CR-05FA7---4R7
CR-05FA7---4R7
    VIKING(光颉)
    电阻器 4.7Ω ±1% 1/8W ±200ppm/℃ 0805
CR-05FA7---4R7 数据手册
Data Sheet Customer: Product: Automotive Grade Chip Resistor – CR..A Series Size: 0201/0402/0603/0805/1206/1210/2010/2512 Issued Date: 10-Mar-21 Edition: REV.B5 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) Automotive Grade Chip Resistor【CR..A Series】 Automotive Grade Chip Resistor-CR..A Series ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -AEC-Q200 Compliance -Highly reliable multilayer electrode construction -Special construction to prevent sulfuration in a sulfur containing environment -Compatible with all soldering process -100% CCD inspection ■Construction ■Applications -Automotive Industry L -Telecommunication Equipments D1 -Radio and Tape Recorders, TV Tuners -Digital Cameras, Watches, Pocket Calculators     W T   -Computers, Instruments -Medical Equipment  D2  Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat ■Dimensions Size L W T D1 D2 (Inch) (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) CR-01 0201 0.60±0.03 0.30±0.03 0.23±0.03 0.15±0.05 0.15±0.05 0.150 CR-02 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 CR-03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 CR-05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 CR-06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 CR-10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 CR-0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 CR-12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type www.viking.com.tw For detail questions, contact:sales@viking.com.tw 1 Edition: REV.B5 Revision: 10-Mar-2021 【CR..A Series】 Automotive Grade Chip Resistor ■Part Numbering Part Number:CR-03FA7---10R CR- 03 F Product Type Dimensions Resistance Tolerance D: ±0.5% F: ±1% J: ±5% 01: 0201 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 ■Recommend Land Pattern Packaging Code 4: 7” Reel 4Kpcs 6: 7” Reel 10Kpcs 7: 7” Reel 5Kpcs 9: 10” Reel 8Kpcs A: 10” Reel 10Kpcs B: 10” Reel 20Kpcs C: 13” Reel 40Kpcs D: 13” Reel 20Kpcs C: High Power & Automotive Grade - - 1 0 R Resistance - - - 1R2: 1.2Ω - - - 3K3: 3.3KΩ - - - 10K: 10KΩ - - 100K: 100KΩ “-“ to fill up 6 spaces 100 . A CR-01 CR-02 A (mm) 0.30 0.50 B (mm) 0.25 0.45 C (mm) 0.30 0.60 CR-03 CR-05 CR-06 CR-10 CR-0A CR-12 0.90 1.20 2.00 2.00 3.80 4.90 0.60 0.70 0.90 0.90 0.90 1.60 0.90 1.30 1.60 2.80 2.80 3.50 Type - ■Derating Curve Derating Curve C B 7 Function Code A: Automotive Grade Power ratio (%) CR- A CR-02 CR-03 CR-05 CR-06 CR-10 CR-0A CR-12 80 60 40 CR-01 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) ■Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition: REV.B5 Revision: 10-Mar-2021 【CR..A Series】 Automotive Grade Chip Resistor ■Standard Electrical Specifications Power Rating at 70C Jumper Rated Current Item Type Operating Temp. Range Max. Operating Voltage Max. Overload Voltage 25V 50V Resistance Range ±1%(E24、E96) -55 ~ +125C Jumper: 1A 1/16W CR-02 (0402) -55 ~ +155C 50V CR-03 (0603) 100V 75V CR-05 (0805) -55 ~ +155C 150V CR-06 (1206) -55 ~ +155C 200V CR-10 (1210) -55 ~ +155C 200V CR-0A (2010) -55 ~ +155C 200V CR-12 (2512) 0Ω (
CR-05FA7---4R7
物料型号:文档中列出了不同尺寸的汽车级芯片电阻,型号包括CR-01、CR-02、CR-03、CR-05、CR-06、CR-10、CR-0A和CR-12,分别对应0201、0402、0603、0805、1206、1210、2010和2512尺寸。
器件简介:这些电阻属于汽车级芯片电阻CR..A系列,符合AEC-Q200标准,具有高可靠性的多层电极结构,特殊构造以防止含硫环境中的硫化,并兼容所有焊接工艺。
引脚分配:文档中没有明确提到引脚分配,但提到了边缘电极和外部电极,以及电阻层、底电极、阻挡层、主要涂层和次要涂层。
参数特性:电阻的尺寸、重量、功率等级、工作温度范围、最大操作电压、最大过载电压、电阻范围、温度系数(TCR)等参数均有详细列出。
功能详解:文档中提到了电阻的应用领域,包括汽车行业、电信设备、收音机、磁带录音机、电视调谐器、数码相机、手表、袖珍计算器、计算机、仪器和医疗设备。
应用信息:电阻适用于多种应用,包括汽车行业、电信设备等,具体应用领域在简介中已有说明。
封装信息:文档提供了不同尺寸的封装信息,包括英寸尺寸、长度、宽度、厚度、D1和D2尺寸以及每1000件的重量。
CR-05FA7---4R7 价格&库存
很抱歉,暂时无法提供与“CR-05FA7---4R7”相匹配的价格&库存,您可以联系我们找货
