RG1005N-2431-P-T1
RG1005N-2431-P-T1
    SUSUMU
    贴片电阻 0402 2.43KΩ ±0.02% 1/16W ±10ppm/℃
RG1005N-2431-P-T1 数据手册
RG series SUSUMU CO.,LTD Ultra precision 0.02%, 0.05%, 0.1%, 0.25%, 0.5%, tolerance Thin Film Chip Resistor FEATURES • High Reliability and Excellent Stability at different environmental conditions • Low noise, THIN FILM(NiCr) construction • EIA Standard case size(0402, 0603, 0805, 1206) • RoHS Compliance and 100% Lead-Free (Matte Sn termination finished) APPLICATIONS • Automotive • Test & Measurement • Optical & Telecommunication • Medical and Industrial Equipment Electrical Specification Power Rating ar 85 oC Type Size Low (ultra precision) Regular High Resistance Tolerance (Code) +0.5% (D) Resistance Range (ohm) 10-100K +0.25% (C) RG1005 0402 0.032W 0.063W 0.125W +0.1% (B) 47-100K +0.05% (W) RG1608 0603 0.063W +0.02% (V) 100-2.94K +0.5% (D) 10-360K +0.25% (C) 47-274K 0.166W 0.1W +0.1% (B) 47-332K +0.05% (W) RG2012 RG3216 0805 1206 0.1W 0.125W 0.125W +0.02% (V) 100-4.99K +0.5% (D) 10-1M +0.25% (C) 47-1M +0.1% (B) 47-1M 0.25W +0.05% (W) 47-475K +0.02% (V) 100-10K +0.5% (D) 47-1M +0.25% (C) 47-1M +0.1% (B) 47-1M 0.25W +0.05% (W) 47-1M +0.02% (V) 100-33.2K Temperature Coefficient (Code) (ohm) (ppm/oC) 10-46.4 47-100K 100-2.94K 47-100K 100-2.94K 47-100K 100-2.94K 47-100K 100-2.94K 100-2.94K 10-46.4 47-360K 47-274K 100-4.99K 47-274K 100-4.99K 47-332K 47-274K 100-4.99K 47-332K 47-274K 100-4.99K 100-4.99K 10-46.4 47-1M 47-475K 100-10K 47-1M 100-10K 47-1M 47-475K 100-10K 47-475K 47-475K 100-10K 100-10K 10-46.4 10-1M 100-33.2K 47-1M 100-33.2K 47-1M 100-33.2K 47-1M 100-33.2K 100-33.2K 100(R) 25(P), 10(N) 5(V) 25(P), 10(N) 5(V) 25(P), 10(N) 5(V) 25(P), 10(N) 5(V) 25(P), 10(N), 5(V) 50(Q) 25(P) 10(N) 5(V) 25(P), 10(N) 5(V) 25(P) 10(N) 5(V) 25(P) 10(N) 5(V) 25(P), 10(N), 5(V) 50(Q) 25(P) 10(N) 5(V) 25(P), 10(N) 5(V) 25(P) 10(N) 5(V) 25(P) 10(N) 5(V) 25(P), 10(N), 5(V) 50(Q) 25(P), 10(N) 5(V) 25(P), 10(N) 5(V) 25(P), 10(N) 5(V) 25(P), 10(N) 5(V) 25(P), 10(N), 5(V) Max. operating Voltage Resistance Values (E-series) 25V E-24, E-96 75V E-24, E-96 100V E-24, E-96 150V E-24, E-96 www.susumu.co.jp RG series SUSUMU CO.,LTD Ultra precision 0.02%, 0.05%, 0.1%, 0.25%, 0.5%, tolerance Thin Film Chip Resistor Performance Dimensions & Footprints Dimensions inch (mm) L P P R G 1005 R G 1608 W R G 2012 T R G 3216 L W P T .0 4 0 ± .0 0 2 .0 2 0 ± .0 0 2 .0 0 8 ± .0 0 4 .0 1 4 ± .0 0 2 (1 .0 ± 0 .0 5 ) (0 .5 ± 0 .0 5 ) (0 .2 ± 0 .1 ) (0 .3 5 ± 0 .0 5 ) .0 6 3 ± .0 0 8 .0 3 1 ± .0 0 8 .0 1 2 ± .0 0 8 0 .0 1 6 ± .0 0 4 (1 .6 ± 0 .2 ) (0 .8 ± 0 .2 ) (0 .3 ± 0 .2 ) (0 .4 ± 0 .1 ) .0 7 9 ± .0 0 8 .0 4 9 ± .0 0 8 .0 1 6 ± .0 0 8 0 .0 1 6 ± .0 0 4 (2 .0 ± 0 .2 ) (1 .2 5 ± 0 .2 ) (0 .4 ± 0 .2 ) (0 .4 ± 0 .1 ) .1 2 6 ± .0 0 8 .0 6 3 ± .0 0 8 .0 2 ± .0 1 0 .0 1 6 ± .0 0 4 (3 .2 ± 0 .2 ) (1 .6 ± 0 .2 ) (0 .5 ± 0 .2 5 ) (0 .4 ± 0 .1 ) Dimensions (mm) c a b c R G 1005 0 .5 1 .6 0 .6 R G 1608 1 .0 3 .0 1 .2 a R G 2012 1 .2 4 .0 1 .7 b R G 3216 2 .0 5 .0 2 .0 Recommended Reflow Curve Power Derating Curve Sldering Temperature Profile :For operation above 85degC, power rating must be derated according to the following chart 300 Peak Temperature 260oC 250 1-5oC/Sec. 1-5oC/Sec. 200 150 10 Sec. 100 120 Sec. 50 1-9oC/Sec. 0 Ordering information RG 1608 TYPE S iz e N 104 TCR W R - Va lu e s - T5 To le r a n c e Package 1005 V = 5 p p m /oC 3 d ig its f o r E 2 4 s e r ie s P = 0 .0 2 % T1=1000 1608 N =10ppm / C (E x .1 0 4 = 1 0 0 K W = 0 .0 5 % T5=5000 2012 P = 2 5 p p m /oC 4 d ig its f o r E 9 6 s e r ie s B = 0 .1 % 3216 Q = 5 0 p p m /oC (E x .4 9 9 2 = 4 9 .9 K C = 0 .2 5 % o R =100ppm / C o oh m ) oh m ) D = 0 .5 % www.susumu.co.jp RG series SUSUMU CO.,LTD Ultra precision 0.02%, 0.05%, 0.1%, 0.25%, 0.5%, tolerance Thin Film Chip Resistor Reliability Test Data Tape & Reel Dimensions (mm) www.susumu.co.jp
RG1005N-2431-P-T1
物料型号:RG系列,包括RG1005, RG1608, RG2012, RG3216。
器件简介:超精密薄膜芯片电阻,提供0.02%, 0.05%, 0.1%, 0.25%, 0.5%的容差。
引脚分配:文档中未明确提供引脚分配信息,但提供了尺寸和封装信息
参数特性: - 高可靠性和在不同环境条件下的卓越稳定性。 - 低噪音,采用薄膜(NiCr)结构。 - 符合EIA标准尺寸(0402, 0603, 0805, 1206)。 - 符合RoHS标准,100%无铅(表面锡处理)。
功能详解:文档中提供了详细的电气规格,包括功率等级、电阻容差、温度系数、最大工作电压和电阻值系列。
应用信息:适用于汽车、测试与测量、光学与通信、医疗和工业设备。
封装信息:提供了不同型号的尺寸和封装细节,包括宽度(W)、间距(P)、厚度(T)以及长宽(a, b, c)。
RG1005N-2431-P-T1 价格&库存
很抱歉,暂时无法提供与“RG1005N-2431-P-T1”相匹配的价格&库存,您可以联系我们找货
