RT-05NL7---36K
RT-05NL7---36K
    VIKING(光颉)
    电阻器 36KΩ 0,-10% 1/8W ±100ppm/℃ 0805
RT-05NL7---36K 数据手册
Data Sheet Customer: Product: Trimmable Thick Film Chip Resistor - RT Series Size: 0402/0603/0805/1206/1210/2010/2512 Issued Date: 10-Mar-21 Edition: REV.B1 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) Trimmable Thick Film Chip Resistor【RT Series】 Trimmable Thick Film Chip Resistor ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -Suitable for laser fine tune -Small size and light weight -Highly reliable multilayer electrode construction -Compatible with all soldering process ■Construction ■Applications L -Tuner -Sensor Control Circuit D1 -Camcorder     W T   -Portable Audio -Photo Sensor -Portable Measuring Equipment  D2  Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat ■Dimensions L W T D1 D2 (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 RT-03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 RT-05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 RT-06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 RT-10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 RT-0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 RT-12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type Size (Inch) RT-02 www.viking.com.tw For detail questions, contact:sales@viking.com.tw 1 Edition: REV.B1 Revision: 10-Mar-2021 【RT Series】 Trimmable Thick Film Chip Resistor ■Part Numbering RT- 03 N Product Type Dimensions 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 RT- Resistance Tolerance N: 0~-10% P: 0~-20% Q: 0~-30% ■Recommend Land Pattern L 7 Function Code L: Standard - Packaging Code 4: 7” Reel 4Kpcs 6: 7” Reel 10Kpcs 7: 7” Reel 5Kpcs 9: 10” Reel 8Kpcs A: 10” Reel 10Kpcs B: 10” Reel 20Kpcs C: 13” Reel 40Kpcs D: 13” Reel 20Kpcs F: Bulk - - 1 R 2 Resistance - - - 1R2: 1.2Ω - - - 3K3: 3.3KΩ - - - 10K: 10KΩ - - 100K: 100KΩ “-“ to fill up 6 spaces ■Derating Curve Derating Curve . 100 B Power ratio(%) C A Type A (mm) B (mm) C (mm) RT-02 0.50 0.45 0.60 RT-03 0.90 0.60 0.90 RT-05 1.20 0.70 1.30 RT-06 2.00 0.90 1.60 RT-10 2.00 0.90 2.80 RT-0A 3.80 0.90 2.80 RT-12 4.90 1.60 3.50 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) ■Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition: REV.B1 Revision: 10-Mar-2021 【RT Series】 Trimmable Thick Film Chip Resistor ■Standard Electrical Specifications Type Item Power Rating at 70°C Operating Temp. Range Max. Operating Voltage Max. Overload Voltage RT-02 (0402) 1/16W 50V 100V RT-03 (0603) 1/10W 50V 100V RT-05 (0805) 1/8W 150V 300V RT-06 (1206) 1/4W 200V 400V RT-10 (1210) 1/3W 200V 400V RT-0A (2010) 3/4W 200V 400V RT-12 (2512) 1W 250V 500V -55 ~ +155C Resistance Range 0~ -10% 0~ -20% TCR (PPM/°C) 0~ -30% 1Ω - 10MΩ ±200 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ ±200 ±100 ±200 Operating Voltage=√(P*R) or Max. operating voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. overload voltage listed above, whichever is lower. ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. ■Environmental Characteristics Item Temperature Coefficient of Resistance (T.C.R.) Requirement (1.0%+0.05Ω) Insulation Resistance 10G Damp Heat with Load Dry Heat JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. Short Time Overload Endurance Test Method At 25C/-55C and 25C/+125C, 25C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds. JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 (2.0%+0.10Ω) 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 (2.0%+0.10Ω) 402C, 90~95% R.H. RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 (1.0%+0.05Ω) at +155C for 1000 hrs Bending Strength www.viking.com.tw JIS-C-5201-1 4.33 IEC-60115-1 4.33 (1.0%+0.05Ω) Bending once for 60 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm For detail questions, contact:sales@viking.com.tw 3 Edition: REV.B1 Revision: 10-Mar-2021 【RT Series】 Trimmable Thick Film Chip Resistor Item Requirement Solderability Test Method JIS-C-5201-1 4.17 IEC-60115-1 4.17 95% min. coverage 2455C for 3 seconds Resistance to Soldering Heat JIS-C-5201-1 4.18 IEC-60115-1 4.18 (0.5%+0.05Ω) 2605C for 10 seconds Voltage Proof JIS-C-5201-1 4.7 IEC-60115-1 4.7 No breakdown or flashover 1.42 times Max. Operating Voltage for 1 minute Leaching Individual leaching area ≦5% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Total leaching area ≦ 10% 2605C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles Rapid Change of Temperature (0.5%+0.05Ω) RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH ▓Packaging Reel Specifications & Packaging Quantity Type RT-02 Paper RT-03 RT-05 RT-06 Paper RT-10 RT-0A RT-12 Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 20K 8mm 13 inch 330±1.0 4K 12mm 7 inch 178.5±1.5 8K 12mm 10 inch 250±1.0 Packaging Quantity ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 60 60 60 +1/-0 +1/-0 Embossed www.viking.com.tw For detail questions, contact:sales@viking.com.tw 4 Edition: REV.B1 Revision: 10-Mar-2021 【RT Series】 Trimmable Thick Film Chip Resistor Paper Tape Specifications Bottom Tape Top Tape ψ D0 E A F W B T Type A (mm) Paper Tape Resistor B (mm) W (mm) P1 E (mm) F (mm) P2 P0 Direction of unreeling P0 (mm) P1 (mm) ΦD0 (mm) P2 (mm) T (mm) RT-02 0.65±0.10 1.15±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 RT-03 1.10±0.10 1.90±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 RT-05 1.60±0.10 2.40±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RT-06 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RT-10 2.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 Embossed Plastic Tape Specifications Top Tape ψ D0 E A F W B ψD11.5+0.25,-0 T Resistor P1 P2 P0 Direction of unreeling Embossed Tape A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) RT-0A 2.80±0.10 5.40±0.20 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 RT-12 3.50±0.10 6.70±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 www.viking.com.tw For detail questions, contact:sales@viking.com.tw 5 P2 (mm) ΦD0 (mm) Type T (mm) Edition: REV.B1 Revision: 10-Mar-2021 【RT Series】 Trimmable Thick Film Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version A8 Jun 03, 2014 - - Environmental Characteristics updated Version A9 Jul 15, 2016 - - Remove Material Description - Modify Storage Temperature Version B - - Modify TCR Test description May 20, 2019 Version B1 Mar 10, 2021 www.viking.com.tw - Modify Bending Test description - Modify 2010 Embossed Plastic Tape B Specification - Modify Soldering Condition (IPC/JEDEC J-STD-020) - For detail questions, contact:sales@viking.com.tw 6 Edition: REV.B1 Revision: 10-Mar-2021
RT-05NL7---36K
物料型号:RT Series,包括多种尺寸如0402、0603、0805、1206、1210、2010、2512。
器件简介:这是一系列可调节的厚膜芯片电阻器,使用钌基材料制成,适用于激光微调,具有小尺寸、轻重量、高可靠性的多层电极结构,兼容所有焊接工艺。
引脚分配:文档中未明确列出引脚分配,但通常这类电阻器为无引脚的表面贴装元件。
参数特性:包括尺寸、重量、功率额定值、工作温度范围、最大工作电压、电阻范围、温度系数等。
功能详解:适用于调谐器、传感器控制电路、摄像机、便携式音频设备、光电传感器、便携式测量设备等。
应用信息:适用于需要精确电阻调整的应用场合。
封装信息:提供了不同尺寸的封装信息,包括长、宽、高、孔径等尺寸参数,以及每千片的重量。
RT-05NL7---36K 价格&库存
很抱歉,暂时无法提供与“RT-05NL7---36K”相匹配的价格&库存,您可以联系我们找货
