85
DATA SHEET
SURFACE MOUNT MULTILAYER
CERAMIC CAPACITORS
Automotive grade
with Soft Termination
X7R
10 V to 250 V
Product Specification – December 4, 2018 V.1
1 nF to 4.7 uF
RoHS compliant & Halogento Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
Automotive grade
NP0/X7R
6.3 V to 630 V
2
17
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes
Automotive grade X7R series
chip capacitors with flexible leadfree terminations and used for
automotive equipments.
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
GLOBAL PART NUMBER
AS
XXXX X X XXX X
(1)
APPLICATIONS
All general purpose applications
Entertainment applications
Comfort / security applications
Information applications
(2) (3) (4)
B
(5)
X XXX
(6) (7)
(1) SIZE – INCH BASED (METRIC)
0805 (2012) / 1206 (3216)/ 1210 (3225)
(2) TOLERANCE
J = ± 5%
K = ± 10%
FEATURES
AEC-Q200 qualified
MSL class: MSL 1
AC series soldering is
compliant with J-STD-020D
Halogen free epoxy
RoHS compliant
Reduce environmentally
hazardous waste
High component and
equipment reliability
Save PCB space
The capacitors are 100%
performed by automatic optical
inspection prior to taping.
M = ± 20%
(3) PACKING STYLE
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
(4) TC MATERIAL
X7R
(5) RATED VOLTAGE
8 = 25 V
9 = 50 V
0 = 100 V
A = 200 V
Y = 250 V
(6) PROCESS
B = Class 2 MLCC
(7) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 121 = 12 x 101 = 120 pF
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
3
17
6.3 V to 630 V
CONSTRUCTION
The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal
electrodes are contained. This structure gives rise to a high capacitance per unit volume.
The inner electrodes are connected to the two end flexible terminations and finally co vered with a layer of plated
tin (NiSn).
The terminations are lead-free. A cross section of the structure is shown in Fig.1 and Fig.2.
Copper
Soft electrode
(Stress relaxation)
Ni Plating
Sn Plating
YNM0049
Fig. 1 Surface mounted multilayer ceramic capacitor construction
OUTLINES
DIMENSION
Table 1 For outlines see fig. 3
TYPE
L1 (mm)
W (mm)
0603
1.6 ± 0.2
0.8 ± 0.15
0805
2.0 ± 0.3
1.25 ± 0.2
1206
3.2 ± 0.4
1.6 ± 0.2
T (mm)
L2/L3(mm)
min
L2/L3(mm)
max
L4(mm)
min
0.8 ± 0.15
0.20
0.65
0.50
0.25
0.75
0.70
0.25
0.85
1.50
0.25
1.00
1.20
0.85 ± 0.15
1.25 ± 0.20
0.85 ± 0.15
1.25 ± 0.20
1.60 ± 0.20
1210
3.2 ± 0.5
2.5 ± 0.3
2.5 ± 0.3
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
4
17
6.3 V to 630 V
CAPACITANCE RANGE & THICKNESS FOR X7R
Table 2
Size 0805
0603
CAP.
16 V
0805
25 V
50 V
100 V
25 V
50 V
100 V
1.0 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
1.5 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
2.2 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
3.3 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
4.7 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
6.8 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
10 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
15 nF
0.85± 0.15
0.85± 0.15
0.85± 0.15
22 nF
0.8± 0.15
0.8± 0.15
0.8± 0.15
0.8± 0.15
0.85± 0.15
0.85± 0.15
0.85± 0.15
33 nF
0.8± 0.15
0.8± 0.15
0.8± 0.15
0.8± 0.15
0.85± 0.15
0.85± 0.15
1.25± 0.2
47 nF
0.8± 0.15
0.8± 0.15
0.8± 0.15
0.8± 0.15
0.85± 0.15
0.85± 0.15
1.25± 0.2
68 nF
0.8± 0.15
0.8± 0.15
0.8± 0.15
1.25± 0.2
1.25± 0.2
1.25± 0.2
100 nF
0.8± 0.15
0.8± 0.15
0.8± 0.15
1.25± 0.2
1.25± 0.2
1.25± 0.2
1 uF
1.25± 0.2
NOTE
Values in shaded cells indicate thickness class in mm
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
6.3 V to 630 V
5
17
Table 3 Size 1206
1206
CAP.
16V
25V
50 V
100 V
250 V
22 nF
1.25± 0.2
33 nF
1.25± 0.2
47 nF
1.25± 0.2
68 nF
1.25± 0.2
100 nF
0.85± 0.15
0.85± 0.15
1.25± 0.2
150 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
220 nF
Table 4
1.25± 0.2
1.6± 0.2
Size 1210
1210
CAP.
50 V
4.7 uF
2.5± 0.3
NOTE
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
6.3 V to 630 V
6
17
THICKNESS CLASSES AND PACKING QUANTITY
Table 5
SIZE
CODE
0603
0805
1206
1210
Ø 180 MM / 7 INCH
Paper
Blister
Ø 330 MM / 13 INCH
Paper
Blister
8 mm
4,000
15,000
0.85 ± 0.15 mm
8 mm
4,000
15,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
0.6 ± 0.1 mm
8 mm
4,000
20,000
0.85 ± 0.1 mm
8 mm
4,000
15,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
1.6 ± 0.2 mm
8 mm
2,000
10,000
2.5 ± 0.3 mm
8 mm
1,000
THICKNESS
CLASSIFICATION
TAPE WIDTH
QUANTITY PER REEL
0.8 ± 0.15 mm
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
7
17
6.3 V to 630 V
ELECTRICAL CHARACTERISTICS
NP0/X7R DIELECTRIC CAPACITORS; NI/SIN TERMINATIONS
Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions
for testing as given in 5.3 of IEC 60068-1:
Temperature: 15 °C to 35 °C
Relative humidity: 25% to 75%
Air pressure: 86 kPa to 106 kPa
Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time
sufficient to allow the entire capacitor to reach this temperature.
The period as prescribed for recovery at the end of a test is normally sufficient for this purpose.
Table 6
VALUE
DESCRIPTION
Capacitance range
1 nF to 4.7 uF
Capacitance tolerance
X7R
± 5% (1), ± 10%, ± 20%
Dissipation factor (D.F.)
X7R
0603
≤10V
16V
22nF to 100nF
0805
1206
1210
1nF to 100uF
22nF to 220nF
≤ 5%
1nF to 100nF
22nF to 220nF
≤ 3.5%
680nF to 1uF
≤ 5%
25V
22nF to 39nF
1nF to 100nF
22nF to 220nF
50V
22nF to 39nF
1nF to 100nF
22nF to 220nF
47nF to 100nF
220nF to 470nF
≤ 2.5%
≤ 3.5%
≤ 2.5%
≤ 3.5%
4.7 uF
100V
1nF to 100nF
22nF to 220nF
≤ 2.5%
47nF to 100nF
250V
Insulation resistance after 1
minute at Ur (DC)
≤ 5%
≤ 5%
22nF to 100nF
≤ 2.5%
IR ≥ 10 GΩ or I.R x C ≥ 500Ω.F whichever is less
Maximum capacitance change as a
function of temperature
(temperature characteristic/coefficient):
X7R
Operating temperature range:
X7R
± 15%
–55 °C to +125 °C
NOTE
1. Capacitance tolerance ±5% doesn't available for X7R full product range, please contact local sales force before order
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
8
17
6.3 V to 630 V
SOLDERING RECOMMENDATION
Table 7
SOLDERING
METHOD
SIZE
0402
0603
0805
1206
≥ 1210
Reflow
≥ 0.1 µF
≥ 1.0 µF
≥ 2.2 µF
≥ 4.7 µF
Reflow only
Reflow/Wave
< 0.1 µF
< 1.0 µF
< 2.2 µF
< 4.7 µF
SOLDERING CONDITIONS
The lead free MLCCs are able to stand the reflow soldering conditions as below:
Temperature: above 220 °C
Endurance: 95 to 120 seconds
Cycles: 3 times
The test of "soldering heat resistance" is carried out in accordance with the schedule of "MIL-STD-202F-method 210F", "The robust
construction of chip capacitors allows them to be completely immersed in a solder bath of 270 °C for 10 seconds". Therefore, it is possible
to mount MLCCs on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Capacitors are tested
for solderability at 245 °C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds.
TESTS AND REQUIREMENTS
Table 8
Test procedures and requirements
TEST
Mounting
TEST METHOD
PROCEDURE
REQUIREMENTS
IEC 60384-
4.3
The capacitors may be mounted on printed-circuit boards or
ceramic substrates
No visible damage
4.5.1
Class 1:
At 20°C, 24 hours after annealing
Within specified tolerance
21/22
Capacitance
IEC 6038421/22
f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 20°C
f = 1 KHz for C > 1nF, measuring at voltage 1 Vrms at 20°C
Class 2:
f = 1 KHz, measuring at voltage 1 Vrms at 20°C
Dissipation
Factor (D.F.)
IEC 60384-
4.5.2
21/22
Class 1:
In accordance with
specification
Class 2:
At 20 °C, 24 hours after annealing
Insulation
Resistance
IEC 6038421/22
4.5.3
At Ur (DC) for 1 minute
In accordance with
specification
www.yageo.com
Dec. 04, 2018 V.1
TEST
TEST METHOD
4.6
Temperature
coefficient
Automotive grade
NP0/X7R
6.3 V to 630 V
PROCEDURE
REQUIREMENTS
Capacitance shall be measured by the steps shown in the
following table.
Class1:
∆ C/C: ± 30ppm
The capacitance change should be measured after 5 min at
each specified temperature stage.
Step
Temperature(°C)
a
25± 2
b
Lower temperature± 3°C
c
25± 2
d
Upper Temperature± 2°C
e
25± 2
9
17
Class2:
X7R: ∆ C/C: ±15%
Class2:
X7R/X5R: ∆ C/C: ± 15%
(1) Class I
Temperature Coefficient shall be calculated from the formula
as below
C2 - C1
106 [ppm/°C]
Temp, Coefficient =
C1 xΔT
C1: Capacitance at step c
C2: Capacitance at 125°C
∆T: 100°C (=125°C -25°C)
(2) Class II
Capacitance Change shall be calculated from the formula as
below
C2 - C1
∆C =
x 100%
C1
C2: Capacitance at step b or d
High
Temperature
Exposure
AEC-Q200
3
Unpowered ; 1000hours @ T=150°C
No visual damage
Measurement at 24± 2 hours after test conclusion.
Δ C/C:
Class1:
NP0: within ± 0.5% or 0.5 pF
whichever is greater
Class2:
X7R: ± 10%
D.F.:
within initial specified value
IR:
www.yageo.com
Dec. 04, 2018 V.1
TEST
Temperature
Cycling
Automotive grade
NP0/X7R
TEST METHOD
PROCEDURE
REQUIREMENTS
AEC-Q200
Preconditioning;
150 +0/–10°C for 1 hour, then keep for
24 ± 1 hours at room temperature
No visual damage
4
1000 cycles with following detail:
30 minutes at lower category temperature
30 minutes at upper category temperature
Recovery time 24 ± 2 hours
10
6.3 V to 630 V
17
∆C/C
Class1:
NP0: Within ± 1% or 0.5pF,
whichever is greater.
Class2:
X7R: ±10%
D.F. meet initial specified value
IR meet initial specified value
Destructive
Physical Analysis
AEC-Q200
Moisture
Resistance
AEC-Q200
5
10ea X 3 lots.
Note: Only applies to SMD ceramics.
Electrical test not required.
6
T=24 hrs/per cycle; 10 continuous cycles unpowered.
Measurement at 24 ± 2 hours after test condition.
No visual damage
∆C/C
NP0: Within ± 3% or 3 pF,
X7R: ± 10%
D.F.
Within initial specified value
IR
NP0: ≥ 10,000 MΩ
X7R: Meet initial specified
value
Fig. 4 Moisture resistant
www.yageo.com
Dec. 04, 2018 V.1
TEST
Biased Humidity
Automotive grade
NP0/X7R
6.3 V to 630 V
TEST METHOD
PROCEDURE
REQUIREMENTS
AEC-Q200
1. Preconditioning, class 2 only:
150 +0/-10 °C /1 hour, then keep for
24 ± 1 hour at room temp
No visual damage after
recovery
2. Initial measure:
Parameter: IR
Measuring voltage: 1.5V ± 0.1 VDC
Note: Series with 100 KΩ & 6.8 KΩ
Initial requirement:
7
3. Test condition:
85 °C, 85% R.H. connected with 100 KΩ resistor, applied
1.5V/Ur for 1,000 hours.
4. Recovery:
Class1: 6 to 24 hours
Class2: 24 ± 2 hours
5. Final measure: IR
11
17
Class1:
- Connected to 100 KΩ:
C ≤ 10 nF: I.R ≥ 10,000 MΩ
or
C > 10 nF: (I.R-100 KΩ) x C
≥ 100s.
- Connected to 6.8 KΩ:
or
C > 10 nF: (I.R-6.8 KΩ) x C
≥ 100s.
Class2:
C ≤ 25 nF: I.R ≥ 4,000 MΩ or
C > 25 nF: (I.R-100 KΩ) x C
≥ 100s.
C ≤ 25 nF: I.R ≥ 10,000 MΩ
or
C > 25 nF: (I.R-6.8 KΩ) x C
≥ 100s.
Final measurement:
The insulation resistance shall
be greater than 0.1 time initial
value.
www.yageo.com
Dec. 04, 2018 V.1
TEST
Operational Life
Automotive grade
NP0/X7R
TEST METHOD
PROCEDURE
REQUIREMENTS
AEC-Q200
No visual damage
8
2. Initial measure:
Spec: refer to initial spec C, D, IR
3. Endurance test:
Temperature: X7R: 125 °C
Specified stress voltage applied for 1,000 hours:
Applied 2.0 x Ur for general products
Applied 1.5 x Ur for high cap. Products
12
6.3 V to 630 V
17
∆C/C
NP0: Within ± 2% or 1 pF,
X7R: ± 15%
D.F.
NP0: ≤ 2 x specified value.
X7R: ≤ 16V: ≤ 7%
≥ 25V: ≤ 5%
High voltage series follows with below
IR
stress condition:
NP0: ≥ 4,000 MΩ or IR x Cr ≥
40s whichever is less
Applied 1.5 x Ur for 200V, 250V series
Applied 1.3 x Ur for 500V, 630V series
Applied 1.2 x Ur for 1KV, 2KV, 3KV series
X7R: ≥ 1,000 MΩ or IRx Cr ≥
50s whichever is less
4. Recovery time: 24 ± 2 hours
5. Final measure: C, D, IR
Note: If the capacitance value is less than the minimum value
permitted, then after the other measurements have been
made the capacitor shall be preconditioned according to “IEC
60384 4.1” and then the requirement shall be met.
External Visual
AEC-Q200
9
Any applicable method using × 10 magnification
In accordance with
specification
Physical
Dimension
AEC-Q200
10
Verify physical dimensions to the applicable device
specification.
In accordance with
specification
Mechanical
Shock
AEC-Q200
13
Three shocks in each direction shall be applied along the three
mutually perpendicular axes of the test specimen (18 shocks)
Peak value: 1,500 g’s
∆C/C
NP0: Within ± 0.5% or 0.5 pF,
Duration: 0.5 ms
X7R: ± 10%
Velocity change: 15.4 ft/s
Waveform: Half-sin
D.F.
IR
Vibration
AEC-Q200
14
5 g’s for 20 minutes, 12 cycles each of 3 orientations.
Note:
Use 8” x 5” PCB. 0.31” thick 7 secure points on one long side
and 2 secure points at corners of opposite sides. Parts
mounted within 2” from any secure point. Test from
10-2000 Hz.
∆C/C
X7R: ± 10%
D.F: meet initial specified value
www.yageo.com
Dec. 04, 2018 V.1
TEST
Resistance to
Soldering Heat
Automotive grade
NP0/X7R
6.3 V to 630 V
13
17
TEST METHOD
PROCEDURE
REQUIREMENTS
AEC-Q200
Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1
Dissolution of the end face
plating shall not exceed 25% of
the length of the edge
concerned
15
Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute
Preheating: for size >1206: 100 °C to 120 °C for 1 minute
and 170 °C to 200 °C for 1 minute
Solder bath temperature: 260 ± 5 °C
Dipping time: 10 ± 0.5 seconds
∆C/C
Class1:
NP0: Within ± 1% or 0.5 pF,
Class2:
X7R: ± 10%
D.F. within initial specified
value
IR within initial specified value
Thermal Shock
AEC-Q200
16
150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room
temp
2. Initial measure:
3. Rapid change of temperature test:
NP0/X7R: -55 °C to +125 °C; 300 cycles
15 minutes at lower category temperature; 15 minutes at
upper category temperature.
No visual damage
∆C/C
NP0: Within ± 1% or 1 pF,
X7R: ± 15%
4. Recovery time:
ESD
AEC-Q200
17
Per AEC-Q200-004
A component passes a voltage
level if all components stressed
at that voltage level pass.
Solderability
AEC-Q200
18
Preheated to a temperature of 80 °C to 140 °C and
maintained for 30 seconds to 60 seconds.
The solder should cover over
95% of the critical area of each
termination.
Test conditions for lead containing solder alloy
Temperature: 235 ± 5 °C
Dipping time: 2 ± 0.2 seconds
Depth of immersion: 10 mm
Alloy Composition: 60/40 Sn/Pb
Number of immersions: 1
Test conditions for lead-free containing solder alloy
Temperature: 245 ± 5 °C
Dipping time: 3 ± 0.3 seconds
Alloy Composition: SAC305
www.yageo.com
Dec. 04, 2018 V.1
TEST
Electrical
Characterization
Automotive grade
NP0/X7R
TEST METHOD
PROCEDURE
REQUIREMENTS
AEC-Q200
Parametrically test per lot and sample size requirements,
summary to show Min, Max, Mean and Standard deviation at
room as well as Min and Max operating temperatures.
∆C/C
Class 1:
NP0: -55 °C to +125 °C
Normal temperature: 20 °C
Class2:
X7R: ± 15%
19
14
17
6.3 V to 630 V
Class 1:
NP0: ± 30 ppm/°C
Class 2:
Board Flex
AEC-Q200
21
Part mounted on a 100 mm X 40 mm FR4 PCB board, which
is 1.6 ± 0.2 mm thick and has a layer-thickness 35 µm ± 10
µm.
Part should be mounted using the following soldering reflow
profile.
No visible damage
∆C/C
Class2:
X7R: ± 10%
Conditions:
Class2:
Bending 5 mm at a rate of 1 mm/s, radius jig 230 mm
Test Substrate:
b
C
Dimension(mm)
4.5
YNSC147
40
a
100
unit: mm
Terminal
Strength
AEC-Q200
22
With the component mounted on a PCB obtained with the
device to be tested, apply a 17.7N (1.8Kg) force to the side of
a device being tested.
This force shall be applied for 60+1 seconds.
Also the force shall be applied gradually as not to apply a
shock to the component being tested.
* Apply 2N force for 0402 size.
Type
a
b
c
0201
0.3
0.9
0.3
0402
0.4
1.5
0.5
0603
1.0
3.0
1.2
0805
1.2
4.0
1.65
1206
2.2
5.0
1.65
1210
2.2
5.0
2.0
1808
3.5
7.0
3.7
Magnification of 20X or greater
may be employed for
inspection of the mechanical
integrity of the device body,
terminals and body/terminal
junction.
Before, during and after the
test, the device shall comply
with all electrical requirements
stated in this specification.
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
6.3 V to 630 V
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Beam Load Test
AEC-Q200
Place the part in the beam load fixture. Apply a force
until the part breaks or the minimum acceptable
force level required in the user specification(s) is
attained.
≤ 0805
23
15
17
Thickness > 0.5 mm: 20N
Thickness ≤ 0.5 mm: 8N
≥ 1206
Thickness ≥1.25 mm: 54N
Thickness < 1.25 mm: 15N
Voltage Proof
IEC 60384-1
4.6
Specified stress voltage applied for 1~5 seconds
Ur ≤ 100 V: series applied 2.5 Ur
100 V < Ur ≤ 200 V series applied (1.5 Ur + 100)
200 V < Ur ≤ 500 V series applied (1.3 Ur + 100)
Ur > 500 V: 1.3 Ur Ur ≥ 1000 V: 1.2 Ur
Charge/Discharge current is less than 50mA
No breakdown or flashover
Note: Classify the components according to the highest ESD voltage level survived during
ESD testing.
Fig. 5 Passive component HBM ESD test flow diagram (DC = Direct Contact Discharge, AD = Air Discharge)
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
6.3 V to 630 V
16
17
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 0
- New
Oct. 05, 2017
www.yageo.com
Dec. 04, 2018 V.1
Automotive grade
NP0/X7R
6.3 V to 630 V
17
17
LEGAL DISCLAIMER
Yageo, its distributors and agents (collectively, “Yageo ”), hereby disclaims any and all liabilities for any errors,
inaccuracies or incompleteness contained in any product related information, including but not limited to
product specifications, datasheets, pictures and/or graphics. Yageo may make changes, mod ifications and/or
improvements to product related information at any time and without notice.
Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular
purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo
disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all
liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied
warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability.
Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s
knowledge of typical operating conditions for such types of applications in a generic nature. Such statements
are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a
specific customer application or use. They are intended for use only by customers with requisite knowledge and
experience for determining whether Yageo products are the correct products for their application or use. In
addition, unpredicatable and isolated cases of product failure may still occ ur, therefore, customer application or
use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective
safeguard measures to ensure that product failure would not result in personal injury or property damage.
Yageo products are not designed for application or use in medical, life -saving, or life-sustaining devices or for
any other application or use in which the failure of Yageo products could result in personal injury or death.
Customers using or selling Yageo products not expressly indicated for above -mentioned purposes shall do so at
their own risk and agree to fully indemnify Yageo and hold Yageo harmless.
Information provided here is intended to indicate product specifications only. Yageo reserves all t he rights for
revising this content without further notification, as long as products are unchanged. Any product change will
be announced by PCN.
www.yageo.com
Dec. 04, 2018 V.1
