL
331
330pF
250
TUV/UL
391
390pF
250
TUV/UL
471
470pF
250
TUV/UL
561
560pF
250
TUV/UL
681
680pF
250
TUV/UL
821
820pF
250
TUV/UL
102
1000pF
250
TUV/UL
122
1200pF
250
TUV/UL
1812
2208
2211
2220
Web: www.venkel.com
Rev: 09/2020-A
4
SAFC
SERIES
X1/Y2 CLASS - X7R DIELECTRIC
SIZE
1808
Code
Value
Rated Max
Voltage (Vac)
2R0
2pF
250
5R0
5pF
250
6R8
6.8pF
250
8R2
8.2pF
250
100
10pF
250
120
12pF
250
1812
2208
2211
2220
Certificate
150
15pF
250
180
18pF
250
220
22pF
250
270
27pF
250
330
33pF
250
360
36pF
250
TUV/UL
390
39pF
250
TUV/UL
470
47pF
250
TUV/UL
560
56pF
250
TUV/UL
680
68pF
250
TUV/UL
820
82pF
250
TUV/UL
101
100pF
250
TUV/UL
121
120pF
250
TUV/UL
131
130pF
250
TUV/UL
151
150pF
250
TUV/UL
181
180pF
250
TUV/UL
221
220pF
250
TUV/UL
271
270pF
250
TUV/UL
331
330pF
250
TUV/UL
391
390pF
250
TUV/UL
471
470pF
250
TUV/UL
561
560pF
250
TUV/UL
681
680pF
250
TUV/UL
821
820pF
250
TUV/UL
102
1000pF
250
TUV/UL
122
1200pF
250
TUV/UL
152
1500pF
250
TUV/UL
182
1800pF
250
TUV/UL
222
2200pF
250
TUV/UL
272
2700pF
250
TUV/UL
332
3300pF
250
TUV/UL
472
4700pF
250
TUV/UL
Web: www.venkel.com
Rev: 09/2020-A
5
SAFC
SERIES
APPLICATION - EXAMPLE CIRCUIT
Y
Y
Tip & Ring
TNV
SELV
X
1st
X : Across The Line
Y : Line By Pass
2nd
TEST SPECIFICATIONS
NO.
ITEM
SPECIFICATION
Appearance
No mechanical damage shall occur
Capacitance
1
Resistance to
soldering heat
≤ ± 10% of initial value
Class II (X7R)
≤ ± 20% of initial value
More than 1,000MΩ
Voltage)
To satisfy the specified initial value
Appearance
Characteristic
Cap. Change
Class I (C0G)
≤ ± 15% of initial value
Class II (X7R)
Q Class I
More Than 30pF : Q ≥ 350
30pF and below: Q ≥ 275 + 2.5 x C (C:pF)
Tan 0 Class II
Maximum 5.0%
More than 1,000MΩ
Voltage)
Appearance
Capacitance
Endurance
Class I (C0G)
Voltage Proof
3
Cap. Change
Capacitance
Damp Heat /
Steady State
Characteristic
Q/Tanδ
Voltage Proof
2
TEST CONDITION
Characteristic
Cap. Change
Class I (C0G)
Class II (X7R)
≤ ± 25% of initial value
Q Class I
More Than 30pF : Q≥350
Tan 0 Class II
Maximum 5.0%
More than 1,000MΩ
Class II capacitor shall be set for 48 ± 4 hours at
room temperature after one hour heat treatment at
150 + 0/-10°C before initial measure.
Preheat : At 150 ± 10°C For 60 ~120sec.
Dip : Solder Temperature of 260 ± 5°C
Dip Time: 10 ± 1sec.
Solder : H63A
Flux : Rosin
Measure at room temp. after cooling for:
Class I : 24 ± 2 Hours
Class II : 48 + 4 Hours
Temperature : 40°C
Humidity: 95 %RH
Test Time : 500hr (21days)
The capacitors with rated voltage (250Vac) applied.
Class I : 24 ± 2 Hrs
Class II : 48 ± 4 Hrs
Solder the Capacitor on P.C. Board shown before
testing.
Impulse Voltage
Each individual capacitor shall be subjected to a
2.5KV(X2) and 5KV(X1/Y2) impulse for three times.
Then the capacitors are applied to life test.
T1 = 1.2us is between 10% to 90%
T2 = 50us is between 50% to 50%
100%
90
50
10
T1
T2
Voltage Proof
Voltage)
Temperature : 125°C
Test Time : 1 000hrs
Applied Voltage :
Class X Capacitors :1.25Ur (312.5Vac)
Class Y Capacitors :1.70Ur (425Vac)
Except that once every hour the voltage shall be
increased to 1 000Vrms for 0.1 s.
Web: www.venkel.com
Rev: 09/2020-A
6
SAFC
SERIES
TEST SPECIFICATIONS
FIG.1
P.C.Board for Bending Strength Test (referring to IEC384-14 and EN132400)
Solder Resist
Copper
C
40mm
A
B
100mm
1.6mm
Material : Glass Epoxy Substrate
Copper (Thickness : 0.035mm)
Solder Resist
FIG.2
Test Substrate
C
10mm
A
Solder Resist
Thickness : 1.6 mm
3mm
B
Unit: mm
TYPE
A
B
C
1808
3.5
7.0
2.5
1812
3.5
7.0
3.7
2208
4.5
8.0
2.5
2211
4.5
8.0
3.0
2220
4.5
8.0
5.6
Web: www.venkel.com
Rev: 09/2020-A
7
SAFC
SERIES
NO.
ITEM
SPECIFICATION
TEST CONDITION
1
Visual
No abnormal exterior appearance
Visual Inspection
2
Dimension
See Page2
Visual Inspection
3
Capacitance
Within the specified tolerance
Char.
Class I (C0G)
C0G
4
Q and Dissipation Factor
Frequency
Voltage
1.0 ± 0.2Vrms
More than 30pF : Q ≥ 1000
C≤100pF
1MHz ±10%
30pF & below: Q ≥ 400 + 20C (C:pF)
C≤100pF
1KHz ±10%
Class II (X7R)
Maximum : 2.5% (0.025)
X7R
1KHz ±10%
1.0 ± 0.2Vrms
After performing deage at 150 ± 5% for 30min.
and placement room temperature for 24± 2hr.
5
6
7
Minimum 10,000MΩ
Applied Voltage:
Applied Voltage: 500V Charge Time : 60sec.
Voltage Proof
No dielectric breakdown or mechanical breakdown
Applied Voltage:
X Capacitor: Applied Voltage 1075Vdc(4.3Ur)
Y Capacitor: Applied Voltage 1500Vac
For 1min. Is Applied Less Than 50mA Current
More than 90% of the terminal surface is to be
soldered newly, so metal part does not come out Solder Temperature: 245 ± 5˚C
Dip Time: 5 ± 0.5 sec.
or dissolve
Immersing Speed: 25 ± 10% mm/s
Solderability
Solder: H63A
Flux: Rosin
Preheat : At 80 ~120˚C For 10 ~30sec.
Appearance
Capacitance
8
Resistance to
Flexure of Substrate
Class II (X7R)
≤ ± 12.5% of initial value
No indication of peeling shall occur on
the terminal electrode.
Capacitance
Characteristic
Cap. Change
Class I (C0G)
≤ ± 5% of initial value
Class II (X7R)
Q Class I
Q / Tanδ
Voltage Proof
Voltage)
Appearance
Capacitance
Resistance to
Soldering Heat
≤ ± 5.0% of initial value
Appearance
10
Class I (C0G)
Voltage)
Robustness of Shear
Cap. Change
Q / Tanδ
Voltage Proof
9
Characteristic
Characteristic
Cap. Change
Class I (C0G)
Class II (X7R)
Q / Tanδ
More than 1,000MΩ
Voltage Proof
Voltage)
Bending shall be applied to the 1.0 mm with
1.0 mm/sec.
R340
Bending
Limit
C Meter
45±1mm
45±1mm
Solder the capacitor on P.C. board shown in
Fig 1. before testing.
A 5N·f ( 0.5Kg·f) pull force shall be applied
for 10 ± 1 second.
at room temperature after one hour heat
treatment at
150 + 0/-10˚C before initial measure.
Preheat: At 150± 10˚C For 60 ~120sec.
Dip: Solder Temperature of 260 ± 5˚C
Solder: H63A
Flux: Rosin
Class I: 24 ± 2 Hours
Class II: 48 ± 4 Hours
Web: www.venkel.com
Rev: 09/2020-A
8
SAFC
SERIES
NO.
ITEM
Appearance
Capacitance
11
Damp Heat/Steady
State
Test Condition :
Temperature : 40˚C
Humidity : 95 %RH
The capacitors with rated voltage(250Vac)
applied.
Class I: 24 ± 2 Hrs
Class II: 48 ± 4 Hrs
Solder The Capacitor On P.C. Board Shown In
Fig 2. Before Testing.
Characteristic
Cap. Change
Class I (C0G)
Class II (X7R)
Q Class I
Tan δ Class II
Maximum 5.0%
More than 1,000MΩ
Voltage)
Appearance
Capacitance
Endurance
TEST CONDITION
More Than 30pF: Q ≥ 350
30pF & Below:Q ≥ 275 + 2.5× C (C:pF)
Voltage Proof
12
SPECIFICATION
Characteristic
Cap. Change
Class I (C0G)
Class II (X7R)
Q Class I
Tan δ Class II
Maximum 5.0%
More than 1,000MΩ
Impulse Voltage
to a 2.5KV(X2) and 5KV(X1/Y2) impulse for
three times. Then the capacitors are applied
to life test.
100 (%)
90
T1=1.2us is between 10% to 90%
T2=50us is between 50% to 50%
50
10
t
T1
T12
Voltage Proof
Voltage)
13
14
Capacitor didn’t burnt at all
Passive Flammability
The cheese cloth shall not burn with a flame
Active Flammability
Temperature : 125˚C
Test Time : 1000hrs
Applied Voltage :
be increased to 1000Vrms for 0.1s.
Volume Sample : 21.56mm3
Flame exposure time : 5 sec.Max.
The capacitors of class X2 each test capacitors applied Ur(250Vac).
Then each sample shall be subjected to 20
discharges from a tank capacitor, charge to a
voltage that, when discharged, places
Ui(2500V)
across the capacitor under test. The interval
between successive discharges shall be 5s.
Web: www.venkel.com
Rev: 09/2020-A
9
SAFC
SERIES
TAPE & REEL SPECIFICATIONS
PLASTIC TAPE
Pitch Hold
I
Chip Inserting Hole
F
A
G
H
B
t
O
C
D
E
J
Unit: mm
TYPE
A
B
1808
2.5±0.2
4.9±0.2
1812
3.6±0.2
4.9±0.2
2208
2.5±0.2
6.1±0.2
2211
3.2±0.2
6.1±0.2
2220
5.4±0.2
6.1±0.2
TYPE
G
5.5±0.05
C
D
E
F
4.0±01
8.0±01
4.0±0.05
8.0±01
1.75±0.1
H
I
J
T
O
12.0±0.3
1.5±0.1/-0
3.7 max.
0.3 max.
0.5 min.
1808
1812
2208
2211
2220
REEL DIMENSIONS
Reel Material: Polystyrene
E
C
B
D
W
A
TYPE
Unit: mm
A
B
C
D
E
W
178±2.0
Ø50 min.
Ø13±0.5
Ø21±0.8
2.0±0.5
14±0.15
1808
1812
2208
2211
2220
TAPE & REEL QUANTITIES (EMBOSSED PLASTIC TAPE)
SIZE
1808, 1812, 2208, 2211, 2220
THICKNESS (T)
QTY PER REEL
0.9mm < T ≤ 1.25mm
3000
1.25mm < T ≤ 2.0mm
2000
1.25mm < T ≤ 2.2mm
1000
T > 2.2mm
700
Web: www.venkel.com
Rev: 09/2020-A
10
SAFC1812X7R202-472KNE 价格&库存
很抱歉,暂时无法提供与“SAFC1812X7R202-472KNE”相匹配的价格&库存,您可以联系我们找货
