G08F1E222MN0B0S0N0
G08F1E222MN0B0S0N0
    STE(松田)
    CAP_D8X4MM_TM
    安规电容 CAP_D8X4MM_TM 2.2nF ±20% 250V Y5V
G08F1E222MN0B0S0N0 数据手册
Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) SPECIFICATION CE Series(Y2-Series) Company and Factory Name: SHANTOU FREE TRADE ZONE SONGTIAN ELECTRONIC TECHNOLOGY CO.,LTD Add: Songtian science and technology park,Free trade zone,Shantou,City,Guangdong,China. E-mail: info@songtian.cn P.O.BOX: 515071 Homepage: http://songtian-ste.com 1 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) Contents 1. Applications.......................................................................................................................................................3 2. Part Number Code........................................................................................................................................... 3 3. Electrical Characteristics.................................................................................................................................4 4. Dimensions....................................................................................................................................................... 4 5. nternal Structure...............................................................................................................................................6 6. Marking.............................................................................................................................................................. 6 7. Temperature Characteristic Curves.............................................................................................................. 7 8. Taping And Dimensions.................................................................................................................................. 7 9. Safety Certificate.............................................................................................................................................. 8 10. Performance Test Methods And Requirements........................................................................................8 11. Reliability Test Methods And Requirements............................................................................................. 9 12. Storage Conditions......................................................................................................................................11 13. Environmental Compliance........................................................................................................................ 12 14. Packaging..................................................................................................................................................... 12 2 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) 1. Applications Can be used for power supply noise suppression circuit in cross connection and bypass.It is a primary and secondary coupling X/Y capacitor used as AC line filter and switching power supply and AC converter. 2. Part Number Code Part Number Code G 08 F Rated Voltage G:Y2 Core Diameter 07:mm 08:8mm 09:9mm 10:10mm 1 E 222 Pitch E:7.5mm D:10.0mm M N0 Tolerance K:±10% M:±20% B Nominal capacitance 101:100pF 151:150pF 221:220pF 471:470pF 681:680pF 102:1000pF 152:1500pF 222:2200pF 332:3300pF 472:4700pF S Package B: Bulk T:Tape Foot Type 1:Long straight 2:Outside Crimped 3:Short Straight 8:Vertical Crimped Temperature Characteristic B:Y5P E:Y5U F:Y5V 0 0 N 0 Inner Management Environmental Standard 0:RoHS 2:RoHS+Halogen-Free Lead Length S0~S9:1.0~1.9mm X0~X9:2.0~2.9mm A0~A9:3.0~3.9mm B0~B9:4.0~4.9mm C0~C9:5.0~5.9mm D0~D9:6.0~6.9mm E0~E9:7.0~7.9mm 3 Lead Length F0~F9:8.0~8.9mm G0~G9:9.0~9.9mm H0~H9:10.0~10.9mm J0~J9:11.0~11.9mm K0~K9:12.0~12.9mm L0~L9:13.0~13.9mm M0~M9:14.0~14.9mm Lead Length M0~M9:14.0~14.9mm N0:16~27.0mm(Bulk) Crimped Lead Taped N0:H0=16.5mm P0:H0=17.0mm Q0:H0=19.0mm Straight Lead Q0:20.0mm Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) 3. Electrical Characteristics Capacitance and Dissipation factor testing condition 25℃, 1KHz, 1Vrms Dissipation Factor(tanδ) ≤2.5% Rated Voltage 250VAC Withstand Voltage 2500VAC Insulation Resistance (I.R.) ≥10000MΩ Temperature Characteristic Y5P, Y5U, Y5V 4. Dimensions PN of STE Dimension (mm) D Max T Max L Min F±0.8 Φd±0.05 H1 Max C Max Marking Packing G07B1E101KN0B0 S0N0 7.0 4.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk G07B1E151KN0B0 S0N0 7.0 4.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk G07B1E221KN0B0 S0N0 7.0 4.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk G07B1E471KN0B0 S0N0 7.0 4.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk 4 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) G08B1E681KN0B0 S0N0 8.5 4.0 16.0 10.0 0.6 11.0 2.5 Example 2 Bulk G07E1E102MN0B0 S0N0 7.0 4.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk G09E1E152MN0B0 S0N0 9.0 4.0 16.0 10.0 0.6 11.5 2.5 Example 1 Bulk G10E1E222MN0B0 S0N0 10.0 4.0 16.0 10.0 0.6 12.5 2.5 Example 1 Bulk G07F1E152MN0B0 S0N0 7.0 4.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk G08F1E222MN0B0 S0N0 8.0 4.0 16.0 10.0 0.6 10.5 2.5 Example 2 Bulk G09F1E332MN0B0 S0N0 9.0 4.0 16.0 10.0 0.6 11.5 2.5 Example 1 Bulk G10F1E472MN0B0 S0N0 10.0 4.0 16.0 10.0 0.6 12.5 2.5 Example 1 Bulk G07B1E101KQ0T0 S0N0 7.0 4.0 / 10.0 0.6 9.5 2.5 Example 2 Taping G07B1E471KQ0T0 S0N0 7.0 4.0 / 10.0 0.6 9.5 2.5 Example 2 Taping G08B1E681KQ0T0 S0N0 8.5 4.0 / 10.0 0.6 11.0 2.5 Example 2 Taping G09E1E152MQ0T0 S0N0 9.0 4.0 / 10.0 0.6 11.5 2.5 Example 1 Taping G09F1E332MQ0T0 S0N0 9.0 4.0 / 10.0 0.6 11.5 2.5 Example 1 Taping 5 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) 5. Internal Structure No. Name Material 1 Electrode Metal Layer 2 Ceramic Dielectric Ceramic 3 Lead Free Tin Bar 4 Lead Wire CP wire 5 Coating Epoxy Resin 6 Marking Laser marking 6. Marking ①Registered Trademark Type(CE:Y2) □□□ M (±20%) ②CE ③Nominal Capacitance ④Capacitance Tolerance ENEC(EU) VDE ⑤Safety Certification Sign KTL CQC UL ⑥Rated Voltage ⑦Sub-Class of Safety Performance Example 1:Y2 Single Sided Printing 250V~(250VAC) X1 Y2 Example 2: Y2 Double Sided Printing 6 Note Color:Blue Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) 7. Temperature Characteristic Curves 8. Taping And Dimensions Code Po P P1 P2 F ΔS Δh W Wo Size(mm) 12.7 25.4 8.95 12.7 7.5 0 0 17.0 10.5 Tolerance ±0.3 ±1.0 ±0.7 ±1.3 ±0.8 ±2.0 ±2.0 +1.5/-1.0 Max Code W1 W2 H1 Do H L t1 t2 c Size(mm) 9.0 3.0 45.0 4.0 20.0 11.0 0.5 1.7 2.5 Tolerance +0.75/-0.5 Max Max ±0.2 +1.5/-1 Max ±0.2 Max / 7 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) 9. Safety Certificate USA Canada Certification Body UL CUL Korea KTL China CQC Germany VDE EU ENEC Country Report Reference Certificate No. Capacitance Range UL60384-14 E208107 100~10000pF SU03031-7001B 100~10000pF CQC19001213202 100~10000pF 40025748 100~10000pF 40025748 100~10000pF K60384-14 (2015) GB/T 6346.14-2015 En 60384-14: 2017-04 En 60384-14: 2017-04 Rated Voltage X1Y2: 250VAC 10. Performance Test Methods And Requirements No. 1 Item Standard Test Method Temperature Range -25℃~125℃ / Capacitors must be visually inspect to No opparent defect,size within the check if there’s opparent defect and normal range measure size with vernier caliper 2 Appearance/Size 3 Marking 4 Capacitance 5 D.F. D.F.≤2.5% 6 I.R. >10000MΩ Clear and easy to recognize Within the specified tolerance Dielectric Strength 25 ℃ ,1 ± 0.1 KHz, 1.0 V. 500VDC, 60s±5s . Between No breakdown and flashover Leads 7 Visual inspection Between Leads and No breakdown and flashover Body 8 Between terminals: AC2500V (r.m.s.) 60s, ≤50mA As shown in figure at right,a metal foil should be closely wrapped around the body of the capacitor to the distance of about 3 to 4mm from each terminal.hen,the capacitor should be inserted into a container filled with metal balls of about 1mm diameter.voltage appliedA C2500V(r.m.s.),60s Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) 11. Reliability Test Methods And Requirements No. Item Standard B(Y5P) Capacitance change ±10% E(Y5U) +22/-56% Char. 1 2 Temperature Characteristics Solderability Test Method The capacitance measurement should be made at each step specified in Table 3 < Table 3> Step 1 2 3 4 5 Temperature 20 -25 20 85 20 (℃) ±2 ±2 ±2 ±2 ±2 F(Y5V) +30/-80% Temperature range: -25 ~+85℃ Lead wire should be 245±3℃, 3±0.3s. soldered with uniform Solder composition: coating on the axial direction Sn96.5Ag3.0Cu0.5 over 95% of the circumferential direction. Appearance No marked defect 3 Solder Resistance Heat Up Capacitance Within ±10% change I.R. Dielectric Strength 260 ± 5℃,10.0 ± 0.5 s. ≥1000MΩ Per 10.1[Basic characteristics] item7 10~55Hz, 0.75mm, 10Hz→55Hz→10Hz. 1min Apply for a total of 6 hours, 2 hrs each in 3 mutually perpendicular directions. Appearance No visible damage 4 Vibration Capacity D.F. Within the tolerance .≤2.5% Appearance No visible damage 5 Humidity (Under Steady State) Capacity Rate of Change I.R. ≤±15% 40±2℃, 90-95%RH, 500±12 hours. >5000MΩ Withstand Per 10.1[Basic Voltage characteristics] item7 9 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) No. Item Standard Test Method Appearance No visible damage 6 Humidity Loading Capacitance ≤±15% Change I.R. 40±2℃, 90~ 95% RH, Apply with UR,500±12 hours. >5000MΩ Dielectric Per 10.1[Basic Strength characteristics] item7 Appearance No visible damage Impulse Voltage: 5KVDC,three times. After the capacitors are applied to life test. Capacitance Within ±20% change 7 Life Test I.R. >5000MΩ Dielectric Per 10.1[Basic Strength characteristics] item7 125+2/-0℃,relative humidity of 50% max, 1000 hours,1.7*UR (r.m.s.), except that once each hour the voltage is increased to AC1000V(r.m.s.) for 0.1 sec. The Varistor under test shall be held in the flame in the position which best promotes burning. Each specimen shall be exposed once in the flame. Specifically as follows: level C requirements. 8 9 Capacitor volume (mm3) Apply flame time (S) Passive The burning time shall not be exceeded the standard. Flammability The tissue paper shall ignite. Robustness of Termination Tensile Strength Bending Strength Class volume <250 250< volume≤ 500 500< volume≤ 1750 volume >1750 Maximum burning time (S) A 15 30 60 120 3 B C 10 5 20 10 30 20 60 30 10 30 As shown in the figure at right, 10N, 10±1 sec. Lead wire should not be cut off. Capacitor Each lead wire should be subjected to 5N weight should not be broken. and then a 90° bend, at the point of egress, in one direction, return to original position, and then apply a 90° bend in the opposite direction at the rate of one bend in 2 to 3 sec. 10 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) No. Item Standard Test Method No visible Capacitors should be tested in the order shown in the damage following table (for one cycle) for five consecutive cycles. Temperature cycling Capacitance B(Y5P)/E(Y5U): (℃) Order (min) ±20%; Rate of Change F(Y5V): ±30%。 1 -25 +0/-3 30 2 +25 +0/-3 3 B(Y5P)/E(Y5U): Rapid D.F.≤5.0% 3 125 +3/-0 30 D.F. Temperature F(Y5V): 4 +25 +0/-3 3 Changes D.F.≤7.5% I.R. >5000MΩ [Pre-treatment]: Stored at 85 ± 2 ° C , 1 hour and then 24 ± 2 hours before Per 10.1[Basic making initial measurements. Withstand characteristics] [Treatment After testing]: Voltage Capacitors must be stored at room temperature for 24 ± 2 item7 hours. The capacitor should be individually wrapped in at least one but not more than two complete layers of cheese-cloth. The capacitor should be subjected to discharges for 20 times. he interval between successive discharges should be 5 sec. The UAC should be maintained for 2 min. after the last discharge. Appearance 10 11 Active The Flammability cheese-cloth (Only for Y2) should not be on fire. C1, 2:1UF±10% C3:0.033UF±5%, 10KV Ct:3UF±5% 10KV Cx: Capacitor under test F: Fuse,Rated 10A R:100Ω±5% Ur: Rated Voltage Ut: Voltage applied to Ct L1 to 4: 1.5mH±20% 16A Rod core choke 12. Storage Conditions 12.1 Storage Temperature: ≤35℃. 12.2 Relative Humidity: ≤70% RH. 12.3 Keep away from corrosive atmosphere and sunlight. 12.4 Period : 1 year. 11 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) 13. Environmental Compliance: RoHS Compliance REACH Compliance 14. Packaging External Packaging (Bulk) Internal Packaging (Bulk) External Packaging (Taping) Internal Packaging (Taping) Dimension Description (cm) External Packaging (Bulk) Internal Packaging (Bulk) L B H L B H 41.0 29.0 16.0 18.6 27.3 12.6 External Packaging (Taping) L B H 54.0 36.0 26.3 Internal Packaging (Taping) B A C 4.4 33.5 26.2 12 Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2) SPQ Reference Table Type Specification P=5 B P=7.5 E Bulk P=10 Type D SPQ Quantity Long Lead/Short Lead Φ≤13 500 Long Lead/Short Lead Φ≤8 1000 Long Lead/Short Lead Φ>8 500 Short lead 1000 Long Lead 500 Long Lead 14≦Φ
G08F1E222MN0B0S0N0 价格&库存
很抱歉,暂时无法提供与“G08F1E222MN0B0S0N0”相匹配的价格&库存,您可以联系我们找货
G08F1E222MN0B0S0N0
  • 1+0.46860
  • 50+0.27610
  • 1000+0.24860
库存:6
G08F1E222MN0B0S0N0
  • 10+0.22847
  • 100+0.20807
  • 500+0.18767
  • 1000+0.16727
  • 2000+0.15367
  • 4000+0.14959
库存:635
G08F1E222MN0B0S0N0
库存:1257
G08F1E222MN0B0S0N0
  • 10+0.28950
  • 100+0.23220
  • 300+0.20330
  • 1000+0.16090
  • 5000+0.14400
  • 10000+0.13560
库存:1257
