100E330JW3600XT
100E330JW3600XT
    ATC
    贴片电容(MLCC) 3838 33pF ±5% 3.6KV P90
100E330JW3600XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100E Series Porcelain High RF Power Multilayer Capacitors FEATURES • • • • • • • • • * For leaded styles only GENERAL DESCRIPTION PACKAGING OPTIONS KYOCERA AVX, the industry leader, offers new improved ESR/ESL performance for the 100 E Series RF Capacitors. This high Q multilayer capacitor is ultra-stable under high RF current and voltage applications. High density porcelain construction provides a rugged, hermetic package. KYOCERA AVX offers an encapsulation option for applications requiring extended protection agains arc-over and corona. Tape & Reel • Impedance Matching • DC Blocking CIRCUIT APPLICATIONS • HF/RF Power Amplifiers • Transmitters • Antenna Tuning Tray (96 pcs) ELECTRICAL SPECIFICATIONS FUNCTIONAL APPLICATIONS • Bypass • Coupling • Tuning Case E Size (.380” x .380”) Capacitance Range 1pF to 5100pF Extended WVDC up to 7200 VDC Low ESR/ESL High Q High RF Power Ultra-Stable Performance High RF Current/Voltage Available with Encapsulation Option* • Plasma Chambers • Medical (MRI coils) ENVIRONMENTAL CHARACTERISTICS Temperature Coefficient (TCC) 90 ± 30 PPM/ºC Capacitance Range 1 pF to 5100 pF Operating Temperature -55ºC to +125ºC* Quality Factor Greater than 10,000 (1 pF to 1000 pF) @ 1 MHz. Greater than 10,000 (1100 pF to 5100 pF) @ 1 KHz. Insulation Resistance (IR) 1 pF to 5100 pF 105 Megohms min. @ 25ºC at 500 VDC 104 Megohms min. @ 125ºC at 500 VDC Working Voltage (WVDC) See Capacitance Values table Thermal Shock Mil-STD-202, Method 107, Condition A Moisture Resistance Mil-STD-202, Method 106 Low Voltage Humidity Mil-STD-202, Method 103, condition A, with 1.5 VDC applied while subjected to an environment of 85ºC with 85% relative humidity for 240 hours Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C. Voltage applied. 200% of WVDC for capacitors rated at 500 volts DC or less. 120% of WVDC for capacitors rated at 1250 volts DC or less. 100% of WVDC for capacitors rated above 1250 volts DC Termination Styles Available in various surface mount and leaded styles. See Mechanical Configurations Terminal Strength Terminations for chips and pellets withstand a pull of 10 lbs. min., 25 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Dielectric Withstanding Voltage (DWV) 250% of WVDC for capacitors rated at 500 volts DC or less for 5 seconds. 150% of WVDC for capacitors rated at 1250 volts DC or less for 5 seconds. 120% of WVDC for capacitors rated above 1250 Volts DC for 5 seconds Aging Effects None Piezoelectric Effects None Capacitance Drift ± (0.02% or 0.02 pF), whichever is greater Retrace Less than ±(0.02% or 0.02 pF), whichever is greater. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032421 – rf microwave products – 467 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100E Series Porcelain High RF Power Multilayer Capacitors CAPACITANCE VALUES F, G, J, K, M Rated WVDC CAP. STD. EXT. TAGE Tol. 7200 EXTENDED B, C, D Rated Cap. Cap. WVDC Code (pF) STD. EXT. 470 47 510 51 560 56 620 62 680 68 750 75 820 82 910 91 101 100 111 110 121 120 3600 7200 131 130 151 150 161 160 181 180 201 200 221 220 241 240 271 270 301 300 331 330 361 360 EXTENDED VOLTAGE EXTENDED VOLTAGE 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 EXTENDED VOLTAGE 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R8 2R0 2R1 2R2 2R3 2R4 3R0 3R0 3R0 3R0 4R3 4R7 5R1 Tol. F, G, J, K, M EXT. 3600 5000 VOLT. EXTENDED VOLTAGE Rated Cap. Cap. WVDC Code (pF) STD. EXT. 5R6 5.6 6R2 6.2 6R8 6.8 7R5 7.5 8R2 8.2 9R1 9.1 100 10 110 11 120 12 130 13 150 15 B, C, 3600 7200 D 160 16 180 18 200 20 220 22 240 24 270 27 300 30 330 33 360 36 390 39 430 43 Cap. Cap. Tol. Code (pF) N/A CODE CAP. (pF) 391 431 471 511 561 621 681 751 821 911 102 112 122 152 182 222 272 302 332 392 472 512 390 430 470 510 560 620 680 750 820 910 1000 1100 1200 1500 1800 2200 2700 3000 3300 3900 4700 5100 TOL. RATED WVDC STD. EXT. 3600 2500 F, G, J, K, M N/A 1000 500 VRMS = 0.707 X WVDC • SPECIAL VALUES, TOLERANCES, MATCHING, AND CAPACITOR ASSEMBLIES ARE AVAILABLE. • KYOCERA AVX CUSTOM POWER CAPACITOR ASSEMBLY CATALOG, LISTS ASSEMBLY OPTIONS. • DIFFERENT WORKING VOLTAGES ARE AVAILABLE • ENCAPSULATION OPTION AVAILABLE. PLEASE CONSULT FACTORY. HOW TO ORDER 100 E 391 K W 3600 X T Series Packaging Case Size T = Tape and Reel, 250 pc qty. Please see last Column Mechanical Configuration Table for Box and Tray Options See mechanical dimensions below Capacitance Laser Marking (Optional) EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Voltage Rating Termination Style Code Capacitance Tolerance Code Code Tol. B C D F G J K M ±.1 pF ±.25 pF ±.5 pF ±1% ±2% ±5% ±10% ±20% Please see 2nd Column Mechanical Configuration Table The above part number refers to a 100 E Series (case size E) 390 pF capacitor, K tolerance (±10%), 3600 WVDC, with W termination (Tin / Lead, Solder Plated over Nickel Barrier), laser marking and Tape and Reel packaging. 468 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070721 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100E Series Porcelain High RF Power Multilayer Capacitors MECHANICAL CONFIGURATION Series Term. & Case Code Size Case Size & Type E 100E Outline W/T is a Termination Surface Y W W Solder Plate E 100E Y P W Pellet E 100E T T L Solderable Nickel T L Y W L T Body Dimensions Lead and Termination inches (mm) Dimensions and Material Length Width Thickness Overlap Materials (L) (W) (T) (Y) .380+.015 -.010 (9.65+0.38-0.25) .380+.015 -.010 (9.65+0.38-0.25) E 100E .040 (1.02) max. .380+.040 -.010 (9.65+1.02-0.25) .380 ±.010 (9.65 ±0.25) MS Microstrip .170 (4.32) max. AR Axial Ribbon E 100E AW .380+.035 -.010 (9.65+0.89-0.25) RW Tin/Lead, Solder Plated over Nickel Barrier Termination T&R, 250 pcs Tray, 24 or 96 pcs T J24 J96 Heavy Tin/Lead Coated, over Nickel Barrier Termination T&R, 250 pcs Tray, 24 or 96 pcs T J24 J96 RoHS Compliant Tin Plated over Nickel Barrier Termination T&R, 250 pcs Tray, 24 or 96 pcs T J24 J96 Tray, 16 or 32 pcs J16 J32 Tray, 16 or 32 pcs J16 J32 Silver-plated Copper Leads ia. = .032 ±.002 (.813 ±.051) D LL = 2.25 (57.2) min. Box, 20 pcs B20 Silver-plated Copper Leads ia. = .032 ±.002 (.813 ±.051) D LL = 1.0 (25.4) min. Tray, 16 or 64 pcs J16 J64 N/A Non-Mag Axial Wire E 100E Pkg Code High Purity Silver Leads LL = .750 (19.05) min WL = .350 ±.010 (8.89 ±0.25) TL = .010 ±.005 (0.25 ±0.13) Leads are Attached with High Temperature Solder. E 100E Pkg Type & Qty Non-Mag Radial Wire Custom lead styles and lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 093021 – rf microwave products – 469 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100E Series Porcelain High RF Power Multilayer Capacitors MECHANICAL CONFIGURATION Series Term. & Case Code Size Case Size & Type E 100E WN PN TN W Non-Mag Solderable Barrier T L Y W Non-Mag Pellet E 100E Y Non-Mag Solder Plate E 100E Outline W/T is a Termination Surface T L Y W L T Body Dimensions inches (mm) Length Width (L) (W) .380+.015 -.010 (9.65+0.38-0.25) .040 (1.02) max. .380+.040 -.010 (9.65+1.02-0.25) MN 100E AN .380 ±.010 (9.65 ±0.25) Non-Mag Microstrip .170 (4.32) max. E 100E BN 100E RN .380+.035 -.010 (9.65+0.89-0.25) Heavy Tin/Lead Coated, over T&R, 250 pcs Non-Magnetic Tray, 24 or 96 pcs Barrier Termination T J24 J96 T&R, 250 pcs Tray, 24 or 96 pcs T J24 J96 Tray, 16 or 32 pcs J16 J32 Tray, 16 or 32 pcs J16 J32 Silver-plated Copper Leads ia. = .032 ±.002 (.813 D ±.051) LL = 2.25 (57.2) min. Box, 20 pcs B20 Silver-plated Copper Leads ia. = .032 ±.002 (.813 D ±.051) LL = 1.0 (25.4) min. Tray, 16 or 64 pcs J16 J64 N/A Non-Mag Axial Wire E Non-Mag Radial Wire Custom lead styles and lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. 470 Pkg Code T J24 J96 High Purity Silver Leads LL = .750 (19.05) min WL = .350 ±.010 (8.89 ±0.25) TL = .010 ±.005 (0.25 ±0.13) Leads are Attached with High Temperature Solder. E Non-Mag Axial Ribbon Pkg Type & Qty Tin/Lead, Solder Plated over T&R, 250 pcs Non-Magnetic Tray, 24 or 96 pcs Barrier Termination RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination .380+.015 -.010 (9.65+0.38-0.25) E 100E Lead and Termination Dimensions and Material Thickness Overlap Materials (T) (Y) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 093021 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100E Series Porcelain High RF Power Multilayer Capacitors SUGGESTED MOUNTING PAD DIMENSIONS W L W 391k 1k 39 T T L Mount Type Horizontal Electrode Orientation Vertical Electrode Orientation B B Pad Size Normal Vertical Mount High Density Normal Horizontal Mount High Density A Min. .185 .165 .405 .385 Case E B Min. .050 .030 .050 .030 C Min. .325 .325 .325 .325 D Min. .425 .385 .425 .385 Dimensions are in inches. A C D PERFORMANCE DATA The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032421 – rf microwave products – 471 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100E Series Porcelain High RF Power Multilayer Capacitors PERFORMANCE DATA 472 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 120320 – rf microwave products –
100E330JW3600XT 价格&库存
很抱歉,暂时无法提供与“100E330JW3600XT”相匹配的价格&库存,您可以联系我们找货
