800B100FT500XT
800B100FT500XT
    ATC
    贴片电容(MLCC) 1111 10pF ±1% 500V C0G (NP0)
800B100FT500XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800B Series NP0 Porcelain, High RF Power Ultra-Low ESR FEATURES • • • • • • • Case B Size (.110” x .110”) Rugged, reliable NPO dielectric Case optimized for highest self resonant frequency Capacitance Range 0.1 pF to 1000 pF Lowest ESR Capable of highest RF Power RoHS Compliant/Lead-Free PACKAGING OPTIONS GENERAL DESCRIPTION KYOCERA AVX’s 800B Series offers superb performance in demanding high RF power applications requiring consistent and reliable operation. The combination of highly conductive metal electrode systems, optimized case geometries, and proprietary dielectrics, yields the lowest ESR. KYOCERA AVX’s new NPO low loss rugged dielectrics are designed to provide superior heat transfer in high RF power applications. Ultralow ESR and superior thermal performance insure that the 800B Series products are your best choice for high RF power applications from VHF through microwave frequencies. TYPICAL APPLICATIONS • Avionics • Public Safety Radio • Wireless Communications • VHF / UHF / HDTV Broadcast Transmitters • Telecom • WiMAX • Microwave Communication Systems and Satellite Systems TYPICAL CIRCUIT APPLICATIONS • • • • High RF Power Filter Networks Matching Networks Couplers Combiners • • • • Output Coupling Antenna Coupling DC Blocking Bypassing ENVIRONMENTAL TEST Thermal Shock MIL-STD-202, Method 107, Condition A Moisture Resistance MIL-STD-202, Method 106 MIL-STD-202, Method 103, Condition A, with 1.5 Volts DC applied while subjected Low Voltage Humidity to an environment of 85°C with 85% relative humidity for 240 hours min. Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C 200% WVDC applied Tape & Reel Vertical Orientation Tape & Reel ENVIRONMENTAL CHARACTERISTICS Quality Factor (Q) > 2000 @ 1 MHz Temperature Coefficient of Capacitance (TCC) 0 ±30 PPM/°C (-55°C to +125°C) Insulation Resistance (IR) 0.1 pF to 1000 pF: 105 Megohms min. @ +25°C at rated WVDC 104 Megohms min. @ +125°C at rated WVDC Working Voltage (WVDC) See Capacitance Values Table Dielectric Withstanding Voltage (DWV) Case B: 250% of rated WVDC for 5 secs Retrace Less than ±(0.02% or 0.02 pF), whichever is greater Aging Effects None Piezoelectric Effects None Capacitance Drift ±(0.02% or 0.02 pF), whichever is greater Operating Temperature Range From -55°C to +125°C (No derating of working voltage) Termination Styles See Mechanical Configurations Terminal Strength Terminations for chips withstand a pull of 5 lbs. min., 15 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Test per MIL-STD-202, method 211. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 543 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800B Series NP0 Porcelain, High RF Power Ultra-Low ESR CAPACITANCE VALUES Cap. Code 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 2R2 Cap. (pF) 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 Tol. Rated WVDC B B, C 500 B, C, D Cap. Code 2R4 2R7 3R0 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 130 150 160 180 Cap. (pF) 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 Tol. Rated WVDC Cap. Code 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 111 121 131 B, C, D 500 B, C, J, K, M F, G, J, K, M Cap. (pF) 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 130 Tol. Rated WVDC 500 F, G, J, K, M 300 Cap. Code 151 161 181 201 221 241 271 301 331 361 391 431 471 511 561 621 681 751 821 911 102 Cap. (pF) 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 1000 Tol. Rated WVDC 300 200 F, G, J, K, M 100 50 VRMS = 0.707 X WVDC • SPECIAL VALUES, TOLERANCES AND MATCHING AVAILABLE. PLEASE CONSULT FACTORY. HOW TO ORDER 800 B 910 J T 500 X T Series Packaging Case Size T = Tape and Reel, 500 pc qty TV = Vertical Tape and Reel, 500 pc qty See mechanical dimensions below Please see last Column Mechanical Configuration Table for other options Capacitance Laser Marking (Optional) EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures WVDC Termination Code Capacitance Tolerance Code Code Tol. B C D ±0.1 pF ±0.25 pF ±0.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% Please see 2nd Column Mechanical Configuration Table The above part number refers to a 800 B Series (case size B) 91 pF capacitor, J tolerance (±5%), 500 WVDC, with T termination (Tin Plated over Nickel Barrier Termination, RoHS Compliant), laser marking and tape and reel packaging. 544 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070621 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800B Series NP0 Porcelain, High RF Power Ultra-Low ESR MECHANICAL CONFIGURATION Series & Case Size Term. Code Case Size & Type B 800B T 800B Y Solderable Nickel Barrier B Body Dimensions inches (mm) Length (L) Width (W) Thickness (T) Outline ES W/T is a Termination Surface W T L Y W W Solder Plate T L .110+.020 -.010 (2.79+0.51-0.25) .110+.020 -.010 (2.79+0.51-0.25) .110 ±.015 (2.79 ±0.38) .070 (1.78) max. Lead and Termination Dimensions and Material Overlap (Y) Materials Pkg Type & Qty Pkg Code RoHS Compliant Tin Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs T1K or T TV1K or TV Tin/ Lead, Solder Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs T1K or T TV1K or TV Pkg Type & Qty Pkg Code T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs T1K or T TV1K or TV .015 (0.38) ±.010 (0.25) .110 ±.015 (2.79 ±0.38) NON-MAGNETIC CONFIGURATION Series & Case Size Term. Code Case Size & Type B 800B TN Non-Mag Solderable Barrier Non-Magnetic Configuration Y W L T Body Dimensions inches (mm) Length (L) Width (W) Thickness (T) .110+.020 -.010 (2.79+0.51-0.25) .110 ±.015 (2.79 ±0.38) .070 (1.78) max. Lead and Termination Dimensions and Material Overlap (Y) Materials .015 (0.38) ±.010 (0.25) RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination SUGGESTED MOUNTING PAD DIMENSIONS Case B Vertical Mount Cap Value .43 Pad Size A Min. B Min. C Min. D Min. Normal .090 (2.29) .050 (1.27) .075 (1.91) .175 (4.45) High Density .070 (1.78) .030 (.762) .075 (1.91) .135 (3.43) All Values inches (mm) Case B Horizontal Mount Cap Value .43 Pad Size A Min. B Min. C Min. D Min. Normal .130 (3.30) .050 (1.27) .050 (1.27) .175 (4.45) High Density .110 (2.79) .030 (.762) .075 (1.91) .135 (3.43) All Values inches (mm) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 545 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800B Series NP0 Porcelain, High RF Power Ultra-Low ESR PERFORMANCE DATA 1.00 800 B ESR vs. Frequency Frequency (GHz) ESR (Ohms) Fpr 10.0 1.0 pF 3.3 pF 10 pF 39 pF 0.10 800 B FSR & FPR vs. Capacitance 100.0 100 pF 200 pF 1000 pF Fsr 1.0 (Typical) 0.01 100 1000 0.1 10000 Frequency (MHz) 1 10 100 Capacitance (pF) 800B Capacitance Change vs. Temperature 1 0.8 TCC= 0 ±30 PPM/C 0.6 % Change in Capacitance 0.4 0.2 0 -0.2 -0.4 -0.6 -0.8 -1 -55 -35 -15 5 25 45 65 85 105 125 Temperature (Degrees C) 546 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 1000 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800B Series NP0 Porcelain, High RF Power Ultra-Low ESR SAMPLE KITS Kit # Kit 83T RoHS Compliant Item Number DK0083T Kit 84T DK0084T Kit 85T DK0085T Description 800B NPO Ceramic High RF Power MLCs 16 different values, 15 pcs. min. per value 800B NPO Ceramic High RF Power MLCs 16 different values, 15 pcs. min. per value 800B NPO Ceramic High RF Power MLCs 16 different values, 15 pcs. min. per value Cap. Value Range (pF) Cap Value (pF) Tol. Price 1.0, 1.2, 1.5, 1.8, 2.0, 2.2, 2.4, 2.7, 3.0, 3.3............ ±0.1 1.0 to 10 3.9, 4.7, 5.6, 6.8, 8.2.............................................. ±0.25 $165.00 10........................................................................... ±5% 10 to 100 100 to 1000 10, 12, 15, 18, 20, 22, 24, 27, 30, 33, 39, 47, 56, 68, 82, 100..................................... ±0.1 100, 120, 150, 180, 200, 220, 240, 270, 300, 330, 390, 470................................................. ±5% $165.00 $165.00 560, 680, 820, 1000............................................... ±10% The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070721 – rf microwave products – 547
800B100FT500XT
物料型号:800B系列
器件简介:KYOCERA AVX的800B系列在要求严格的高射频功率应用中提供卓越的性能,这些应用需要一致和可靠的操作。高导电金属电极系统、优化的外壳几何形状和专有介质的结合,实现了最低的等效串联电阻(ESR)。KYOCERA AVX的新型NPO低损耗坚固介质设计用于在高射频功率应用中提供优越的热传递。超低ESR和卓越的热性能确保800B系列产品是您从VHF到微波频率的高射频功率应用的最佳选择。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 品质因数(Q):在1MHz时为2000 - 电容温度系数(TCC):-55°C至+125°C范围内为±30ppm/°C - 绝缘电阻(IR):0.1pF至1000pF时,最小为10^5兆欧姆(@ +25°C额定WVDC),最小为10^6兆欧姆(@ +125°C额定WVDC) - 工作电压(WVDC):见电容值表 - 介质耐电压(DWV):外壳B:额定WVDC的250%持续5秒 - 老化效应:无 - 压电效应:无 - 电容漂移:±(0.02%或0.02pF),取较大值 - 工作温度范围:-55°C至+125°C(工作电压不降额) - 端接样式:见机械配置 - 端接强度:芯片端接可承受至少5磅的拉力,典型15磅,持续5秒,垂直于电容器端接表面的测试按MIL-STD-202方法211
功能详解:文档中未提供详细的功能解释。
应用信息: - 航空电子 - 公共安全无线电 - 无线通信 - VHF/UHF/HDTV广播发射机 - 电信 - WiMAX - 微波通信系统和卫星系统
封装信息: - 垂直方向胶带和卷轴 - 符合RoHS
800B100FT500XT 价格&库存
很抱歉,暂时无法提供与“800B100FT500XT”相匹配的价格&库存,您可以联系我们找货
