800A1R5BT250XT
800A1R5BT250XT
    ATC
    贴片电容(MLCC) 0505 1.5pF ±0.1pF 250V C0G (NP0)
800A1R5BT250XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800A Series NP0 Porcelain, High RF Power Ultra-Low ESR FEATURES • • • • • • • • • Case A Size (.055” x .055”) Low ESR / ESL High Q Low Noise Capacitance Range 0.1 pF to 100 pF Rated WVDC up to 250 VDC Zero TCC High Self-Resonance Established Reliability (QPL) GENERAL DESCRIPTION KYOCERA AVX 800 A Series offers superb performance in demanding high RF power applications requiring consistent and reliable operation. The combination of highly conductive metal electrode systems, optimized case geometries, and proprietary dielectrics, yields the lowest ESR. KYOCERA AVX new NPO low loss rugged dielectrics are designed to provide superior heat transfer in high RF power applications. Ultralow ESR and superior thermal performance insure that the 800 A Series products are your best choice for high RF power applications from UHF through microwave frequencies. Typical applications: UHF and Microwave Communications Systems, Wireless Communications, Public Safety Radio, Telecom, WiMAX, and Satellite Systems. Typical circuit applications: High RF Power Filter Networks, Combiners, Couplers, Matching Networks, Output Coupling, Antenna Coupling, and DC Blocking and Bypassing. ELECTRICAL SPECIFICATIONS Temperature Coefficient (TCC) 0 ± 30 PPM/ºC Capacitance Range 0.1 pF to 1000 pF Operating Temperature -55ºC to +125ºC* Quality Factor Greater than 2,000 @ 1 MHz. Insulation Resistance (IR) 0.1 pF to 470 pF 105 Megohms min. @ 25ºC at rated WVDC 105 Megohms min. @ 125ºC at rated WVDC Working Voltage (WVDC) See Capacitance Values table Dielectric Withstanding Voltage (DWV) 250% of rated WVDC for 5 seconds Aging Effects None Piezoelectric Effects None Capacitance Drift ± (0.02% or 0.02 pF), whichever is greater PACKAGING OPTIONS Tape & Reel Vertical Orientation Tape & Reel ENVIRONMENTAL CHARACTERISTICS Themal Shock Mil-STD-202, Method 107, Condition A Moisture Resistance Mil-STD-202, Method 106 Low Voltage Humidity Mil-STD-202, Method 103, condition A, with 1.5 VDC applied while subjected to an environment of 85ºC with 85% relative humidity for 240 hours Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C. 200% WVDC applied. Solderability Mil-STD-202, Method 208 Terminal Strength Terminations for chips and pellets withstand a pull of 5 lbs. min., 10 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070621 – rf microwave products – 537 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800A Series NP0 Porcelain, High RF Power Ultra-Low ESR CAPACITANCE VALUES Cap. Code 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 Cap. (pF) 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 Tol. Rated WVDC B B, C 250 B, C, D Cap. Code 2R2 2R4 2R7 3R0 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 130 150 Cap. (pF) 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 HOW TO ORDER Tol. Rated WVDC B, C, D 250 B, C, J, K, M F, G, J, K, M 800 A 100 J Cap. Code 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 Cap. (pF) 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 T 250 Series F, G, J, K, M 250 X T     T = Tape and Reel, 500 pc qty TV = Vertical Orientation of Product Tape and Reel, 500 pc qty See mechanical dimensions below For tray and box options, leave last position blank. Please see last column mechanical configuration table for package quantities Capacitance EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Laser Marking (Optional) Voltage Rating Capacitance Tolerance Code B C D ±.1 pF ±.25 pF ±.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% The above part number refers to a 800A Series (case size A) 10 pF capacitor, J tolerance (±5%), 250 WVDC, with T termination (Tin Plated over Nickel Barrier Termination), Laser Marking and Tape and Reel 4000 pc qty. Packaging 538 Rated WVDC Packaging Case Size Code Tol. Tol. Termination Style Code Please see 2nd Column Mechanical Configuration Table The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070621 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800A Series NP0 Porcelain, High RF Power Ultra-Low ESR MECHANICAL CONFIGURATION Series & Case Size Term. Code Case Size & Type 800A T A Solderable Nickel Barrier Y W T L Y 800A W Body Dimensions inches (mm) Outline ES W/T is a Termination Surface A Solder Plate W T L Length (L) Width (W) .055+.015 -.010 (1.40+0.38-0.25) .055 ±.015 (1.40 ±0.38) .055+.015 -.010 (1.40+0.38-0.25) .055 ±.015 (1.40 ±0.38) Lead and Termination Dimensions and Material Thickness (T) .057 (1.45) max. Overlap (Y) .010+.010 -.005 (0.25+0.25 -0.13) Materials Pkg Type & Qty Pkg Code RoHS Compliant Tin Plated over Nickel Barrier Termination T&R, 4000 or 500 pcs T4K or T Vertical T&R, TV4K or TV 4000 or 500 pcs Tin/ Lead, Solder Plated over Nickel Barrier Termination T&R, 4000 or 500 pcs T4K or T Vertical T&R, TV4K or TV 4000 or 500 pcs NON-MAGNETIC CONFIGURATION Series & Case Size 800A Term. Case Size Code & Type TN A Non-Mag Solderable Barrier Non-Magnetic Configuration Y W L T Body Dimensions inches (mm) Lead and Termination Dimensions and Material Length (L) Width (W) Thickness (T) .055+.025 -.010 (1.40+0.64-0.25) .055 ±.015 (1.40 ±0.38) .057 (1.45) .010+.010 -.005 max. (0.25+0.25 -0.13) Overlap (Y) Materials – rf microwave products – Pkg Code RoHS Compliant T&R, 4000 or Tin Plated over 500 pcs T4K or T Non-Magnetic Vertical T&R, TV4K or TV Barrier Termination 4000 or 500 pcs The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070621 Pkg Type & Qty 539 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800A Series NP0 Porcelain, High RF Power Ultra-Low ESR SUGGESTED MOUNTING PAD DIMENSIONS Mount Type Pad Size Normal Vertical Mount High Density Normal Horizontal Mount High Density Case A A Min. .070 .050 .080 .060 B Min. .050 .030 .050 .030 C Min. .030 .030 .030 .030 D Min. .130 .090 .130 .090 Dimensions are in inches. ESR (Ohms) 1.00 800 A ESR vs. Frequency 800A - 1.0 pF 800A - 3.3 pF 800A - 10 pF 800A - 33 pF 800A - 100 pF 0.10 0.01 100 1000 Frequency (MHz) 540 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 10000 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800A Series NP0 Porcelain, High RF Power Ultra-Low ESR PERFORMANCE DATA 800 A FSR & FPR vs. Capacitance 100 Vert Fpr Horiz Fpr Vert Fsr Frequency (GHz) Horiz Fsr 10 (Typical) 1 11 0 100 Capacitance (pF) 800A Capacitance Change vs. Temperature 1 0.8 TCC= 0 ±30 PPM/C % Change in Capacitance 0.6 0.4 0.2 0 -0.2 -0.4 -0.6 -0.8 -1 Temperature (Degrees C) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 541 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800A Series NP0 Porcelain, High RF Power Ultra-Low ESR SAMPLE KITS Kit # Kit 80T Kit 81T Kit 82T 542 RoHS Compliant Item Number Description Cap. Value Range (pF) 800A NPO Ceramic High RF Power MLCs 16 different values, 15 pcs. min. per value 0.1 to 2.0 DK0081T 800A NPO Ceramic High RF Power MLCs 16 different values, 15 pcs. min. per value 1.0 to 10 DK0082T 800A NPO Ceramic High RF Power MLCs 16 different values, 15 pcs. min. per value 10 to 100 DK0080T Cap Value (pF) Tol. 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2, 1.5 ±0.1............................................. ±0.1 Price $135.00 1.6, 1.8, 2.0............................................................ ±0.25 1.0, 1.2, 1.5, 1.8, 2.0, 2.2, 2.4, 2.7, 3.0, 3.3............ ±0.1 3.9, 4.7, 5.6, 6.8, 8.2.............................................. ±0.25 $135.00 10........................................................................... ±5 10, 12, 15, 18, 20, 22, 24, 27, 30, 33, 39, 47, 56, 68, 82, 100..................................... ±5% $135.00 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products –
800A1R5BT250XT 价格&库存
很抱歉,暂时无法提供与“800A1R5BT250XT”相匹配的价格&库存,您可以联系我们找货
