PWR13FTEU40R2
PWR13FTEU40R2
    VIKING(光颉)
    电阻器 40.2Ω ±1% 0.5W ±100ppm/℃ 1210
PWR13FTEU40R2 数据手册
Data Sheet Customer: Product: Pulse Withstanding Chip Resistor - PWR Series Size: 0402/0603/0805/1206/1210/2010/2512 Issued Date: 10-Mar-21 Edition: REV.C7 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) 【PWR Series】 Pulse Withstanding Chip Resistor Pulse Withstanding Chip Resistor – PWR Series ■Features -Tolerance from ±0.5%~5% -High power rating -Excellent pulse withstanding performance -Improved working voltage ratings -Standard package sizes of 0402~2512 -AEC-Q200 Compliance ■Applications -Metering (Testing/Measurement) -Diagnostic Equipment -Medical Devices -Industrial Controls -Plasma -LCD Video Monitors ■Construction L D1     W T    Alumina Substrate  External Electrode  Bottom Electrode  Resistor Layer  Top Electrode  Primary Overcoat  Edge Electrode  Secondary Overcoat  Barrier Layer  D2 ■Dimensions Type Size (Inch) L (mm) W (mm) T (mm) D1 (mm) D2 (mm) PWR02 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 Weight (g) (1000pcs) 0.63 PWR03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 PWR05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 PWR05 (1/2W) 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 5.049 PWR06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 PWR06 (3/4W) 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 9.541 PWR13 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 PWR10 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 PWR12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 PWR12(2W) 2512 6.35±0.20 3.15±0.15 0.60±0.10 0.60±0.25 0.60±0.20 42 www.viking.com.tw For detail questions, contact : sales@viking.com.tw 1 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor Derating Curve ■Derating Curve Power ratio(%) . 100 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) ■Part Numbering PWR Product Type 12 Dimensions 02: 0402 03: 0603 05: 0805 06: 1206 13: 1210 10: 2010 12: 2512 J T Resistance Tolerance D: ±0.5% F: ±1% J: ±5% -: No specified E Packaging Code TCR (PPM/°C) T: 7”Taping Reel V:10”Taping Reel W:13”Taping Reel E: ±100 F: ±200 G: ±300 4 : ±350 -: No specified A 1001 Power Rating A: 1.5W T: 1W Q: 3/4W U: 1/2W G: 2/5W O: 1/3W V : 1/4W W: 1/8W X: 1/10W P: 1/5W S: 2W Marking Resistance 1001: 1KΩ 1004: 1MΩ R0R0: 0Ω : Standard Marking N: No Marking ■Standard Electrical Specifications Item Power Rating at 70°C Operating Temp. Range Max. Operating Voltage Max. Overload Voltage PWR02 (0402) 1/5W -55 ~ +155C 50V 100V PWR03 (0603) 1/10W -55 ~ +155C 50V 100V Type PWR05 (0805) 1/8W -55 ~ +155C 150V 300V PWR06 (1206) 1/3W -55 ~ +155C 200V 400V PWR13 (1210) 1/2W -55 ~ +155C 200V 400V PWR10 (2010) 3/4W -55 ~ +155C 400V 800V PWR12 (2512) 1.5W -55 ~ +155C 500V 1000V www.viking.com.tw Resistance Range ±0.5% (E24,E96) - TCR (PPM/°C) ±300 100Ω-1MΩ 20.5Ω-1MΩ ±100 10Ω - 294Ω 1Ω - 294Ω ±200 300Ω - 1MΩ 10Ω - 294Ω 10Ω - 20Ω 1Ω - 20Ω 20.5Ω - 20MΩ 10Ω - 20Ω 1Ω - 20Ω 20.5Ω - 20MΩ 10Ω - 20Ω 1Ω - 20Ω 20.5Ω - 20MΩ 10Ω - 20Ω ±100 1Ω - 294Ω 300Ω - 20MΩ For detail questions, contact : sales@viking.com.tw 2 ±1% ±5% (E24,E96) (E24) 1Ω-20Ω 1Ω - 20Ω 20.5Ω - 20MΩ ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor ■High Power & Ultra High Power Rating Electrical Specifications Item Type PWR03 (0603) Power Rating at 70°C Jumper Rated Current 1/4W Operating Temp. Range Max. Operating Voltage Max. Overload Voltage -55 ~ +155C 75V 150V Resistance Range ±0.5% (E24,E96) ±1% (E24,E96) 1Ω - 294Ω 10Ω - 294Ω 300Ω - 1MΩ Jumper: 5A* 2/5W 0Ω(≦8mΩ) 10Ω - 294Ω PWR05 (0805) -55 ~ +155C 150V ±5% (E24) 1Ω - 294Ω 1/2W * 10Ω - 294Ω -55 ~ +155C 400V 300Ω - 1MΩ 0Ω(≦5mΩ) - 1Ω - 20Ω 10Ω - 20Ω 1/2W -55 ~ +155C 200V 3/4W * 500V 1000V 20.5Ω - 1MΩ Jumper: 10A* 3/4W PWR10 (2010) 1W PWR12 (2512) 2W * 0Ω(≦5mΩ) 10Ω - 20Ω PWR13 (1210) -55 ~ +155C 200V 10Ω - 20Ω 400V 1Ω - 20Ω ±200 ±100 ±200 1Ω - 20Ω ±200 800V 10Ω 500V ±200 ±100 20.5Ω - 1MΩ -55 ~ +155C ±100 - 400V 20.5Ω - 1MΩ -55 ~ +155C ±200 ±100 1Ω - 20Ω 10Ω - 20Ω -55 ~ +155C ±200 400V 20.5Ω - 1MΩ PWR06 (1206) ±100 - ±100 1Ω - 294Ω 600V Jumper: 6A* PWR06 (1206) ±200 300V 300Ω - 1MΩ PWR05 (0805) TCR (PPM/°C) ±100 1Ω - 10Ω ±350 1000V 10.2Ω-200K ±100 *: Ultra High Power: double side printed resistor element Operating Voltage=√(P*R) or Max. Operating Voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. The power rating depends on the maximum temperature of the resistive element. Due to the power dissipation of the resistor, the temperature of the resistive element will rise depending on the condition of heat dissipation from PCB. The maximum power rating in application only applies if the temperature of the resistive element is not exceed 155℃. ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. ■Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact : sales@viking.com.tw 3 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor ■Environmental Characteristics Item Temperature Coefficient of Resistance (T.C.R.) Requirement ±5% and Below Jumper JIS-C-5201-1 4.8 IEC-60115-1 4.8 At 25C/-55C and 25C/+125C, 25C is the reference temperature As Spec. Short Time Overload (1.0%+0.05Ω) Insulation Resistance 10G Endurance (1.0%+0.05Ω) 0603: ≦8mΩ 0805: ≦5mΩ 1206: ≦5mΩ 0603: ≦8mΩ 0805: ≦5mΩ 1206: ≦5mΩ (0.5%+0.05Ω) Damp Heat with Load Ultra High Power * (1.0%+0.05Ω) JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds Jumper:2*Imax for 5 seconds JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” 0603: ≦8mΩ 0805: ≦5mΩ 1206: ≦5mΩ JIS-C-5201-1 4.24 IEC-60115-1 4.24 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155C for 1000 hrs JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 60 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 2455C for 3 seconds Dry Heat (0.5%+0.05Ω) 0603: ≦8mΩ 0805: ≦5mΩ 1206: ≦5mΩ Bending Strength (1.0%+0.05Ω) 0603: ≦8mΩ 0805: ≦5mΩ 1206: ≦5mΩ Solderability 95% min. coverage Resistance to Soldering Heat (0.5%+0.05Ω) Voltage Proof Test Method 0603: ≦8mΩ 0805: ≦5mΩ 1206: ≦5mΩ No breakdown or flashover JIS-C-5201-1 4.18 IEC-60115-1 4.18 2605C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 1.42 times Max. Operating Voltage for 1 minute Leaching Rapid Change of Temperature Individual leaching area ≦5% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Total leaching area ≦ 10% 2605C for 30 seconds (0.5%+0.05Ω) 0603: ≦8mΩ 0805: ≦5mΩ 1206: ≦5mΩ JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■Storage Temperature: 15~28C; Humidity < 80%RH ■Packaging Reel Specifications & Packaging Quantity www.viking.com.tw For detail questions, contact : sales@viking.com.tw 4 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor Type PWR02 Paper PWR03 PWR05 PWR06 Paper PWR13 PWR10 PWR12 Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 Packaging Quantity Embossed ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 60 60 +1/-0 +1/-0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 20K 8mm 13 inch 330±1.0 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 4K 12mm 7 inch 178.5±1.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 8K 12mm 10 inch 250±1.0 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 60 Paper Tape Specifications Bottom Tape Top Tape ψ D0 E A F B T Paper Tape P2 P0 Direction of unreeling P2 (mm) ΦD0 (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) PWR02 0.65±0.10 1.15±0.10 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.1 PWR03 1.10±0.10 1.90±0.1 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.1 PWR05 1.60±0.10 2.40±0.2 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.1 PWR06 1.90±0.10 3.50±0.2 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.1 PWR13 2.90±0.10 3.50±0.2 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.1 Type A (mm) P1 Resistor W T (mm) Embossed Plastic Tape Specifications Top Tape ψ D0 E A F B W ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) P2 (mm) ΦD0 (mm) PWR10 2.80±0.10 5.40±0.20 12.0±0.3 1.75±0.1 5.50±0.05 4.00±0.10 4.00±0.1 2.00±0.05 1.50+0.1, -0 1.2 +0 PWR12 3.50±0.10 6.70±0.10 12.0±0.3 1.75±0.1 5.50±0.05 4.00±0.10 4.00±0.1 2.00±0.05 1.50+0.1, -0 1.2 +0 Type A (mm) www.viking.com.tw For detail questions, contact : sales@viking.com.tw 5 T (mm) Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor ■Marking No Marking for 0402 0805~2512 4 digits marking for Example Resistance 5.6Ω 97.6Ω 100Ω 2.2KΩ 10KΩ 49.9KΩ 100KΩ 1MΩ marking 5R60 97R6 1000 2201 1002 4992 1003 1004 0603: 3 digits marking in E24 st Example: 101=100Ω 102=1KΩ (1 and 2 E24 code 10 11 12 13 15 16 nd 18 rd are E24 code and 3 code is multiplier) 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 1% for 0603: 3 digits marking in E96 (E96 series except E24 series) 3 digits marking for Example: 13C=13K3Ω 13C 68B=4K99Ω 68X=49.9Ω Marking Table Code E96 Code E96 Code E96 Code E96 02 102 28 191 52 340 75 590 03 105 29 196 53 348 76 604 04 107 31 205 54 357 77 619 06 113 32 210 55 365 78 634 07 115 33 215 56 374 79 649 08 118 34 221 57 383 80 665 09 121 35 226 58 392 81 681 10 124 36 232 59 402 82 698 11 127 37 237 60 412 83 715 13 133 38 243 61 422 84 732 14 137 39 249 62 432 86 768 15 140 40 255 63 442 87 787 16 143 41 261 64 453 88 806 17 147 42 267 65 464 89 825 19 154 43 274 66 475 90 845 20 158 44 280 67 487 91 866 21 162 45 287 68 499 92 887 22 165 46 294 69 511 93 909 23 169 47 301 70 523 94 931 24 174 48 309 71 536 95 953 25 178 49 316 72 549 96 976 26 182 50 324 73 562 187 51 332 74 576 27 Code A Multiplier 10 B 0 www.viking.com.tw 10 C 1 10 D 2 10 E 3 10 F 4 10 G 5 10 6 X 10 For detail questions, contact : sales@viking.com.tw 6 -1 Y 10 -2 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor ■Recommend Land Pattern C Mi n Type A (mm) B (mm) C (mm) PWR02 0.50 0.45 0.60 PWR03 0.90 0.60 0.90 PWR05 1.20 0.70 1.30 PWR06 2.00 0.90 1.60 PWR13 2.00 0.90 2.80 PWR10 3.80 0.90 2.80 PWR12 4.90 1.00 3.40 T B www.viking.com.tw A For detail questions, contact : sales@viking.com.tw 7 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor ■Lightning Surge Resistors are tested in accordance with IEC 60115-1 using both 1.2/50us and 10/700 pulse shapes. The limit of acceptance is a shift in resistance of less than 1% from the initial value. PWR Series 1.2/50us Lightning Surge 10000 Peak Voltage (V) 2512 2010 1210 1206 0805 0603 1000 100 10 1 10 100 1000 10000 100000 1000000 Resistance(Ω) PWR Series 10/700us Lightning Surge 10000 2512 Peak Voltage (V) 2010 1210 1206 0805 1000 0603 100 10 1 10 100 1000 10000 100000 1000000 10000000 Resistance(Ω) www.viking.com.tw For detail questions, contact : sales@viking.com.tw 8 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor ■Pulse withstanding capacity The limit of acceptance was a shift in resistance of less than 1% from the initial value. The power applied was subject to the restrictions of the maximum permissible impulse voltage graph shown. www.viking.com.tw For detail questions, contact : sales@viking.com.tw 9 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor ■Continuous Pulse The continuous load graph was obtained by applying repetitive rectangular pulses where the pulse period was adjusted so that the average power dissipated in the resistor was equal to its rated power at 70C. Again the limit of acceptance was a shift in resistance of less than 1% from the initial value. www.viking.com.tw For detail questions, contact : sales@viking.com.tw 10 Edition : REV.C7 Revision: 10-Mar-2021 【PWR Series】 Pulse Withstanding Chip Resistor REVISION HISTORY REVISION DATE Version C CHANGE NOTIFICATION DESCRIPTION Jun 03, 2014 - - Environmental Characteristics updated Version C1 Apr 21, 2016 - - Features increase AEC-Q200 Compliance Version C2 Jul 15, 2016 - - Modify Storage Temperature Version C3 Oct 13, 2017 - - Increase High Power Specifications Version C4 Jul 27, 2018 - - Increase 0402 size Electrical Specifications - Increase 0805/1206 Ultra High Power Electrical Specifications Version C5 May 20, 2019 - - Modify TCR Test description Version C6 Jan 31, 2020 - Version C7 Mar 10, 2021 - www.viking.com.tw - Increase PWR2512 2W - Increase 0603 / 0805/1206 High power rating 0R (Jumper) - Modify Bending Test description - Increase large reel packaging code - Modify 2010 Embossed Plastic Tape B Specification - Modify Soldering Condition (IPC/JEDEC J-STD-020) For detail questions, contact : sales@viking.com.tw 11 Edition : REV.C7 Revision: 10-Mar-2021
PWR13FTEU40R2
物料型号:PWR Series
器件简介: - 该系列为脉冲耐受芯片电阻,具有不同的尺寸(0402/0603/0805/1206/1210/2010/2512)和额定功率。 - 符合AEC-Q200标准,适用于多种应用场景,如测量设备、诊断设备、医疗设备、工业控制、等离子、LCD视频监视器等。
引脚分配:文档中未明确列出引脚分配,但提供了不同尺寸的电阻器的物理尺寸和重量。
参数特性: - 容差范围从±0.5%到5%。 - 高功率等级。 - 优秀的脉冲耐受性能。 - 提升的工作电压等级。
功能详解: - 电阻器由氧化铝基板、外部电极、底电极、电阻层、顶电极、主覆盖层、边缘电极和障碍层组成。
应用信息: - 适用于计量、诊断设备、医疗设备、工业控制、等离子、LCD视频监视器等多种应用。
封装信息: - 提供了不同尺寸的封装信息,包括长度、宽度、厚度、内径和外径,以及每1000个电阻的重量。
PWR13FTEU40R2 价格&库存
很抱歉,暂时无法提供与“PWR13FTEU40R2”相匹配的价格&库存,您可以联系我们找货
